[Gelöst]Nanocul für Klingel
Begonnen von Sebastian84, 30 Dezember 2025, 10:21:53
Sebastian84
Guten Tag. Nach den Wechsel auf Debian 13 geht meine Funkklingel nicht mehr.
   CMDS
   Clients    :FS20:FHT.*:KS300:USF1000:BS:HMS:FS20V: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:TSSTACKED:STACKABLE:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
   DEF        /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port@38400 1234
   DeviceName /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port@38400
   FHTID      1234
   FUUID      5fa2728b-f33f-cdd4-ca30-1b3fbc286ae096e9
   NAME       nanoCUL
   NR         165
   NR_CMD_LAST_H 2
   PARTIAL
   STATE      disconnected
   TYPE       CUL
   devioNoSTATE 1
   eventCount 2
   initString X21
   MatchList:
     0:FS20V    ^81..(04|0c)..0101a001......00[89a-f]...
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     8:HMS      ^810e04......a001
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     D:CUL_IR   ^I............
     E:CUL_TX   ^TX[A-F0-9]{10}
     F:Revolt   ^r......................$
     G:IT       ^i......
     H:STACKABLE_CC ^\*
     I:UNIRoll  ^[0-9A-F]{5}(B|D|E)
     J:SOMFY    ^Y[r|t|s]:?[A-F0-9]+
     K:CUL_TCM97001 ^s[A-F0-9]+
     L:CUL_REDIRECT ^o+
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2022-01-11 11:45:49   ccconf          freq:868.300MHz bWidth:325KHz rAmpl:42dB sens:4dB
     2025-12-28 11:34:24   cmds            No answer
     2024-06-09 08:00:22   credit10ms      788
     2025-12-30 09:28:04   raw             No answer
     2025-12-30 10:15:50   state           disconnected
     2024-06-09 08:00:14   uptime          0 00:06:12
     2025-12-30 10:00:18   version         No answer
   XMIT_TIME:
     1767085853.36432
     1767085854.53631
   icon       control_building_kg
   rfmode     SlowRF
   room       5_Klingel
Hier aus der Config für usb
[code] Bus=01 Lev=04 Prnt=06 Port=03 Cnt=01 Dev#= 8 Spd=12
ver= 2.00 cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
Vendor=0403 ProdID=6001 Rev= 6.00
Manufacturer=SHK
Product=NANO CUL
SerialNumber=868
#Ifs= 1 Cfg#= 1 Atr=ao MxPwr= 90mA
If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) sub=ff Prot=ff Driver-ftdi_sio
Ad=81(I) Atr=02(BulK) MXPS= 64 IvL=0ms
Ad=02(0) Atr=02(Bulk) MxPS= 64 Ivl=0ms
[/code]
Ich glaube das im Device der Fard für den usb nanocul nicht stimmt, das er auf disconnected steht.
Nobbynews
#1
Was sagt denn
ls -l /dev/serial/by-id ?
Würde fast drauf wetten, dass in der def eine "0" hinter port fehlt.
Zitat/dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0@38400 1234
Edit:
Gerade erst den Screenshot gesehen. Es fehlt die "0" hinter port.
Sebastian84
Hab ich jetzt gemacht. Leider steht immer noch disconnected. Wenn ich das Image von Debain 12 was ich nur geupdatet habe geht es einwandfrei ohne die 0  beim port. Aber das ist ja eine neu instalation von Debain 13.
Evtl ein Rechte-Problem. Füge fhem zur Gruppe plugdev hinzu.
Und immer wieder schön die Anfängerfragen zumüllen,
anstatt in einem passenden Unterforum zu posten... 🤮
Sebastian84
Danke hat damit geklappt.
Diebm Befehle sind dafür
Eingabe in ssh:
sudo usermod -aG plugdev fhem
sudo systemctl restart fhem
Und zur Kontrolle,:
groups fhem
Zitat von: betateilchen am 30 Dezember 2025, 12:40:16Und immer wieder schön die Anfängerfragen zumüllen,
Frage an dich wegen des Debian-Packtages und diesem neuen plugdev-Thema seit Trixie: kannst und magst du das berücksichtigen?
