[gelöst] Verstehe Fehlermeldung nicht
Begonnen von bommel-bs, 24 April 2023, 10:07:02
bommel-bs
in meiner DOIF erhalte ich folgende Fehlermeldung:
     if ( open ne "open"   and open ne "closed") (         set SchlafZimmer_Rolladen_Tuer pct 100      ): Not enough arguments for open at (eval 310315) line 1, near "open ne"
       if ( open ne "open"  and open ne "closed") (         set SchlafZimmer_Rolladen_Links pct 100      ): Not enough arguments for open at (eval 310318) line 1, near "open ne"
       if ( open ne "open" and open ne "closed") (         set SchlafZimmer_Rolladen_Rechts pct 100      ): Not enough arguments for open at (eval 310321) line 1, near "open ne"
Trotz Fehleremldung funktioniert alles wie gewünscht. Leider komme ich hier nicht weiter.
define di_SchlafZimmer_Rollo DOIF ([({sunrise(0,"08:30", "9:00")}) | 7] and [wech] eq "wech") (\
     set SchlafZimmer_Rolladen_Links pct 100;;\
     set SchlafZimmer_Rolladen_Tuer pct 100;;\
     set SchlafZimmer_Rolladen_Rechts pct 100;;\
DOELSEIF ([({sunrise(0,"07:30", "9:00")}) | 6] and [wech] eq "wech") (\
DOELSEIF ([({sunrise(0,"07:30", "9:00")} ) | AT ]  and [wech] eq "wech") (\
DOELSEIF ([{sunset("CIVIL","0","16:00","22:30")}]) (\
     set SchlafZimmer_Rolladen_Links pct 0;;\
     sleep 5;;\
     set SchlafZimmer_Rolladen_Tuer pct 0;;\
     sleep 5;;\
     set SchlafZimmer_Rolladen_Rechts pct 0;;\
     sleep 10;;\
DOELSEIF ([n_autoRolloOst:Sonne] eq "1" ) (\
     if  ( [SchlafZimmer_Rolladen_Tuer:pct] > 70) (\
        set SchlafZimmer_Rolladen_Tuer pct 70\
     if ( [SchlafZimmer_Rolladen_Links:pct] > 50) (\
        set SchlafZimmer_Rolladen_Links pct 50\
     if ( [SchlafZimmer_Rolladen_Rechts:pct] > 50) (\
        set SchlafZimmer_Rolladen_Rechts pct 50 \
DOELSEIF ([n_autoRolloOst:Sonne] eq "0" and isday() )  (\
     if ( [SchlafZimmer_Rolladen_Tuer] ne "open"   and [SchlafZimmer_Rolladen_Tuer] ne "closed") (\
        set SchlafZimmer_Rolladen_Tuer pct 100\
     if ( [SchlafZimmer_Rolladen_Links] ne "open"  and [SchlafZimmer_Rolladen_Links] ne "closed") (\
        set SchlafZimmer_Rolladen_Links pct 100\
     if ( [SchlafZimmer_Rolladen_Rechts] ne "open" and [SchlafZimmer_Rolladen_Rechts] ne "closed") (\
        set SchlafZimmer_Rolladen_Rechts pct 100\
attr di_SchlafZimmer_Rollo do always
attr di_SchlafZimmer_Rollo room 99_System
attr di_SchlafZimmer_Rollo verbose 4
#   DEF        ([({sunrise(0,"08:30", "9:00")}) | 7] and [wech] eq "wech") (
#     set SchlafZimmer_Rolladen_Links pct 100;
#     set SchlafZimmer_Rolladen_Tuer pct 100;
#     set SchlafZimmer_Rolladen_Rechts pct 100;
#DOELSEIF ([({sunrise(0,"07:30", "9:00")}) | 6] and [wech] eq "wech") (
#DOELSEIF ([({sunrise(0,"07:30", "9:00")} ) | AT ]  and [wech] eq "wech") (
#DOELSEIF ([{sunset("CIVIL","0","16:00","22:30")}]) (
#     set SchlafZimmer_Rolladen_Links pct 0;
#     sleep 5;
#     set SchlafZimmer_Rolladen_Tuer pct 0;
#     sleep 5;
#     set SchlafZimmer_Rolladen_Rechts pct 0;
#     sleep 10;
#DOELSEIF ([n_autoRolloOst:Sonne] eq "1" ) (
#     if  ( [SchlafZimmer_Rolladen_Tuer:pct] > 70) (
#        set SchlafZimmer_Rolladen_Tuer pct 70
#     if ( [SchlafZimmer_Rolladen_Links:pct] > 50) (
#        set SchlafZimmer_Rolladen_Links pct 50
#     if ( [SchlafZimmer_Rolladen_Rechts:pct] > 50) (
#        set SchlafZimmer_Rolladen_Rechts pct 50
#DOELSEIF ([n_autoRolloOst:Sonne] eq "0" and isday() )  (
