looking for a solution: triggering a zwave signal when a light goes on
Begonnen von HarryT, 24 November 2021, 22:19:38
HarryT
Hi
I have a light which will be triggered by 2 sensors.  I want to generate a zwave signal when the light goes on so I can trigger other lights, connected to a zwave dimmer, to also switch on.
The easiest/cheapest solution I can think of is to place the first light after a zwave switch with power measurement and use the power management as a trigger.
Any better suggestions?
Thanks
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
I assume that the light and the 2 sensors are of traditional type (i.e. not accessible via FHEM).
To notify FHEM (or another dimmer) about "light goes on" I see three possibilities: measure the signal between the sensors and the light, measure the energy change when the light goes on, or measure the light intensity change. Sending the signal to FHEM can be done via different methods like WLAN or ZWave.
Which of the possibilities is the easiest/cheapest, depends on the setting (how are the sensors and the light installed), how you value your time spent on tinkering vs money investment, and if there are design constraints like the changes should not be visible or they must be aeshtetically pleasing.
I would probably go with your suggestion.
