Logeinträge, deren Verursacher nicht ersichtlich sind
Begonnen von vosskam, 28 März 2022, 12:07:58
vosskam
Hallo Zusammen,
ich habe eine Fhem-Installation mit über 100 Aktoren stabil am laufen.
Seit einer Woche versuche ich nach Kräften, das Log aufzuräumen.
Dabei bin ich an einem Punkt angekommen, der mich verzweifeln lässt.
In Anlage die Logs samt Stacktrace, die mich um den Verstand bringen:
2022.03.27 20:32:37 1: PERL WARNING: Argument "12.74 °C" isn't numeric in subtraction (-) at FHEM/TimeSeries.pm line 247.
2022.03.27 20:32:37 1: stacktrace:
2022.03.27 20:32:37 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (247)
2022.03.27 20:32:37 1:     TimeSeries::_updatestat             called by FHEM/TimeSeries.pm (312)
2022.03.27 20:32:37 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 20:32:37 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 20:32:37 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 20:32:37 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 20:32:37 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 20:32:37 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 20:32:37 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 20:32:37 1: PERL WARNING: Argument "12.74 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 20:32:37 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 20:32:37 1: PERL WARNING: Argument "12.74 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 20:32:37 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (354)
2022.03.27 20:47:39 1: PERL WARNING: Argument "12.61 °C" isn't numeric in subtraction (-) at FHEM/TimeSeries.pm line 247.
2022.03.27 20:47:39 1: stacktrace:
2022.03.27 20:47:39 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (247)
2022.03.27 20:47:39 1:     TimeSeries::_updatestat             called by FHEM/TimeSeries.pm (312)
2022.03.27 20:47:39 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 20:47:39 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 20:47:39 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 20:47:39 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 20:47:39 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 20:47:39 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 20:47:39 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 20:47:39 1: PERL WARNING: Argument "12.61 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 20:47:39 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 20:47:39 1: PERL WARNING: Argument "12.61 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 20:47:39 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (354)
2022.03.27 20:54:47 1: PERL WARNING: Argument "11.28 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 20:54:47 1: stacktrace:
2022.03.27 20:54:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 20:54:47 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 20:54:47 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 20:54:47 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 20:54:47 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 20:54:47 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 20:54:47 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 20:54:47 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 20:54:47 1: PERL WARNING: Argument "11.28 °C" isn't numeric in division (/) at FHEM/TimeSeries.pm line 363.
2022.03.27 20:54:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (363)
2022.03.27 21:02:42 1: PERL WARNING: Argument "12.50 °C" isn't numeric in subtraction (-) at FHEM/TimeSeries.pm line 247.
2022.03.27 21:02:42 1: stacktrace:
2022.03.27 21:02:42 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (247)
2022.03.27 21:02:42 1:     TimeSeries::_updatestat             called by FHEM/TimeSeries.pm (312)
2022.03.27 21:02:42 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 21:02:42 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 21:02:42 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 21:02:42 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 21:02:42 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 21:02:42 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 21:02:42 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 21:02:42 1: PERL WARNING: Argument "12.50 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 21:02:42 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 21:02:42 1: PERL WARNING: Argument "12.50 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 21:02:42 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (354)
2022.03.27 21:17:45 1: PERL WARNING: Argument "12.41 °C" isn't numeric in subtraction (-) at FHEM/TimeSeries.pm line 247.
2022.03.27 21:17:45 1: stacktrace:
2022.03.27 21:17:45 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (247)
2022.03.27 21:17:45 1:     TimeSeries::_updatestat             called by FHEM/TimeSeries.pm (312)
2022.03.27 21:17:45 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 21:17:45 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 21:17:45 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 21:17:45 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 21:17:45 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 21:17:45 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 21:17:45 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 21:17:45 1: PERL WARNING: Argument "12.41 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 21:17:45 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 21:17:45 1: PERL WARNING: Argument "12.41 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 21:17:45 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (354)
2022.03.27 21:24:47 1: PERL WARNING: Argument "11.20 °C" isn't numeric in subtraction (-) at FHEM/TimeSeries.pm line 247.
2022.03.27 21:24:47 1: stacktrace:
2022.03.27 21:24:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (247)
2022.03.27 21:24:47 1:     TimeSeries::_updatestat             called by FHEM/TimeSeries.pm (312)
2022.03.27 21:24:47 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 21:24:47 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 21:24:47 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 21:24:47 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 21:24:47 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 21:24:47 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 21:24:47 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 21:24:47 1: PERL WARNING: Argument "11.28 °C" isn't numeric in addition (+) at FHEM/TimeSeries.pm line 249.
