Hinweis: Perlwarnung in Postme beim Start von fhem
Begonnen von Invers, 11 April 2022, 14:24:49
Invers
022.04.11 14:21:06.056 1: PERL WARNING: Scalar value @args[0] better written as $args[0] at ./FHEM/95_PostMe.pm line 1018.
2022.04.11 14:21:06.057 1: stacktrace:
2022.04.11 14:21:06.057 1:     main::__ANON__                      called by ./FHEM/95_PostMe.pm (1018)
2022.04.11 14:21:06.057 1:     (eval)                              called by fhem.pl (2728)
2022.04.11 14:21:06.057 1:     (eval)                              called by fhem.pl (2727)
2022.04.11 14:21:06.057 1:     main::CommandReload                 called by fhem.pl (2057)
2022.04.11 14:21:06.058 1:     main::LoadModule                    called by fhem.pl (2122)
2022.04.11 14:21:06.058 1:     main::CommandDefine                 called by fhem.pl (1275)
2022.04.11 14:21:06.058 1:     main::AnalyzeCommand                called by fhem.pl (1126)
2022.04.11 14:21:06.058 1:     main::AnalyzeCommandChain           called by configDB.pm (764)
2022.04.11 14:21:06.058 1:     main::_cfgDB_Execute                called by configDB.pm (468)
2022.04.11 14:21:06.058 1:     main::cfgDB_ReadAll                 called by fhem.pl (622)
2022.04.11 14:21:06.061 1: PERL WARNING: Scalar value @args[0] better written as $args[0] at ./FHEM/95_PostMe.pm line 1084.
2022.04.11 14:21:06.062 1: stacktrace:
2022.04.11 14:21:06.062 1:     main::__ANON__                      called by ./FHEM/95_PostMe.pm (1084)
2022.04.11 14:21:06.062 1:     (eval)                              called by fhem.pl (2728)
2022.04.11 14:21:06.062 1:     (eval)                              called by fhem.pl (2727)
2022.04.11 14:21:06.062 1:     main::CommandReload                 called by fhem.pl (2057)
2022.04.11 14:21:06.062 1:     main::LoadModule                    called by fhem.pl (2122)
2022.04.11 14:21:06.062 1:     main::CommandDefine                 called by fhem.pl (1275)
2022.04.11 14:21:06.063 1:     main::AnalyzeCommand                called by fhem.pl (1126)
2022.04.11 14:21:06.063 1:     main::AnalyzeCommandChain           called by configDB.pm (764)
2022.04.11 14:21:06.063 1:     main::_cfgDB_Execute                called by configDB.pm (468)
2022.04.11 14:21:06.063 1:     main::cfgDB_ReadAll                 called by fhem.pl (622)
Prof. Dr. Peter Henning
Zitat von: Prof. Dr. Peter Henning am 15 April 2022, 20:50:43
Nix Neues. Alte Version im SVN.
Dann check doch mal eine neue Version ein, mit der die Warnung nicht mehr auftritt  8)
Steht schon in der Todo-Liste. Allerdings nicht an vorderer Position...
pah
In der Zeit, in der Du die beiden Beiträge hier geschrieben hast, hätte man auch die Perl-Warnungen im Modul beseitigen und die Änderung einchecken können...
:D :D :D
Sicher. Und wenn ich jetzt noch einen Post schreibe, doppelt.
;D
pah
