OWX Arduino Einstellungen
Begonnen von eisman, 19 Februar 2020, 07:54:47
eisman
ich habe einen Arduino Uno
   CONNECTS   3
   DEF        3030 global
   DRIVER_VERSION 0.64
   DeviceName 3030
   FD         4
   FUUID      5e42e4c7-f33f-6059-2d87-0a13613c16a7c3c0
   NAME       UNO_M8
   NOTIFYDEV  global
   NR         75
   NTFY_ORDER 50-UNO_M8
   PORT       3030
   STATE      Initialized
   TYPE       FRM
   analog_pins 14,15,16,17,18,19
   analog_resolutions 14:10,15:10,16:10,17:10,18:10,19:10
   firmware   ConfigurableFirmata.ino
   firmware_version V_2_05
   i2c_pins   18,19
   input_pins 2,3,5,6,7,8,9,14,15,16,17,18,19
   onewire_pins 2,3,5,6,7,8,9,14,15,16,17,18,19
   output_pins 2,3,5,6,7,8,9,14,15,16,17,18,19
   protocol_version V_2_05
   pullup_pins 2,3,5,6,7,8,9,14,15,16,17,18,19
   pwm_pins   3,5,6,9
   pwm_resolutions 3:8,5:8,6:8,9:8
   servo_pins 2,3,5,6,7,8,9
   servo_resolutions 2:14,3:14,5:14,6:14,7:14,8:14,9:14
     2020-02-19 07:29:20   state           Initialized
   SERIAL:
   SocketDevice:
     BUF
     DeviceName 3030
     FD         20
     NAME       UNO_M8_192.168.1.80_49153
     NR         2710
     PEER       192.168.1.80
     PORT       49153
     SNAME      UNO_M8
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FRM
       2020-02-19 07:29:16   state           Connected
   room       FRM
ein OWX mit 3x DS18B20
[code]Internals:
   ALARMED    0
   ASYNCHRONOUS 1
   BUSY       0
   DEF        UNO_M8:14
   DeviceName UNO_M8:14
   FRM_OWX_CORRELATIONID 67
   FRM_OWX_CURRDEV 28.FF67B9021703.25
   FUUID      5e44ee3f-f33f-6059-682f-6e6547331bef566c
   HWDEVICE   UNO_M8
   INITDONE   1
   INTERFACE  firmata
   IODev      UNO_M8
   LASTSEND   1582094413.03316
   NAME       OWXio1
   NR         81
   PARTIAL
   PIN        14
   PREBUFFER  000000000�
   PRESENT    1
   ROM_ID     FF
   STATE      Initialized
   TYPE       OWX
   interval   300
   timeout    2
   DEVHASH:
     OWXio1     Busmaster
   DEVS:
     28.285E77911402.F8
     28.FF12B4021704.84
     28.FF67B9021703.25
   FRM_OWX_REPLIES:
     28.285E77911402.F8 0U~�f<��������������������
     28.FF12B4021704.84 ?KF� ���������������������
     28.FF67B9021703.25 BKF� :��������������������
   FRM_OWX_REQUESTS:
     4002:
       device     28.FF67B9021703.25
       command:
         id         4002
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4003:
       command:
         id         4003
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4004:
       device     28.FF12B4021704.84
       command:
         id         4004
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4005:
       command:
         id         4005
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4006:
       device     28.285E77911402.F8
       command:
         id         4006
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4007:
       command:
         id         4007
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4008:
       command:
         id         4008
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4009:
       command:
         id         4009
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4010:
       command:
         id         4010
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4011:
       command:
         id         4011
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4012:
       command:
         id         4012
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4013:
       command:
         id         4013
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4014:
       command:
         id         4014
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4015:
       command:
         id         4015
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4016:
       command:
         id         4016
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4017:
       command:
         id         4017
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4018:
       command:
         id         4018
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4019:
       command:
         id         4019
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4020:
       command:
         id         4020
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4021:
       command:
         id         4021
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4022:
       command:
         id         4022
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4023:
       command:
         id         4023
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4024:
       command:
         id         4024
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4025:
       command:
         id         4025
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4026:
       command:
         id         4026
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4027:
       command:
         id         4027
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4028:
       command:
         id         4028
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4029:
       command:
         id         4029
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4030:
       command:
         id         4030
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4031:
       command:
         id         4031
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4032:
       command:
         id         4032
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4033:
       command:
         id         4033
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4034:
       command:
         id         4034
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4035:
       command:
         id         4035
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4036:
       command:
         id         4036
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4037:
       command:
         id         4037
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4038:
       command:
         id         4038
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4039:
       command:
         id         4039
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4040:
       command:
         id         4040
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4041:
       command:
         id         4041
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4042:
       command:
         id         4042
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4043:
       command:
         id         4043
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4044:
       command:
         id         4044
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4045:
       command:
         id         4045
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4046:
       command:
         id         4046
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4047:
       command:
         id         4047
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4048:
       command:
         id         4048
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4049:
       command:
         id         4049
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4050:
       command:
         id         4050
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4051:
       command:
         id         4051
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4052:
       command:
         id         4052
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4053:
       command:
         id         4053
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4054:
       command:
         id         4054
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4055:
       command:
         id         4055
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4056:
       command:
         id         4056
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4057:
       command:
         id         4057
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4058:
       command:
         id         4058
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4059:
       command:
         id         4059
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4060:
       command:
         id         4060
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4061:
       command:
         id         4061
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4062:
       command:
         id         4062
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4063:
       command:
         id         4063
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4064:
       command:
         id         4064
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4065:
       command:
         id         4065
         read       29
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           190
     4066:
       command:
         id         4066
         read       11
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           68
     4067:
       command:
         id         4067
         read       29
         select:
           crc        248
           family     40
           identity:
             40
             94
             119
             145
             20
             2
         write:
           190
     4068:
       command:
         id         4068
         read       11
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           68
     4069:
       command:
         id         4069
         read       29
         select:
           crc        37
           family     40
           identity:
             255
             103
             185
             2
             23
             3
         write:
           190
     4070:
       command:
         id         4070
         read       11
         select:
           crc        132
           family     40
           identity:
             255
             18
             180
             2
             23
             4
         write:
           68
     4071:
       command:
         id         4071
         read       29
1x FHEM Debian, Homematic,ZigBee,FS20 / 1X Raspberry, ConBee / 7x ESP
1x FHEM Debian, Homematic,Z2M             / 1X Raspberry, ConBee / 6x ESP
1x FHEM Debian,MQTT2                             / 1X Raspberry, i2c,onewire,gpio
1x auf Windows 2012 Hyper-V-S
