Seltsamer Log-Eintrag des DOIF Devices im fhem Logfile
Begonnen von EinEinfach, 18 August 2020, 09:06:58
EinEinfach
ich bekomme ab un zu im Logfile vom fhem einen seltsamen Fehler:
2020.08.16 16:12:15 2: di.zirkulationspumpe_to_heizkessel: offeq "off": Unknown command offeq, try help.
Der Device selbst ist wie folgt definiert:
   DEF        ## Befehle von dem Dummy Zirkulationspumpe in Buderus Sprache für KM100 übersetzt werden
##Zirkulationspumpe arbeitet nach Zeitplan
([HR.Zirkulationspumpe]eq "auto")
(set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp
[{"dayOfWeek":"Mo","setpoint":"on","time":330},
{"dayOfWeek":"Mo","setpoint":"off","time":1380},
{"dayOfWeek":"Tu","setpoint":"on","time":330},
{"dayOfWeek":"Tu","setpoint":"off","time":1380},
{"dayOfWeek":"We","setpoint":"on","time":330},
{"dayOfWeek":"We","setpoint":"off","time":1380},
{"dayOfWeek":"Th","setpoint":"on","time":330},
{"dayOfWeek":"Th","setpoint":"off","time":1380},
{"dayOfWeek":"Fr","setpoint":"on","time":330},
{"dayOfWeek":"Fr","setpoint":"off","time":1380},
{"dayOfWeek":"Sa","setpoint":"on","time":420},
{"dayOfWeek":"Sa","setpoint":"off","time":1320},
{"dayOfWeek":"Su","setpoint":"on","time":420},
{"dayOfWeek":"Su","setpoint":"off","time":1320}])
##Zirkulationspumpe ein
DOELSEIF ([HR.Zirkulationspumpe]eq "on")
{"dayOfWeek":"Mo","setpoint":"on","time":0},
{"dayOfWeek":"Tu","setpoint":"on","time":0},
{"dayOfWeek":"We","setpoint":"on","time":0},
{"dayOfWeek":"Th","setpoint":"on","time":0},
{"dayOfWeek":"Fr","setpoint":"on","time":0},
{"dayOfWeek":"Sa","setpoint":"on","time":0},
{"dayOfWeek":"Su","setpoint":"on","time":0}
##Zirkulationspumpe aus
DOELSE ([HR.Zirkulationspumpe]eq "off")
{"dayOfWeek":"Mo","setpoint":"off","time":0},
{"dayOfWeek":"Tu","setpoint":"off","time":0},
{"dayOfWeek":"We","setpoint":"off","time":0},
{"dayOfWeek":"Th","setpoint":"off","time":0},
{"dayOfWeek":"Fr","setpoint":"off","time":0},
{"dayOfWeek":"Sa","setpoint":"off","time":0},
{"dayOfWeek":"Su","setpoint":"off","time":0}
   FUUID      5dc3ef64-f33f-80cb-93b6-161a1a626544bc44
   MODEL      FHEM
   NAME       di.zirkulationspumpe_to_heizkessel
   NOTIFYDEV  global,HR.Zirkulationspumpe
   NR         127
   NTFY_ORDER 50-di.zirkulationspumpe_to_heizkessel
   STATE      cmd_1
   TYPE       DOIF
   VERSION    22030 2020-05-25 14:10:16
   Helper:
     DBLOG:
       cmd:
         SYS.DBLog:
           TIME       1597734301.99716
           VALUE      1
       cmd_event:
         SYS.DBLog:
           VALUE      di.zirkulationspumpe_to_heizkessel
       cmd_nr:
         SYS.DBLog:
           VALUE      1
       cmd_seqnr:
         SYS.DBLog:
           TIME       1597587139.2814
           VALUE      2
       error:
         SYS.DBLog:
           VALUE      set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp  [{"dayOfWeek":"Mo","setpoint":"on","time":330}, {"dayOfWeek":"Mo","setpoint":"off","time":1380}, {"dayOfWeek":"Tu","setpoint":"on","time":330}, {"dayOfWeek":"Tu","setpoint":"off","time":1380}, {"dayOfWeek":"We","setpoint":"on","time":330}, {"dayOfWeek":"We","setpoint":"off","time":1380}, {"dayOfWeek":"Th","setpoint":"on","time":330}, {"dayOfWeek":"Th","setpoint":"off","time":1380}, {"dayOfWeek":"Fr","setpoint":"on","time":330}, {"dayOfWeek":"Fr","setpoint":"off","time":1380}, {"dayOfWeek":"Sa","setpoint":"on","time":420}, {"dayOfWeek":"Sa","setpoint":"off","time":1320}, {"dayOfWeek":"Su","setpoint":"on","time":420}, {"dayOfWeek":"Su","setpoint":"off","time":1320}]
       mode:
         SYS.DBLog:
           TIME       1597733871.43242
           VALUE      enabled
       state:
         SYS.DBLog:
           VALUE      cmd_1
     2020-08-18 09:05:01   cmd             1
     2020-08-18 09:05:01   cmd_event       di.zirkulationspumpe_to_heizkessel
     2020-08-18 09:05:01   cmd_nr          1
     2020-08-18 09:05:01   error           set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp  [{"dayOfWeek":"Mo","setpoint":"on","time":330}, {"dayOfWeek":"Mo","setpoint":"off","time":1380}, {"dayOfWeek":"Tu","setpoint":"on","time":330}, {"dayOfWeek":"Tu","setpoint":"off","time":1380}, {"dayOfWeek":"We","setpoint":"on","time":330}, {"dayOfWeek":"We","setpoint":"off","time":1380}, {"dayOfWeek":"Th","setpoint":"on","time":330}, {"dayOfWeek":"Th","setpoint":"off","time":1380}, {"dayOfWeek":"Fr","setpoint":"on","time":330}, {"dayOfWeek":"Fr","setpoint":"off","time":1380}, {"dayOfWeek":"Sa","setpoint":"on","time":420}, {"dayOfWeek":"Sa","setpoint":"off","time":1320}, {"dayOfWeek":"Su","setpoint":"on","time":420}, {"dayOfWeek":"Su","setpoint":"off","time":1320}]: The service /dhwCircuits/dhw1/switchPrograms/cp has been changed succesfully!
