[GELÖST] HM-TC-IT-WM-W-EU werden beim anlernen nicht erkannt
Begonnen von Burny4600, 30 November 2020, 16:42:12
Burny4600
Neue HM-TC-IT-WM-W-EU Module mit Firmware 1.4 werden beim Anlernen nicht erkannt.
2020.11.30 16:34:06.816 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:06.953 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:06.998 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:07.109 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:07.171 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:07.271 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:07.316 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:07.468 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:07.513 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:07.606 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:07.650 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:07.759 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:07.804 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:07.897 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:07.942 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:08.091 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:08.135 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:08.229 2: CUL_HM Unknown device HM_6AF5F1 is now defined
2020.11.30 16:34:08.273 1: Error: >< has no TYPE, but following keys: >helper<
2020.11.30 16:34:16.332 1: Error: >< has no TYPE, but following keys: >helper<
Gab es für die Homematic Geräte Änderungen für das Anlernen?
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
frank
FHEM: 6.0(SVN) => Pi3(buster)
Burny4600
Danke.
Genau das war es.
Ein dummer Fehler meinerseits.
Ist schon lange aus ein neues Gerät hinzuzufügen.
LG Chris
