Hombot Saugroboter geht offline und kommt nicht zurück
Begonnen von edition, 19 April 2020, 07:13:25
edition
   DEF        192.168.0.27
   FUUID      5e7f0095-f33f-62ad-598c-0c2b7ecbcbc17b27
   HOST       192.168.0.27
   INTERVAL   750
   NAME       Hombot
   NR         550
   PORT       6260
   PREVIOUSHOMBOTSTATE ONLINE
   STATE      Homebot offline
   TYPE       HOMBOT
   VERSION    0.2.5
     2020-04-19 07:40:46   at_0_MONDAY
     2020-04-19 07:40:46   at_1_TUESDAY
     2020-04-19 07:40:46   at_2_WEDNESDAY
     2020-04-19 07:40:46   at_3_THURSDAY
     2020-04-19 07:40:46   at_4_FRIDAY
     2020-04-19 07:40:46   at_5_SATURDAY
     2020-04-19 07:40:46   at_6_SUNDAY
     2020-04-19 07:40:46   batteryPercent  100
     2020-04-19 07:40:46   cleanMode       SB
     2020-04-19 07:40:46   cpu_IDLE        74.36
     2020-04-19 07:40:46   cpu_NICE        0.00
     2020-04-19 07:40:46   cpu_SYS         16.89
     2020-04-19 07:40:46   cpu_USER        8.74
     2020-04-19 07:40:46   currentBumping  3233
     2020-04-19 07:40:46   firmware        16552
     2020-04-19 07:53:29   hombotState     OFFLINE
     2020-04-19 07:40:46   lastClean       08.04.2020 09:44
     2020-04-08 09:44:27   lastSetCommandState cmd_done
     2020-04-19 07:53:26   lastStatusRequestError connect to http://192.168.0.27:6260 timed out
     2020-04-19 07:53:26   lastStatusRequestState statusRequest_error
     2020-04-19 07:53:29   luigiHttpSrvState running
     2020-04-19 07:40:46   luigiSrvVersion lg.srv, V2.51 compiled 18.11.2016, by fx2
     2020-04-19 07:40:46   nickname        Hombot
     2020-04-19 07:40:46   numSB_Begin     128
     2020-04-19 07:40:46   numSB_Ende      9
     2020-04-19 07:40:46   numSPOT_Begin   9
     2020-04-19 07:40:46   numSPOT_Ende    5
     2020-04-19 07:40:46   numZZ_Begin     69
     2020-04-19 07:40:46   numZZ_Ende      12
     2020-04-19 07:40:46   repeat          false
     2020-04-19 07:53:29   state           Homebot offline
     2020-04-19 07:40:46   turbo           false
   helper:
     requestErrorCounter 0
     setErrorCounter 0
     sshpass    /usr/bin/sshpass
   icon       vacuum_bold
   interval   750
   room       09_Buero
   verbose    5
Ping vom Raspi:
pi@raspberrypi:~ $ ping 192.168.0.27
PING 192.168.0.27 (192.168.0.27) 56(84) bytes of data.
64 bytes from 192.168.0.27: icmp_seq=1 ttl=64 time=3.87 ms
64 bytes from 192.168.0.27: icmp_seq=2 ttl=64 time=5.15 ms
64 bytes from 192.168.0.27: icmp_seq=3 ttl=64 time=4.00 ms
64 bytes from 192.168.0.27: icmp_seq=4 ttl=64 time=3.62 ms
64 bytes from 192.168.0.27: icmp_seq=5 ttl=64 time=4.95 ms
64 bytes from 192.168.0.27: icmp_seq=6 ttl=64 time=3.28 ms
64 bytes from 192.168.0.27: icmp_seq=7 ttl=64 time=3.92 ms
64 bytes from 192.168.0.27: icmp_seq=8 ttl=64 time=3.67 ms
64 bytes from 192.168.0.27: icmp_seq=9 ttl=64 time=4.42 ms
64 bytes from 192.168.0.27: icmp_seq=10 ttl=64 time=4.44 ms
64 bytes from 192.168.0.27: icmp_seq=11 ttl=64 time=4.32 ms
64 bytes from 192.168.0.27: icmp_seq=12 ttl=64 time=3.80 ms
64 bytes from 192.168.0.27: icmp_seq=13 ttl=64 time=8.67 ms
64 bytes from 192.168.0.27: icmp_seq=14 ttl=64 time=3.78 ms
64 bytes from 192.168.0.27: icmp_seq=15 ttl=64 time=3.25 ms
64 bytes from 192.168.0.27: icmp_seq=16 ttl=64 time=3.31 ms
64 bytes from 192.168.0.27: icmp_seq=17 ttl=64 time=3.34 ms
64 bytes from 192.168.0.27: icmp_seq=18 ttl=64 time=3.06 ms
64 bytes from 192.168.0.27: icmp_seq=19 ttl=64 time=3.79 ms
64 bytes from 192.168.0.27: icmp_seq=20 ttl=64 time=3.13 ms
