#erledigt# Problem mit HM-LC-SW4-DR-2
Begonnen von Helmi55, 05 Juni 2020, 18:53:38
Helmi55
Hallo das Gerät ist ca. 3 Monate alt und ich bekomme ab und zu diese Meldungen
2020.06.05 17:42:22 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:23 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:23 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:24 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:27 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:27 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:28 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:28 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:28 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:36 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:36 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:36 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:37 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:37 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:37 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:37 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:39 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:39 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:41 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:41 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:41 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:41 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:42 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:42 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:42 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:43 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:44 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:44 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:44 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:46 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:47 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:47 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:47 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:47 3: CUL_HM PoolPumpe repeat, level C8 instead of 00
2020.06.05 17:42:48 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:48 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
2020.06.05 17:42:48 3: CUL_HM set PoolPumpe off
2020.06.05 17:42:49 3: CUL_HM set PoolPumpe on
2020.06.05 17:42:49 3: CUL_HM PoolPumpe repeat, level 00 instead of C8
In der Suche hab ich nix zielführendes gefunden.
Problem ist dass die Filterpumpe ständig hin und her schaltet (sicher nicht gesund für die Pumpe)
Einziges was hilft ist ein Neustart von FHEM ............
Hier ein List
   DEF        6F77DE01
   FUUID      5e89af49-f33f-b033-c1f4-460457c584ceb569
   NAME       PoolPumpe
   NOTIFYDEV  global
   NR         517
   NTFY_ORDER 50-PoolPumpe
   STATE      on
   TYPE       CUL_HM
   chanNo     01
   device     HM_4_Switch_Garage
     2020-06-05 17:45:31   CommandAccepted yes
     2020-04-05 12:13:44   R-powerUpAction off
     2020-04-05 12:13:44   R-sign          off
     2020-05-02 10:14:19   RegL_01.        00:00 08:00 30:06 56:00 57:24
     2020-06-05 17:45:31   deviceMsg       on (to VCCU)
     2020-06-05 17:45:31   level           100
     2020-06-05 17:42:52   levelMissed     desired:0
     2020-06-05 17:45:31   pct             100
     2020-06-05 17:45:31   recentStateType ack
     2020-06-05 17:45:31   state           on
     2020-06-05 17:45:31   timedOn         off
     2020-06-05 17:45:30   trigLast        fhem:02
   helper:
     dlvlCmd    ++A0112203556F77DE0201C80000
     peerFriend peerSens,peerVirt
     peerOpt    3:switch
     regLst     1,3p
     cmds:
       TmplKey    :no:1591371814.30743
       TmplTs     1591371814.30743
       cmdKey     :1:0:0::0003:01
       TmplCmds:
       cmdList:
         clear:[readings|trigger|register|oldRegs|rssi|msgEvents|msgErrors|attack|all]
         eventL:-peer- -cond-
         eventS:-peer- -cond-
         getConfig:
         getRegRaw:[List0|List1|List2|List3|List4|List5|List6] ... [-PeerChannel-]
         inhibit:[on|off]
         off:
         on-for-timer:-ontime-
         on-till:-time-
         on:
         peerBulk:-peer1,peer2,...- [set|unset]
         peerIODev:[IO] -btn- [set|unset]... not for future use
         press:[long|short] -peer- [-repCount(long only)-] [-repDelay-] ...
         regBulk:-list-.-peer- -addr1:data1- -addr2:data2- ...
         regSet:[prep|exec] -regName- -value- ... [-peerChannel-]
         sign:[on|off]
         statusRequest:
         toggle:
         tplDel:tmplt
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     role:
       chn        1
     tmpl:
   group      Poolsteuerung
   model      HM-LC-SW4-DR-2
   peerIDs    00000000,
   room       Poolsteuerung
   sortby     6
   webCmd     on:off
Da es sich anscheinend um Probleme mit der Rückmeldung handelt, möchte ich zumindest über dieses Problem mit Pushover benachrichtigt werden!
