ECMD erstellen
Begonnen von ahtdf, 24 Mai 2021, 13:53:44
ahtdf
Hallo kann mir da jemand helfen,
ich habe an einem Arduino_uno einen DHT12 Sensor den ich via USB mit Fhem auslesen möchte.
Da ich leider kein Perl programmieren kann , habe ich mir das aus diesem Wiki Beitrag(https://wiki.fhem.de/wiki/ECMD) herauskopiert.
Aus dem FileLog
  • 2021.05.24 13:41:55 5: Arduino_DHT12: Spontaneously received 123 (\061\062\063)
    2021.05.24 13:41:55 5: Arduino_DHT12: dispatch 123
    2021.05.24 13:41:55 5: Arduino_DHT12: merging partial message 1234 T20.00°C H48.00%RH\r\n (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122\110\015\012) and 123 (\061\062\063)
    2021.05.24 13:41:55 5: Arduino_DHT12: 1234 T20.00°C H48.00%RH\r\n123 (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122\110\015\012\061\062\063) split into 2 parts
    2021.05.24 13:41:55 5: Arduino_DHT12: trying to match message 1234 T20.00°C H48.00%RH\r\n (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122\110\015\012)
    2021.05.24 13:41:55 5: Arduino_DHT12: trying to match message 123 (\061\062\063)
    2021.05.24 13:41:55 5: Arduino_DHT12: partial message 123 (\061\062\063) kept
    2021.05.24 13:41:55 5: Arduino_DHT12: Spontaneously received 4 T20.00 (\064\040\124\062\060\056\060\060)
    2021.05.24 13:41:55 5: Arduino_DHT12: dispatch 4 T20.00
    2021.05.24 13:41:55 5: Arduino_DHT12: merging partial message 123 (\061\062\063) and 4 T20.00 (\064\040\124\062\060\056\060\060)
    2021.05.24 13:41:55 5: Arduino_DHT12: trying to match message 1234 T20.00 (\061\062\063\064\040\124\062\060\056\060\060)
    2021.05.24 13:41:55 5: Arduino_DHT12: partial message 1234 T20.00 (\061\062\063\064\040\124\062\060\056\060\060) kept
    2021.05.24 13:41:55 5: Arduino_DHT12: Spontaneously received °C H48. (\302\260\103\040\110\064\070\056)
    2021.05.24 13:41:55 5: Arduino_DHT12: dispatch °C H48.
    2021.05.24 13:41:55 5: Arduino_DHT12: merging partial message 1234 T20.00 (\061\062\063\064\040\124\062\060\056\060\060) and °C H48. (\302\260\103\040\110\064\070\056)
    2021.05.24 13:41:55 5: Arduino_DHT12: trying to match message 1234 T20.00°C H48. (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056)
    2021.05.24 13:41:55 5: Arduino_DHT12: partial message 1234 T20.00°C H48. (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056) kept
    2021.05.24 13:41:55 5: Arduino_DHT12: Spontaneously received 00%R (\060\060\045\122)
    2021.05.24 13:41:55 5: Arduino_DHT12: dispatch 00%R
    2021.05.24 13:41:55 5: Arduino_DHT12: merging partial message 1234 T20.00°C H48. (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056) and 00%R (\060\060\045\122)
    2021.05.24 13:41:55 5: Arduino_DHT12: trying to match message 1234 T20.00°C H48.00%R (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122)
    2021.05.24 13:41:55 5: Arduino_DHT12: partial message 1234 T20.00°C H48.00%R (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122) kept
    2021.05.24 13:41:55 5: Arduino_DHT12: Spontaneously received H\r\n (\110\015\012)
    2021.05.24 13:41:55 5: Arduino_DHT12: dispatch H\r\n
    2021.05.24 13:41:55 5: Arduino_DHT12: merging partial message 1234 T20.00°C H48.00%R (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122) and H\r\n (\110\015\012)
    2021.05.24 13:41:55 5: Arduino_DHT12: partial message 1234 T20.00°C H48.00%RH\r\n (\061\062\063\064\040\124\062\060\056\060\060\302\260\103\040\110\064\070\056\060\060\045\122\110\015\012) kept
Mein Arduino Sketch sieht so aus
  • //2018.6.28
    #include <dht_nonblocking.h>
    #include <LiquidCrystal.h>
    LiquidCrystal lcd(12, 11, 5, 4, 3, 2 );
    #define DHT_SENSOR_TYPE DHT_TYPE_11
    //#define DHT_SENSOR_TYPE DHT_TYPE_21
    //#define DHT_SENSOR_TYPE DHT_TYPE_22
    static const int DHT_SENSOR_PIN = 8;
    DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
    void setup( ){
    lcd.begin (16, 2);
      Serial.begin( 9600);
    void loop( )
      float temperature;
      float humidity;
      if(dht_sensor.measure(&temperature, &humidity)){
        Serial.print("1234 ");
        Serial.print( "T" );
        Serial.print(temperature);
        Serial.print( "°C " );
        Serial.print( "H" );
        Serial.print(humidity);
        Serial.println( "%RH" );
        delay (5000);
         lcd. clear ();
          lcd. setCursor(0, 0);
          lcd. print ("Temperatur=");
          lcd. print (temperature, 1 );
          lcd. print ( "C" );
          lcd. setCursor(0, 1);
          lcd. print ("Feuchte = ");
          lcd. print (humidity, 1 );
          lcd. print ( " %," );
Und das ist meine classdev
  • params devId1234
    reading temperature match "%devId[^\n]+\n"
    reading temperature postproc { /%devId[^T]+T([-+.,0-9]+).*/; $1 }
    reading humidity match "%devId[^\n]+\n"
    reading humidity postproc { /%devId[^H]+H([-+.,0-9]+).*/; $1 }
    state humidity
Raw Definition
  • defmod Arduino_DHT12 ECMD serial /dev/ttyACM1@9600
    attr Arduino_DHT12 classdefs DHT12=opt/fhem/DHT12.classdef
    attr Arduino_DHT12 partial 200
    attr Arduino_DHT12 room Arduino
    attr Arduino_DHT12 split \r\n
    attr Arduino_DHT12 verbose 5
    setstate Arduino_DHT12 opened
    setstate Arduino_DHT12 2021-05-24 13:38:22 state opened
Und im Eventmonitor
steht ab und an
2021-05-24 13:44:34 ECMD Arduino_DHT12 UNKNOWNCODE
Kann mir da jemand weiterhelfen????
Gruß Arno
