Revision 21050: 93_DbRep: adjust behavior of writeToDB - write value at every begin ...
Begonnen von System, 25 Januar 2020, 21:00:30
System
93_DbRep: adjust behavior of writeToDB - write value at every begin and also at every end of period, fix Warning when Agent has detected a renamed device, remove adminCredentials from set of DbRep device type "Agent", delDoublets now     are working for PostgreSQL, calculation of number_fetched_rows corrected, count of inserted rows into standby database corrected, avoid Duplicate entry errors in writeToDB
Source: Revision 21050: 93_DbRep: adjust behavior of writeToDB - write value at every begin ...
