weather sensors not found
Begonnen von HarryT, 30 Juli 2013, 23:18:14
HarryT
Hi
I have 4 new weather sensors. 2 are automatically detected and 2 not.
RFXMNGR sees all 4.
In RFXMNGR I see:
0A520703300E00DD3F0169
Packettype    = TEMP_HUM
subtype       = TH7 - Cresta, TFA TS34C
                channel 1
Sequence nbr  = 3
ID            = 12302
Temperature   = 22,1 °C
Humidity      = 63
Status        = Comfortable
Signal level  = 6
Battery       = OK
0A520703570E00E23F0169
                channel 2
Sequence nbr  = 3
ID            = 22286
Temperature   = 22,6 °C
Humidity      = 63
Signal level  = 6
Battery       = OK
0A520703720E00E33B0179
                channel 3
Sequence nbr  = 3
ID            = 29198
Temperature   = 22,7 °C
Humidity      = 59
Signal level  = 7
Battery       = OK
08500505460000BF69
Packettype    = TEMP
subtype       = TEMP5 - LaCrosse TX3, TX4, TX17
Sequence nbr  = 5
ID            = 17920
Temperature   = 19,1 °C
Signal level  = 6
Battery       = OK
0851010546004E0369
Packettype    = HUM
subtype       = HUM1 - LaCrosse TX3
Sequence nbr  = 5
ID            = 17920
Humidity      = 78
Status        = Wet
Signal level  = 6
Battery       = OK
But in the xmllist only:
        <TRX_WEATHER_LIST>
                <TRX_WEATHER name="TFATS34C_Zolder" state="T: 22.4 H: 65 BAT: ok" sets="" attrs="room group comment alias eventMap userReadings IODev ignore:1,0 do_not_notify:1,0 loglevel:0,1,2,3,4,5,6 event-on-change-reading event-on-update-reading event-min-interval stateFormat devStateIcon devStateStyle icon invertState onOffDevice sortby toggleDevice webCmd">
                        <INT key="CODE" value="TFATS34C_14"/>
                        <INT key="DEF" value="TFATS34C_14"/>
                        <INT key="LASTInputDev" value="TRX_0"/>
                        <INT key="MSGCNT" value="20"/>
                        <INT key="NAME" value="TFATS34C_Zolder"/>
                        <INT key="NR" value="247"/>
                        <INT key="STATE" value="T: 22.4 H: 65 BAT: ok"/>
                        <INT key="TRX_0_MSGCNT" value="20"/>
                        <INT key="TRX_0_RAWMSG" value="0a520701570e00e0410179"/>
                        <INT key="TRX_0_TIME" value="2013-07-30 22:05:10"/>
                        <INT key="TYPE" value="TRX_WEATHER"/>
                        <INT key="IODev" value="TRX_0"/>
                        <ATTR key="room" value="Zolder"/>
                        <STATE key="battery" value="ok" measured="2013-07-30 22:05:10"/>
                        <STATE key="humidity" value="65" measured="2013-07-30 22:05:10"/>
                        <STATE key="state" value="T: 22.4 H: 65 BAT: ok" measured="2013-07-30 22:05:10"/>
                        <STATE key="temperature" value="22.4" measured="2013-07-30 22:05:10"/>
                </TRX_WEATHER>
                <TRX_WEATHER name="TX3TH" state="H: 81 BAT: ok" sets="" attrs="room group comment alias eventMap userReadings IODev ignore:1,0 do_not_notify:1,0 loglevel:0,1,2,3,4,5,6 event-on-change-reading event-on-update-reading event-min-interval stateFormat devStateIcon devStateStyle icon invertState onOffDevice sortby toggleDevice webCmd">
                        <INT key="CODE" value="TX3"/>
                        <INT key="DEF" value="TX3"/>
                        <INT key="MSGCNT" value="14"/>
                        <INT key="NAME" value="TX3TH"/>
                        <INT key="NR" value="243"/>
                        <INT key="STATE" value="H: 81 BAT: ok"/>
                        <INT key="TRX_0_MSGCNT" value="14"/>
                        <INT key="TRX_0_RAWMSG" value="085101014600510379"/>
                        <INT key="TRX_0_TIME" value="2013-07-30 22:04:23"/>
                        <ATTR key="room" value="Buiten"/>
                        <STATE key="battery" value="ok" measured="2013-07-30 22:04:23"/>
                        <STATE key="humidity" value="81" measured="2013-07-30 22:04:23"/>
                        <STATE key="state" value="H: 81 BAT: ok" measured="2013-07-30 22:04:23"/>
                        <STATE key="temperature" value="18.8" measured="2013-07-30 22:04:22"/>
                </TRX_WEATHER>
        </TRX_WEATHER_LIST>
I updated to the latest FHEM software yesterday.
