[patch] for datetime pattern in valueFn with DbLog
Begonnen von stephan.ritscher, 12 Januar 2020, 20:43:25
stephan.ritscher
Fix pattern for timestamps in month October which are set by valueFn of DbLog device.
DS_Starter
I'm a litttle bit confused about your version. The last version is:
FVERSION   93_DbLog.pm:v4.9.6-s20883/2020-01-04
and the mentioned code doesn't exist. The valueFn is currently designed as:
                      my ($yyyy, $mm, $dd, $hh, $min, $sec) = ($TIMESTAMP =~ /(\d+)-(\d+)-(\d+) (\d+):(\d+):(\d+)/);
                      eval { my $epoch_seconds_begin = timelocal($sec, $min, $hh, $dd, $mm-1, $yyyy-1900); };
                      if (!$@) {
                          $timestamp = $TIMESTAMP;
                      } else {
DS_Starter
Uuups, inddeed there is an old code snippet in lines 4624. I will change it to the current standard code.
best regards
Heiko
DS_Starter
I have changed the code to DbLog standard and checked in the module just now.
regards,
Heiko
