Shelly Smoke (shellyplussmoke)
Begonnen von enno, 26 Februar 2023, 09:08:31
enno
Moin zusammen,
ich habe hier zwei Shelly Smoke für meinen "Zoo" bekommen. Einen habe ich jetzt mit MQTT in Fhem eingebunden.
Ein List zeigt mir: Internals:
   CID        shellyplussmoke_80646fd06e08
   DEF        shellyplussmoke_80646fd06e08
   FUUID      63f0cfa8-f33f-8a87-1e3f-0020801d6af321f5
   IODev      myBroker
   NAME       KG_HK_Shellyplussmoke
   NR         1217
   STATE      ???
   TYPE       MQTT2_DEVICE
     2023-02-26 08:41:01   IODev           myBroker
     2023-02-25 11:22:21   alarm           false
     2023-02-25 11:22:22   battery_V       2.99
     2023-02-25 11:22:22   battery_percent 97
     2023-02-25 11:22:17   ble             {}
     2023-02-25 11:22:21   cfg_rev         6
     2023-02-25 11:22:17   connected       true
     2023-02-25 11:22:22   dst             shellyplussmoke-80646fd06e08/events
     2023-02-25 11:22:17   errors_1        read
     2023-02-25 11:22:21   fs_free         122880
     2023-02-25 11:22:21   fs_size         458752
     2023-02-25 11:22:22   id              0
     2023-02-25 11:22:21   kvs_rev         0
     2023-02-25 11:22:21   mac             80646FD06E08
     2023-02-25 11:22:22   method          NotifyStatus
     2023-02-25 11:22:21   mute            false
     2023-02-25 11:22:17   online          true
     2023-02-25 11:22:17   params_cloud_connected false
     2023-02-25 11:22:22   params_devicepower_0_battery_V 2.99
     2023-02-25 11:22:22   params_devicepower_0_battery_percent 97
     2023-02-25 11:22:17   params_devicepower_0_errors_1 read
     2023-02-25 11:22:22   params_devicepower_0_id 0
     2023-02-25 11:22:21   params_events_1_component sys
     2023-02-25 11:22:21   params_events_1_event sleep
     2023-02-25 11:22:21   params_events_1_ts 1677320541.96
     2023-02-25 11:22:17   params_mqtt_connected true
     2023-02-25 11:22:21   params_smoke_0_alarm false
     2023-02-25 11:22:17   params_smoke_0_id 0
     2023-02-25 11:22:17   params_smoke_0_mute false
     2023-02-25 11:22:17   params_sys_cfg_rev 6
     2023-02-25 11:22:17   params_sys_fs_free 126976
     2023-02-25 11:22:17   params_sys_fs_size 458752
     2023-02-25 11:22:17   params_sys_kvs_rev 0
     2023-02-25 11:22:17   params_sys_mac  80646FD06E08
     2023-02-25 11:22:17   params_sys_ram_free 167292
     2023-02-25 11:22:17   params_sys_ram_size 236072
     2023-02-25 11:22:17   params_sys_restart_required false
     2023-02-25 11:22:17   params_sys_uptime 1
     2023-02-25 11:22:17   params_sys_wakeup_period 86400
     2023-02-25 11:22:17   params_sys_wakeup_reason_boot poweron
     2023-02-25 11:22:21   params_sys_wakeup_reason_cause status_update
     2023-02-25 11:22:17   params_sys_webhook_rev 0
     2023-02-25 11:22:22   params_ts       1677320542.43
     2023-02-25 11:22:17   params_wifi_rssi -17
     2023-02-25 11:22:17   params_wifi_ssid Sinclair
     2023-02-25 11:22:17   params_wifi_sta_ip 192.168.179.44
     2023-02-25 11:22:17   params_wifi_status got ip
     2023-02-25 11:22:17   params_ws_connected false
     2023-02-25 11:22:21   ram_free        166656
     2023-02-25 11:22:21   ram_size        236032
     2023-02-25 11:22:21   restart_required false
     2023-02-25 11:22:17   rssi            -17
     2023-02-25 11:22:22   src             shellyplussmoke-80646fd06e08
     2023-02-25 11:22:17   ssid            Sinclair
     2023-02-25 11:22:17   sta_ip          192.168.179.44
     2023-02-25 11:22:17   status          got ip
     2023-02-25 11:22:21   time            11:22
     2023-02-25 11:22:21   unixtime        1677320541
     2023-02-25 11:22:21   uptime          5
     2023-02-25 11:22:21   wakeup_period   86400
     2023-02-25 11:22:21   wakeup_reason_boot poweron
     2023-02-25 11:22:21   wakeup_reason_cause status_update
     2023-02-25 11:22:21   webhook_rev     0
   DbLogExclude .*
   event-on-change-reading .*
   icon       secur_smoke_detector
   readingList shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/online:.* online
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/ble:.* ble
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/cloud:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/devicepower_0:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/mqtt:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/smoke_0:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/sys:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/wifi:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/status/ws:.* { json2nameValue($EVENT) }
shellyplussmoke_80646fd06e08:shellyplussmoke-80646fd06e08/events/rpc:.* { json2nameValue($EVENT) }
Leider ist der in der ersten Version angekündigte Feuchtigkeits und Temperatursensor nicht zu sehen.... Sieht jemand eine Möglichkeit den Melder mit FHEM auszulösen, oder nach Alarm abzuschalten?
Gruss
  Enno
Einfacher FHEM Anwender auf Intel®NUC mit Proxmox und Debian
Ralli
Laut der Shelly-API-Dokumentation kannst du den Alarm grds. per http-Request ausschalten:
https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/Smoke
Dass die hier benannte Methode Smoke.Mute auch in MQTT vorhanden ist, ergibt sich aus der Dokumentation leider nicht. Ausprobieren ...
Ralli
Proxmox 9 Cluster mit HP ED800G2i7, Intel NUC11TNHi7+NUC7i5BNH, virtualisiertes fhem 6.4 dev, virtualisierte OpenCCU (3.89.11.20260919) mit HB-RF-ETH 1.3.0 / RPI-RF-MOD, HM-LAN-GW (1.4.1) und HMW-GW, FRITZBOX 7490 (07.62), FBDECT, Siri und Alexa