Any ideas about this?
{HT}
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
Willi
Did not see your message til now. Sorry.
To make research easier for me (XML is not really human readable, at least in my case...): Which sensors shown in RFXmngr are not detected?
-- Willi
FHEM@Q600(debian) mit DS9490R (1Wire) | FHEM@Sheevaplug(debian) mit RFXCOM-Receiver(80002), CULv3 & USB-WDE1 | FHEM@odroid mit CULv2 & RFXtrx433
HarryT
Zitat von: Willi schrieb am Mi, 07 August 2013 07:28Did not see your message til now. Sorry.
No problem, the weather is much to hot for looking at sensors :-)
ZitatTo make research easier for me (XML is not really human readable, at least in my case...): Which sensors shown in RFXmngr are not detected?
-- Willi
In RFXMNGR:
channel 1
Sequence nbr = 3
ID = 12302
Humidity = 63
Signal level = 6
Battery = OK
channel 2
Sequence nbr = 3
ID = 22286
Humidity = 63
Signal level = 6
Battery = OK
are not detected by FHEM. The problem might be that 1 sensor is identical as the detected sensor and the other is almost identical (and is detected by rfxmgr as identical). The difference is the channel used so I would expect to see them in FHEM too.
In the mean time 1 of the 2 missing sensors is detected by autodetect, but I have no readings from this sensors.
{HT}
Willi
The channel ID was not calculated correct for TS34C.
I had already developed a fix. See: Link
It was already tested and used by user Icebear.
For whatever reasons, my fixes never found the way to SVN. Very strange. Now they are there (in SVN).
To test is, use the new 46_TRX_WEATHER.pm from SVN:
http://sourceforge.net/p/fhem/code/HEAD/tree/trunk/fhem/FHEM/46_TRX_WEATHER.pm?format=raw
It will be also there tomorrow via update.
As the ID are now set correctly like on RFXmngr, the system may see new devices. So you may have to copy your old logs to the new ones.
Regards
Willi
HarryT
Zitat von: Willi schrieb am Fr, 09 August 2013 20:01The channel ID was not calculated correct for TS34C.
That was my impression too so I updated to the current fhem version.
ZitatFor whatever reasons, my fixes never found the way to SVN. Very strange. Now they are there (in SVN).
It works fine now.
ZitatRegards
Willi
Thanks for your work
{HT}
HarryT
Zitat von: Willi schrieb am Fr, 09 August 2013 20:01To test is, use the new 46_TRX_WEATHER.pm from SVN:
Regards
Willi
Hi Willi
The current version writes 2 entries in the log file at every reading. (once per minute) I guess this was not your intention.
{HT}
Willi
HarryT
Zitat von: Willi schrieb am Di, 13 August 2013 23:17Please show these entries.
For example:
2013.08.13 23:25:22 1: TRX_WEATHER: TFA
2013.08.13 23:25:22 1: TRX_WEATHER: TFA 1
2013.08.13 23:25:25 1: TRX_WEATHER: TFA
2013.08.13 23:25:25 1: TRX_WEATHER: TFA 2
2013.08.13 23:26:01 1: TRX_WEATHER: TFA
2013.08.13 23:26:01 1: TRX_WEATHER: TFA 3
2013.08.13 23:26:05 1: TRX_WEATHER: TFA
2013.08.13 23:26:05 1: TRX_WEATHER: TFA 1
2013.08.13 23:26:10 1: TRX_WEATHER: TFA
2013.08.13 23:26:10 1: TRX_WEATHER: TFA 2
2013.08.13 23:26:48 1: TRX_WEATHER: TFA
2013.08.13 23:26:48 1: TRX_WEATHER: TFA 1
2013.08.13 23:26:49 1: TRX_WEATHER: TFA
2013.08.13 23:26:49 1: TRX_WEATHER: TFA 3
{HT}
Willi
I have now removed this debug logging (fhem.log)
Get the newest 46_TRX_WEATHER.pm from SVN or update FHEM tomorrow (updates from SVN are just done once a day...).
-- Willi