2022.03.27 21:24:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (249)
2022.03.27 21:24:47 1: PERL WARNING: Argument "11.20 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 21:24:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 21:24:47 1: PERL WARNING: Argument "11.28 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 21:24:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (354)
2022.03.27 21:24:47 1: PERL WARNING: Argument "11.20 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 21:24:47 1: PERL WARNING: Argument "11.28 °C" isn't numeric in numeric gt (>) at FHEM/TimeSeries.pm line 355.
2022.03.27 21:24:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (355)
2022.03.27 21:32:47 1: PERL WARNING: Argument "12.35 °C" isn't numeric in subtraction (-) at FHEM/TimeSeries.pm line 247.
2022.03.27 21:32:47 1: stacktrace:
2022.03.27 21:32:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (247)
2022.03.27 21:32:47 1:     TimeSeries::_updatestat             called by FHEM/TimeSeries.pm (312)
2022.03.27 21:32:47 1:     TimeSeries::add                     called by fhem.pl (4906)
2022.03.27 21:32:47 1:     main::readingsBulkUpdate            called by ./FHEM/10_KNX.pm (1234)
2022.03.27 21:32:47 1:     main::KNX_Parse                     called by fhem.pl (3967)
2022.03.27 21:32:47 1:     main::Dispatch                      called by ./FHEM/00_TUL.pm (289)
2022.03.27 21:32:47 1:     main::TUL_Parse                     called by ./FHEM/00_TUL.pm (270)
2022.03.27 21:32:47 1:     main::TUL_Read                      called by fhem.pl (3771)
2022.03.27 21:32:47 1:     main::CallFn                        called by fhem.pl (756)
2022.03.27 21:32:47 1: PERL WARNING: Argument "12.35 °C" isn't numeric in sort at FHEM/TimeSeries.pm line 316.
2022.03.27 21:32:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (316)
2022.03.27 21:32:47 1: PERL WARNING: Argument "12.35 °C" isn't numeric in numeric lt (<) at FHEM/TimeSeries.pm line 354.
2022.03.27 21:32:47 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (354)
Der Fehler ist mir völlig klar. Im Laufe der letzten Woche habe ich den Perl-Code an vielen stellen modifiziet, um diesen Logeintrag nicht mehr zu bekommen.
Leider ist für mich überhaupt nicht ersichtlich, welches Ereignis bzw. Notify, AT oder Stateformat zu diesen Logeinträge führen.
Die angegeben Temperaturen kann ich auch keinem Device zuordnen.
Hat jemand aus der Community eine Idee, wie ich den Verursacher der Logs finden kann?
Vorab mal: Wilkommen im Forum :) .
TimeSeries.pm assoziiere ich mit "event-aggregator". Das in Verbindung mit TYPE=KNX und der Temperatur an sich sollte doch einen Verursacher zeigen?
Anscheinend wird da eine Trendaussage aus der gemessenen Temperatur abgeleitet, wobei ggf. die erwartungswidrig eben nicht als "Nummer" angegeben wird, sondern als vorformatierter Text. (Sehr vielleicht paßt es auch in den Kontext von hier: https://forum.fhem.de/index.php/topic,92841.0.html)
erwin
ok, das ist sicher ein KNX-device,
und wie Beta-User schon gesagt hat, vermutlich eines mit event-aggregator...
Also danach suchen:
list TYPE=KNX:FILTER=a:event-aggregator!=
Ich vermute es wird ein dpt9 sein - einfach mal den dpt so umdefinieren, dass KEINE einheit im reading vorkommt....
l.g. erwin
FHEM aktuell auf RaspberryPI Mdl 1-4
Maintainer: 00_KNXIO.pm 10_KNX.pm
User: CUNO2 (868 SLOWRF) - HMS100xx, FS20, FHT, 1-Wire  - 2401(iButton), 18x20, 2406, 2413 (AVR), 2450,..,MQTT2, KNX, SONOFF, mySENSORS,....
Hardware:  Busware ROT, Weinzierl IP731, 1-Wire GW,...
vosskam
Hallo Ihr beiden!
Herzlichen Dank für die Tipps.
Ich habe wieder der Wald vor lauter Bäumen nicht gesehen.
MFG
vosskam
