Fehlermeldung warscheinlich bei ansteuerung FSB61
Begonnen von Firelight, 15 Januar 2015, 20:08:56
Firelight
Hallo
Ich habe seit kurzen meinen server neuinstalliert da ich umsteigen moechte von Fritzbox nach PC.
Seit kurzem wo ich einen enocean sensor umbenennt habe bekomme ich Fehler.
Kennt jemand unterstehende problem?
2015.01.15 19:54:00 2: autocreate: renamed FileLog_EnO_switch_018B38F1 to FileLog_EnO_sensor_018B38F1
2015.01.15 19:54:24 1: PERL WARNING: Use of uninitialized value $rorg in string eq at ./FHEM/10_EnOcean.pm line 6671.
2015.01.15 19:54:24 1: PERL WARNING: Use of uninitialized value $data in division (/) at ./FHEM/10_EnOcean.pm line 6680.
2015.01.15 19:54:24 1: PERL WARNING: Use of uninitialized value $rorg in concatenation (.) or string at ./FHEM/10_EnOcean.pm line 6681.
2015.01.15 19:54:24 1: PERL WARNING: Use of uninitialized value $data in concatenation (.) or string at ./FHEM/10_EnOcean.pm line 6681.
2015.01.15 19:54:24 1: PERL WARNING: Use of uninitialized value $rorg in concatenation (.) or string at ./FHEM/10_EnOcean.pm line 6682.
2015.01.15 19:54:24 1: PERL WARNING: Use of uninitialized value $data in concatenation (.) or string at ./FHEM/10_EnOcean.pm line 6682.
2015.01.15 19:54:24 1: TCM TCM_ESP2_1 unknown RORG mapping for 01
2015.01.15 19:54:25 1: TCM TCM_ESP2_1 unknown RORG mapping for 01
2015.01.15 19:56:04 1: EnOcean Unknown device with SenderID 00881F5E and RORG A5, please define it.
2015.01.15 19:56:04 2: autocreate: define EnO_sensor_00881F5E EnOcean 00881F5E EnOcean:1:A5:00527B0F:00881F5E:30:01FFFFFFFF0000
2015.01.15 19:56:04 2: autocreate: define FileLog_EnO_sensor_00881F5E FileLog ./log/EnO_sensor_00881F5E-%Y.log EnO_sensor_00881F5E
2015.01.15 19:58:01 3: EnOcean set EnO_sensor_018B38F1 closed
2015.01.15 19:58:32 3: EnOcean set EnO_sensor_018B38F1 closed
2015.01.15 19:58:33 2: TCM unknown ORG mapping for 58
2015.01.15 19:58:33 1: EnOcean RORG 58 received from 00000000 unknown.
