Max with dummy sensor from MQTT
Begonnen von RobinC, 22 Januar 2025, 21:00:30
RobinC
I have several Max rad valves working with FHEM. In two rooms the valves are remote, not in the room. I made this work by using a setpoint of 30°C when I wanted them on.
To improve this I have got some Bluetooth sensors which I have connected to FHEM via MQTT. Is it possible to use the readings from these with the valves?
RobinC
Thankyou,
It's easy to forget about language as my browser translates everything for me.
I've now got something like this (from Wzut via a forum post I found).
My biggest challenge was trying to understand the MQQT2_DEVICE.
I'm now waiting for my CUL queue to clear so I can see if it's all behaving.