#     if ( [SchlafZimmer_Rolladen_Tuer] ne "open"   and [SchlafZimmer_Rolladen_Tuer] ne "closed") (
#     if ( [SchlafZimmer_Rolladen_Links] ne "open"  and [SchlafZimmer_Rolladen_Links] ne "closed") (
#     if ( [SchlafZimmer_Rolladen_Rechts] ne "open" and [SchlafZimmer_Rolladen_Rechts] ne "closed") (
#   FUUID      6419ead9-f33f-78f8-f787-cc3b1a2dcfc0b6f3
#   MODEL      FHEM
#   NAME       di_SchlafZimmer_Rollo
#   NOTIFYDEV  global,n_autoRolloOst,wech
#   NR         839
#   NTFY_ORDER 50-di_SchlafZimmer_Rollo
#   STATE      cmd_6
#   TYPE       DOIF
#   VERSION    27262 2023-02-21 19:36:39
#   eventCount 2608
#   READINGS:
#     2023-04-24 10:02:09   Device          n_autoRolloOst
#     2023-04-24 10:02:09   cmd             6
#     2023-04-24 10:02:09   cmd_event       n_autoRolloOst
#     2023-04-24 10:02:09   cmd_nr          6
#     2023-04-24 10:02:09   e_n_autoRolloOst_Sonne 0
#     2023-04-24 10:02:09   error                 if ( open ne "open"   and open ne "closed") (         set SchlafZimmer_Rolladen_Tuer pct 100      ): Not enough arguments for open at (eval 310315) line 1, near "open ne"
#Not enough arguments for open at (eval 310315) line 1, near "open ne"
#       if ( open ne "open"  and open ne "closed") (         set SchlafZimmer_Rolladen_Links pct 100      ): Not enough arguments for open at (eval 310318) line 1, near "open ne"
#Not enough arguments for open at (eval 310318) line 1, near "open ne"
#       if ( open ne "open" and open ne "closed") (         set SchlafZimmer_Rolladen_Rechts pct 100      ): Not enough arguments for open at (eval 310321) line 1, near "open ne"
#Not enough arguments for open at (eval 310321) line 1, near "open ne"
#     2023-04-22 09:17:59   mode            enabled
#     2023-04-24 10:02:09   state           cmd_6
#     2023-04-24 08:30:00   timer_01_c01    25.04.2023 08:30:00|7
#     2023-04-24 07:30:00   timer_02_c02    25.04.2023 07:30:00|6
#     2023-04-24 07:30:00   timer_03_c03    25.04.2023 07:30:00|AT
#     2023-04-23 21:12:39   timer_04_c04    24.04.2023 21:14:32
#   Regex:
#     accu:
#     bar:
#     barAvg:
#     collect:
#     cond:
#       n_autoRolloOst:
#         0:
#         1:
#         2:
#         3:
#         4:
#           Sonne      ^n_autoRolloOst$:^Sonne:
#         5:
#       wech:
#         0:
#           &STATE     ^wech$
#         1:
#           &STATE     ^wech$
#         2:
#           &STATE     ^wech$
#   attr:
#     cmdState:
#     wait:
#     waitdel:
#   condition:
#     0          ::DOIF_time_once($hash,0,$wday,"7") and ::InternalDoIf($hash,'wech','STATE') eq "wech"
#     1          ::DOIF_time_once($hash,1,$wday,"6") and ::InternalDoIf($hash,'wech','STATE') eq "wech"
#     2          ::DOIF_time_once($hash,2,$wday,"AT")  and ::InternalDoIf($hash,'wech','STATE') eq "wech"
#     3          ::DOIF_time_once($hash,3,$wday)
#     4          ::ReadingValDoIf($hash,'n_autoRolloOst','Sonne') eq "1"
#     5          ::ReadingValDoIf($hash,'n_autoRolloOst','Sonne') eq "0" and isday()
#   days:
#     0          7
#     1          6
#     2          AT
#   do:
#     0:
#       0                set SchlafZimmer_Rolladen_Links pct 100;      set SchlafZimmer_Rolladen_Tuer pct 100;      set SchlafZimmer_Rolladen_Rechts pct 100;
#     1:
#     2:
#     3:
#       0                set SchlafZimmer_Rolladen_Links pct 0;      sleep 5;      set SchlafZimmer_Rolladen_Tuer pct 0;      sleep 5;      set SchlafZimmer_Rolladen_Rechts pct 0;      sleep 10;
#     4:
#       0                if  ( [SchlafZimmer_Rolladen_Tuer:pct] > 70) (         set SchlafZimmer_Rolladen_Tuer pct 70      ),      if ( [SchlafZimmer_Rolladen_Links:pct] > 50) (         set SchlafZimmer_Rolladen_Links pct 50      ),      if ( [SchlafZimmer_Rolladen_Rechts:pct] > 50) (         set SchlafZimmer_Rolladen_Rechts