wie kann ich das mit einem notify oder DOIF umsetzen und schnellstmöglich zu reagieren und FHEM neu zu starten um die Pumpe zu schonen
Wer kann mir bitte helfen
Helmut
System1 fhem 6.1 auf RPi 4B mit 4GB, HMUSBConfig, DS9490R-1Wire, Busware USB 868, Pool-Solarsteuerung mit FHEM. System2 fhem 6.1 auf RPi 4B mit 4GB (Bullseye) mit Busware USB 868 und 433 und HMUARTLGW für Haussteuerung
https://www.flickr.com/photos/canonhelmi/
frank
#1
mit welcher prozedur wird die pumpe geschaltet?
ich denke, dass das reading levelMissed bei problemen aktualisiert wird, also für dein notify sinnvoll.
warum gibt es die probleme?
zeig mal ein list vom hauptdevice.
die pumpe wird ja durch die meldung nicht unbedingt mehr geschaltet.
die pumpe meldet nur nicht das level, welches versucht wurde zu schalten. sie schaltet also eher zu wenig.
warum schaltest du nicht mit on-for-timer, dann ist immer sichergestellt, dass wenn die pumpe eingeschaltet wird, diese auf alle fälle ohne neuen befehl auch wieder ausschaltet.
das ist dann schon mal nur die hälfte der kommunikation.
FHEM: 6.0(SVN) => Pi3(buster)
Pfriemler
Auch ich vermute mal, dass hier eine Steuerung Amok läuft. Warum gibt es so extrem viele Schaltbefehle in so kurzer Zeit? Teilweise liegen zwischen widersprüchlichen Schaltbefehlen ja nicht einmal eine Sekunde. Und die Aktoren melden ihren Status immer mit einer gewissen Verzögerung.
Wenn also FHEM "on" schaltet und 1 sek später wieder "off, der Aktor aber aus welchen Gründen auch immer den off-Befehl ignoriert (etwa weil seine Rückmeldung mit dem neuen Schaltbefehl kollidiert) und kurz später wiederholt dann erfolgreich "on" zurückmeldet, dann ist das für FHEM der klassische "meldet C8 obwohl ich 0 erwartet habe nach meinem letzten Schaltbefehl" (&HC8=200 = on, &00 = 0 = off).
Helmi55
Hallo hier das List vom Schalter selbst
   DEF        6F77DE
   FUUID      5e89af48-f33f-b033-b53d-c7bbc3ea1f53e729
   HMUSB_MSGCNT 18
   HMUSB_RAWMSG R85D236D8,0001,34B28348,FF,FFD3,0080026F77DE220355010200002D
   HMUSB_RSSI -45
   HMUSB_TIME 2020-06-05 20:50:45
   IODev      HMUSB
   LASTInputDev HMUSB
   MSGCNT     18
   NAME       HM_4_Switch_Garage
   NOTIFYDEV  global
   NR         515
   NTFY_ORDER 50-HM_4_Switch_Garage
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 PoolPumpe
   channel_02 SolarPumpe
   channel_03 WPPool
   channel_04 Roboter
   lastMsg    No:00 - t:02 s:6F77DE d:220355 010200002D
   protLastRcv 2020-06-05 20:50:45
   protRcv    14 last_at:2020-06-05 20:50:45
   protSnd    18 last_at:2020-06-05 20:50:45
   protState  CMDs_done
   rssi_HMUSB cnt:14 min:-48 max:-45 avg:-46.71 lst:-45
   rssi_at_HMUSB cnt:18 min:-47 max:-43 avg:-45.66 lst:-45
     2020-04-05 12:13:36   CommandAccepted yes
     2020-04-05 12:13:41   D-firmware      2.4
     2020-04-05 12:13:41   D-serialNr      QEQ0660165
     2020-05-02 10:14:18   PairedTo        0x220355
     2020-04-05 12:13:43   R-pairCentral   0x220355
     2020-05-02 10:14:18   RegL_00.        00:00 02:01 0A:22 0B:03 0C:55 15:FF 18:00
     2020-06-05 20:50:45   commState       CMDs_done
     2020-04-26 15:00:43   powerOn         2020-04-26 15:00:43
     2020-06-05 20:50:45   state           CMDs_done
   helper:
     HM_CMDNR   0
     cSnd       112203556F77DE0203000000,112203556F77DE0202000000
     mId        0003
     peerFriend
     peerOpt    -:switch
     regLst     0
     rxType     1
     supp_Pair_Rep 0
     cmds:
       TmplKey    :no:1591371814.24195
       TmplTs     1591371814.24195
       cmdKey     :0:1:0::0003:01
       TmplCmds:
       cmdList:
         assignHmKey:
         deviceRename:newName
         fwUpdate:-filename- -bootTime- ...