64 bytes from 192.168.0.27: icmp_seq=21 ttl=64 time=3.48 ms
64 bytes from 192.168.0.27: icmp_seq=22 ttl=64 time=5.52 ms
64 bytes from 192.168.0.27: icmp_seq=23 ttl=64 time=3.70 ms
64 bytes from 192.168.0.27: icmp_seq=24 ttl=64 time=3.23 ms
64 bytes from 192.168.0.27: icmp_seq=25 ttl=64 time=3.28 ms
64 bytes from 192.168.0.27: icmp_seq=26 ttl=64 time=5.79 ms
64 bytes from 192.168.0.27: icmp_seq=27 ttl=64 time=4.09 ms
64 bytes from 192.168.0.27: icmp_seq=28 ttl=64 time=3.30 ms
64 bytes from 192.168.0.27: icmp_seq=29 ttl=64 time=3.71 ms
64 bytes from 192.168.0.27: icmp_seq=30 ttl=64 time=2.59 ms
64 bytes from 192.168.0.27: icmp_seq=31 ttl=64 time=3.54 ms
64 bytes from 192.168.0.27: icmp_seq=32 ttl=64 time=4.06 ms
64 bytes from 192.168.0.27: icmp_seq=33 ttl=64 time=3.63 ms
64 bytes from 192.168.0.27: icmp_seq=34 ttl=64 time=5.48 ms
64 bytes from 192.168.0.27: icmp_seq=35 ttl=64 time=3.20 ms
64 bytes from 192.168.0.27: icmp_seq=36 ttl=64 time=3.92 ms
64 bytes from 192.168.0.27: icmp_seq=37 ttl=64 time=3.63 ms
64 bytes from 192.168.0.27: icmp_seq=38 ttl=64 time=3.02 ms
64 bytes from 192.168.0.27: icmp_seq=39 ttl=64 time=5.26 ms
64 bytes from 192.168.0.27: icmp_seq=40 ttl=64 time=2.60 ms
64 bytes from 192.168.0.27: icmp_seq=41 ttl=64 time=4.18 ms
64 bytes from 192.168.0.27: icmp_seq=42 ttl=64 time=3.00 ms
64 bytes from 192.168.0.27: icmp_seq=43 ttl=64 time=3.21 ms
64 bytes from 192.168.0.27: icmp_seq=44 ttl=64 time=3.31 ms
64 bytes from 192.168.0.27: icmp_seq=45 ttl=64 time=8.92 ms
64 bytes from 192.168.0.27: icmp_seq=46 ttl=64 time=3.15 ms
64 bytes from 192.168.0.27: icmp_seq=47 ttl=64 time=2.94 ms
64 bytes from 192.168.0.27: icmp_seq=48 ttl=64 time=4.14 ms
64 bytes from 192.168.0.27: icmp_seq=49 ttl=64 time=3.66 ms
64 bytes from 192.168.0.27: icmp_seq=50 ttl=64 time=2.92 ms
64 bytes from 192.168.0.27: icmp_seq=51 ttl=64 time=4.01 ms
64 bytes from 192.168.0.27: icmp_seq=52 ttl=64 time=3.22 ms
64 bytes from 192.168.0.27: icmp_seq=53 ttl=64 time=3.11 ms
64 bytes from 192.168.0.27: icmp_seq=54 ttl=64 time=8.58 ms
^C
--- 192.168.0.27 ping statistics ---
54 packets transmitted, 54 received, 0% packet loss, time 135ms
rtt min/avg/max/mdev = 2.588/4.020/8.919/1.348 ms
CoolTux
Das hier macht mich stutzig
Der Timestamp ist der selbe. Aktuell habe ich noch keine Erklärung geschweige den eine Lösung.
Ich schaue im Laufe des Tages mal in den Code.
Das TuxNet Wiki:
https://www.cooltux.net
edition
Habe gerade eine neue known_hosts Datei erstellt und nach /opt/fhem/.ssh/ verschoben. Rechte auf 777
Wer weiß, wofür das gut ist. Der Hombot hatte vorher eine andere IP Adresse und ich weiß nicht, ob ich den selben USB Stick verwendet habe.
edition
Ich glaube, das war es!
Habe gerade den statusRequest gerade einmal manuell angestoßen, nachdem ich die known_hosts Datei getauscht habe. Jetzt ist er wieder online!
CoolTux
Ah jetzt weiß ich erst was genau Du meinst. Es reicht wenn die Datei 644 hast, aber entscheidend ist das sich die ip des hombot geändert hat und somit gibt es in der Datei einen IP Konflikt. Das war der entscheidende Hinweis.
Das TuxNet Wiki:
edition
Der Hombot war längere Zeit außer Gefecht. Zwischenzeitig hatte ich meine IP Adressen neu geordnet. Darum habe ich den WLAN Hack neu eingespielt. Um die known_hosts Datei habe ich mir keine Gedanken gemacht und sie vom alten System wieder in das Verzeichniss kopiert.
Ich schau einfach mal, was passiert, in den nächsten Tagen.
Trotzdem Danke für die Unterstützung!
edition