pct 50       ),
#     5:
#       0                if ( [SchlafZimmer_Rolladen_Tuer] ne "open"   and [SchlafZimmer_Rolladen_Tuer] ne "closed") (         set SchlafZimmer_Rolladen_Tuer pct 100      ),      if ( [SchlafZimmer_Rolladen_Links] ne "open"  and [SchlafZimmer_Rolladen_Links] ne "closed") (         set SchlafZimmer_Rolladen_Links pct 100      ),      if ( [SchlafZimmer_Rolladen_Rechts] ne "open" and [SchlafZimmer_Rolladen_Rechts] ne "closed") (         set SchlafZimmer_Rolladen_Rechts pct 100      ),
#     6:
#   helper:
#     event      Sonne: 0
#     globalinit 1
#     last_timer 4
#     sleeptimer -1
#     timerdev   n_autoRolloOst
#     timerevent Sonne: 0
#     triggerDev n_autoRolloOst
#     timerevents:
#       Sonne: 0
#     timereventsState:
#       Sonne: 0
#     triggerEvents:
#       Sonne: 0
#     triggerEventsState:
#       Sonne: 0
#   internals:
#     all         wech:STATE
#   interval:
#   intervalfunc:
#   localtime:
#     0          1682404200
#     1          1682400600
#     2          1682400600
#     3          1682363672
#   readings:
#     all         n_autoRolloOst:Sonne
#   realtime:
#     0          08:30:00
#     1          07:30:00
#     2          07:30:00
#     3          21:14:32
#   time:
#     0          ({sunrise(0,"08:30","9:00")})
#     1          ({sunrise(0,"07:30","9:00")})
#     2          ({sunrise(0,"07:30","9:00")})
#     3          {sunset("CIVIL","0","16:00","22:30")}
#   timeCond:
#     0          0
#     1          1
#     2          2
#     3          3
#   timer:
#     0          0
#     1          0
#     2          0
#     3          0
#   timers:
#     0           0
#     1           1
#     2           2
#     3           3
#   trigger:
#   triggertime:
#     1682363672:
#       localtime  1682363672
#       hash:
#     1682400600:
#       localtime  1682400600
#       hash:
#     1682404200:
#       localtime  1682404200
#       hash:
#   uiState:
#   uiTable:
setstate di_SchlafZimmer_Rollo cmd_6
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 Device n_autoRolloOst
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 cmd 6
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 cmd_event n_autoRolloOst
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 cmd_nr 6
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 e_n_autoRolloOst_Sonne 0
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 error       if ( open ne "open"   and open ne "closed") (         set SchlafZimmer_Rolladen_Tuer pct 100      ): Not enough arguments for open at (eval 310315) line 1, near "open ne"\
       if ( open ne "open"  and open ne "closed") (         set SchlafZimmer_Rolladen_Links pct 100      ): Not enough arguments for open at (eval 310318) line 1, near "open ne"\
       if ( open ne "open" and open ne "closed") (         set SchlafZimmer_Rolladen_Rechts pct 100      ): Not enough arguments for open at (eval 310321) line 1, near "open ne"\
setstate di_SchlafZimmer_Rollo 2023-04-22 09:17:59 mode enabled
setstate di_SchlafZimmer_Rollo 2023-04-24 10:02:09 state cmd_6
setstate di_SchlafZimmer_Rollo 2023-04-24 08:30:00 timer_01_c01 25.04.2023 08:30:00|7
setstate di_SchlafZimmer_Rollo 2023-04-24 07:30:00 timer_02_c02 25.04.2023 07:30:00|6
setstate di_SchlafZimmer_Rollo 2023-04-24 07:30:00 timer_03_c03 25.04.2023 07:30:00|AT
setstate di_SchlafZimmer_Rollo 2023-04-23 21:12:39 timer_04_c04 24.04.2023 21:14:32
Danke für eurer Hilfe
Stefan
Damian
Du solltest im FHEM-Modus IF statt if verwenden.
bommel-bs
Hallo Damian,
danke. Jetzt ist die Fehlermeldung nciht mehr vorhanden.
Stefan