         getConfig:
         getDevInfo:
         getSerial:
         getVersion:
         pair:
         raw:data ...
         reset:
         tplDel:tmplt
         unpair:
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +6F77DE,00,00,00
       nextSend   1591383045.88802
       rxt        0
       vccu       VCCU
       p:
         6F77DE
         00
         00
         00
       prefIO:
         HMUSB
     mRssi:
       mNo        00
       io:
         HMUSB:
           -37
           -37
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       prs        1
     rssi:
       HMUSB:
         avg        -46.7142857142857
         cnt        14
         lst        -45
         max        -45
         min        -48
       at_HMUSB:
         avg        -45.6666666666667
         cnt        18
         lst        -45
         max        -43
         min        -47
     tmpl:
   IODev      HMUSB
   IOgrp      VCCU:HMUSB
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.4
   room       HM-Steuerung
   serialNr   QEQ0660165
   subType    switch
   webCmd     getConfig:clear msgEvents
Aufgefallen ist es mir., als ich die Pumpe vom Handy aus, abschalten wollte um das Ventil auf "Rückspülen" zu setzen  und dann wieder auf "on" geschaltet habe.
Da bin ich neben der Pumpe gestanden und die hat on off on off..... geschaltet
Pfriemler
wie schaltest Du vom Handy aus? über FHEMWEB?
Welche Routinen arbeiten im Hintergrund auf den Aktor? Stichwort "Associated with"
frank
es gibt also null automatismen in fhem?
kein doif, at, notify, ...
du schaltest immer nur manuell?
ganz sicher?
der log ausschnitt ist das resultat aus:
1. genau einem manuellen off, um das ventil zu ändern.
2. und kurze zeit später hast du genau einmal wieder auf on geschaltet.
wenn das so stimmt, kann ich mir nur vorstellen, dass es an der handy app oder verbindung liegt.
was für eine app hast du genutzt?
oder wlan im eigenen netz? mit wlan repeater?
sehr seltsam...
frank
oder
kaputtes handy display mit nassen fingern bedient?
auf fhemweb lampensymbol geklickt, was dann diverse toggles auslöst hat?
Helmi55
Hallo und danke für eure Antworten.
Folgende Situation:
Selbstverständlich gibt es at und DOIF in meinem FHEM :D
Die PoolPumpe wird über ein at gesteuert
defmod Ti_PoolPumpe DOIF ([09:00-19:00] and [PoolMaster] eq "on") (set PoolPumpe on) DOELSE (set PoolPumpe off)
attr Ti_PoolPumpe do always
attr Ti_PoolPumpe room Steuerung
setstate Ti_PoolPumpe cmd_1
setstate Ti_PoolPumpe 2020-05-17 14:41:23 Device PoolMaster
setstate Ti_PoolPumpe 2020-06-06 09:00:00 cmd 1
setstate Ti_PoolPumpe 2020-06-06 09:00:00 cmd_event timer_1
setstate Ti_PoolPumpe 2020-06-06 09:00:00 cmd_nr 1
setstate Ti_PoolPumpe 2020-05-17 14:41:23 e_PoolMaster_STATE on
setstate Ti_PoolPumpe 2020-05-09 18:32:32 mode enabled
setstate Ti_PoolPumpe 2020-06-06 09:00:00 state cmd_1
setstate Ti_PoolPumpe 2020-06-05 19:00:00 timer_01_c01 06.06.2020 09:00:00
setstate Ti_PoolPumpe 2020-06-05 19:00:00 timer_02_c01 06.06.2020 19:00:00
Am Handy schalte ich über die EVE App (HomeKit) -
dazu gibt es eine RFHEM Verbindung zwischen dem Garagen Pi und dem Haus Pi (hier läuft HomeKit)
Das Handy war im Haus/Garten eigenen WLAN
Das Display meines Eierfon X ist nicht defekt und ich hatte auch keine nassen Finger  8)
Aber wenn ich jetzt so nachdenke, wollte ich auch von meinem Android Tablet in der Garage über FTUI schalten und hat dann nicht mehr funktioniert.