     2020-08-18 08:57:51   mode            enabled
     2020-08-18 09:05:01   state           cmd_1
   Regex:
     accu:
     cond:
       HR.Zirkulationspumpe:
         0:
           &STATE     ^HR.Zirkulationspumpe$
         1:
   attr:
     cmdState:
     wait:
     waitdel:
   condition:
     0          ::InternalDoIf($hash,'HR.Zirkulationspumpe','STATE')eq "auto"
     1          ::InternalDoIf($hash,'HR.Zirkulationspumpe','STATE')eq "on"
   do:
     0:
       0          set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp  [{"dayOfWeek":"Mo","setpoint":"on","time":330}, {"dayOfWeek":"Mo","setpoint":"off","time":1380}, {"dayOfWeek":"Tu","setpoint":"on","time":330}, {"dayOfWeek":"Tu","setpoint":"off","time":1380}, {"dayOfWeek":"We","setpoint":"on","time":330}, {"dayOfWeek":"We","setpoint":"off","time":1380}, {"dayOfWeek":"Th","setpoint":"on","time":330}, {"dayOfWeek":"Th","setpoint":"off","time":1380}, {"dayOfWeek":"Fr","setpoint":"on","time":330}, {"dayOfWeek":"Fr","setpoint":"off","time":1380}, {"dayOfWeek":"Sa","setpoint":"on","time":420}, {"dayOfWeek":"Sa","setpoint":"off","time":1320}, {"dayOfWeek":"Su","setpoint":"on","time":420}, {"dayOfWeek":"Su","setpoint":"off","time":1320}]
     1:
       0          set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp  [ {"dayOfWeek":"Mo","setpoint":"on","time":0}, {"dayOfWeek":"Tu","setpoint":"on","time":0}, {"dayOfWeek":"We","setpoint":"on","time":0}, {"dayOfWeek":"Th","setpoint":"on","time":0}, {"dayOfWeek":"Fr","setpoint":"on","time":0}, {"dayOfWeek":"Sa","setpoint":"on","time":0}, {"dayOfWeek":"Su","setpoint":"on","time":0} ]
     2:
       0          [HR.Zirkulationspumpe]eq "off"
       1          set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp  [ {"dayOfWeek":"Mo","setpoint":"off","time":0}, {"dayOfWeek":"Tu","setpoint":"off","time":0}, {"dayOfWeek":"We","setpoint":"off","time":0}, {"dayOfWeek":"Th","setpoint":"off","time":0}, {"dayOfWeek":"Fr","setpoint":"off","time":0}, {"dayOfWeek":"Sa","setpoint":"off","time":0}, {"dayOfWeek":"Su","setpoint":"off","time":0} ]
   helper:
     DEVFILTER  ^global$|^HR.Zirkulationspumpe$
     NOTIFYDEV  global|HR.Zirkulationspumpe
     globalinit 1
     last_timer 0
     sleeptimer -1
     timerdev
     timerevent
     timerevents
     timereventsState
     triggerDev
     DOIF_eventa:
       cmd_nr: 1
       cmd: 1
       cmd_event: di.zirkulationspumpe_to_heizkessel
       error: set HR.Heizkessel /dhwCircuits/dhw1/switchPrograms/cp  [{"dayOfWeek":"Mo","setpoint":"on","time":330}, {"dayOfWeek":"Mo","setpoint":"off","time":1380}, {"dayOfWeek":"Tu","setpoint":"on","time":330}, {"dayOfWeek":"Tu","setpoint":"off","time":1380}, {"dayOfWeek":"We","setpoint":"on","time":330}, {"dayOfWeek":"We","setpoint":"off","time":1380}, {"dayOfWeek":"Th","setpoint":"on","time":330}, {"dayOfWeek":"Th","setpoint":"off","time":1380}, {"dayOfWeek":"Fr","setpoint":"on","time":330}, {"dayOfWeek":"Fr","setpoint":"off","time":1380}, {"dayOfWeek":"Sa","setpoint":"on","time":420}, {"dayOfWeek":"Sa","setpoint":"off","time":1320}, {"dayOfWeek":"Su","setpoint":"on","time":420}, {"dayOfWeek":"Su","setpoint":"off","time":1320}]: The service /dhwCircuits/dhw1/switchPrograms/cp has been changed succesfully!
       cmd_1
     DOIF_eventas:
       cmd_nr: 1
       cmd: 1
       state: cmd_1
   internals:
     all         HR.Zirkulationspumpe:STATE
   uiState:
   uiTable:
   group      Heizung
   room       70_Automatisierung
Funktionieren tut es alles wie es sein soll, zumindest habe ich den Eindruck. Nur der Eintrag im Logfile wundert mich.
fhem auf Intel NUC6CAYH mit Proxmox im LXC (Debian 10), KNX mit knxd über MDT SCN-IP000.02, Buderus GB192-15i über KM100, Solaredge WR SE9K über Modbus-TCP
Damian
Fällt dir nichts auf?
EinEinfach
Korrekt?
Damian
Korrekt?
Und beim DOELSEIF fehlt das Leerzeichen:
DOELSEIF ([HR.Zirkulationspumpe] eq "on")
EinEinfach
Dann aber in der ersten Anweisung auch:
Vielen Dank für schnellen Support.