Es kann sein, dass da mit der RFHEM Verbindung Probleme macht?
Das ist RFHEM am Garagen Pi
defmod FHEMHaus RFHEM 10.0.0.10:7072
attr FHEMHaus room System
attr FHEMHaus verbose 0
setstate FHEMHaus created
setstate FHEMHaus 2020-06-06 10:13:55 ipadress 10.0.0.10
setstate FHEMHaus 2020-06-06 10:13:55 statedev present
Dann gibt es am Garagen Pi ein DOIF
defmod di_PoolPumpe_schalten DOIF ([PoolPumpe] eq "on") (set FHEMHaus cmd set du_PoolPumpe:FILTER=state=off on) DOELSEIF ([PoolPumpe] eq "off") (set FHEMHaus cmd set du_PoolPumpe:FILTER=state=on off)
attr di_PoolPumpe_schalten room Uebertrag
setstate di_PoolPumpe_schalten cmd_1
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 Device PoolPumpe
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 cmd 1
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 cmd_event PoolPumpe
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 cmd_nr 1
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 e_PoolPumpe_STATE on
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 state cmd_1
Am Haus Pi gibt es dann einen DUMMY
defmod du_PoolPumpe dummy
attr du_PoolPumpe alias PoolPumpe
attr du_PoolPumpe genericDeviceType switch
attr du_PoolPumpe room Homekit,Pool
attr du_PoolPumpe setList on off
attr du_PoolPumpe webCmd on:off
setstate du_PoolPumpe on
setstate du_PoolPumpe 2020-06-06 09:00:00 state on
und ein DOIF
defmod di_PoolPumpe_schalten DOIF ([du_PoolPumpe:"on"]) (set FHEMGarage cmd set PoolPumpe on) DOELSEIF ([du_PoolPumpe:"off"]) (set FHEMGarage cmd set PoolPumpe off)
attr di_PoolPumpe_schalten room RPi-Garage
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 Device du_PoolPumpe
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 cmd_event du_PoolPumpe
setstate di_PoolPumpe_schalten 2020-06-06 09:00:00 e_du_PoolPumpe_events on
setstate di_PoolPumpe_schalten 2019-05-08 09:06:08 mode enabled
RFHEM arbeitet aber sonst zuverlässig. Wird einiges drüber geschaltet oder liefert werte der Sensoren
Helmut
frank
da hast du dir vermutlich eine loop gebaut.
ich habe aber nicht versucht alles zu verstehen. scheinbar fehlt sogar noch etwas, mindestens "PoolMaster".
schon im ersten doif Ti_PoolPumpe scheint "murks" zu sein.
wenn poolmaster=on und du manuell ausschaltest, schaltet das doif sofort wieder ein.
Helmi55
Hallo
mir fällt grad auf hab einen Blödsinn geschrieben PoolPumpe wird nicht durch at sondern durch DOIF geschaltet
DAs Ganze hat jetzt jahrelang funktioniert. Aber du hast natürlich vollkommen recht, sobald ich die Poolpumpe händisch ausschalte greift sofort wieder das DOIF und schaltet sie ein.
Habs nur diesmal übers handy geschaltet. Sonst schalte ich den PoolMaster in der Garage am Tablet aus und dann ist "finster"
Der PoolMaster ist eigentlich nur ein Dummy um "ALLE" Geräte z.B. im Winter abzuschalten.
Ich werde den entfernen müssen denn wenn ich im DOIF das einbauen würde, dass wenn die PoolPumpe händisch ausgeschaltet wird auch der PoolMaster aus ist, dann hätte ich aber nach 19 Uhr z.B. bei Bedarf keine Wärmepumpe mehr weil die hängt natürlich aus am PoolMaster?
Helmut
Helmi55
Jetzt funkt es
defmod di_PoolPumpe DOIF ([09:00] and [PoolMaster] eq "on") (set PoolPumpe on) DOELSEIF ([19:00] and [PoolMaster] eq "on") (set PoolPumpe off)
attr di_PoolPumpe do always
attr di_PoolPumpe room Steuerung
Helmut
