httpmod und doif die 2.
Begonnen von sash.sc, 01 Februar 2026, 10:28:07
sash.sc
Hallo zusammen.
Ich frage per httpmod die Spritpreise ab. Klappt auch.
Habe mir über den Eventmonitor das doif erzeugen lassen, um mir die Spritpreise per Push aus Handy zu schicken.
DEF        ([":^SuperE10"] <= 1.70)
{my $SE10A=ReadingsVal("AVIA","SuperE10","0");
  my $SE10RE=ReadingsVal("Raiffeisen","SuperE10","0");
  my $SE10PM=ReadingsVal("PM_Raesfeld","SuperE10","0");
  my $SE10WE=ReadingsVal("Westfalen","SuperE10","0");
  fhem ("set pushmsg msg <b>Spritpreise</b> <br> <br>AVIA  E10: $SE10A € <br>PM $SE10PM €<br> Raiff.: E10: $SE10RE €<br>West_Lemb E10 $SE10WE € ''  '' ");;}
DOELSE (set pushmsg msg Pech gehabt)
   FUUID      69512c38-f33f-852e-3143-7d2cd979361dc381
   FVERSION   98_DOIF.pm:0.306590/2025-12-25
   MODEL      FHEM
   NAME       Sprit_push
   NOTIFYDEV  global,.*().*
   NR         720
   NTFY_ORDER 50-Sprit_push
   STATE      cmd_1
   TYPE       DOIF
   VERSION    30659 2025-12-25 12:37:16
   eventCount 67
     2026-02-01 10:14:59   Device          Raiffeisen
     2026-02-01 09:59:03   cmd             1
     2026-02-01 09:59:03   cmd_event       Sprit_push
     2026-02-01 09:59:03   cmd_nr          1
     2026-02-01 09:58:57   mode            enabled
     2026-02-01 09:59:03   state           cmd_1
   Regex:
     accu:
     bar:
     barAvg:
     collect:
     cond:
         0:
           ":^SuperE10" :^SuperE10
   attr:
     cmdState:
     wait:
     waitdel:
   condition:
     0          ::EventDoIf('',$hash,'^SuperE10',0) <= 1.70
   do:
     0:
       0           {my $SE10A=ReadingsVal("AVIA","SuperE10","0");   my $SE10RE=ReadingsVal("Raiffeisen","SuperE10","0");   my $SE10PM=ReadingsVal("PM_Raesfeld","SuperE10","0");   my $SE10WE=ReadingsVal("Westfalen","SuperE10","0");   fhem ("set pushmsg msg <b>Spritpreise</b> <br> <br>AVIA  E10: $SE10A € <br>PM $SE10PM €<br> Raiff.: E10: $SE10RE €<br>West_Lemb E10 $SE10WE € ''  '' ");;}
     1:
       0          set pushmsg msg Pech gehabt
   helper:
     event      SuperE10: 1.749
     globalinit 1
     last_timer 0
     sleeptimer -1
     timerdev   Raiffeisen
     timerevent SuperE10: 1.749
     triggerDev Raiffeisen
     timerevents:
       Diesel: 1.709
       SuperE10: 1.749
       SuperE5: 1.779
     timereventsState:
       Diesel: 1.709
       SuperE10: 1.749
       SuperE5: 1.779
     triggerEvents:
       Diesel: 1.709
       SuperE10: 1.749
       SuperE5: 1.779
     triggerEventsState:
       Diesel: 1.709
       SuperE10: 1.749
       SuperE5: 1.779
   internals:
   readings:
   trigger:
   uiState:
   uiTable:
   checkReadingEvent 1
   checkall   all
   room       Spritpreise
Wenn ich das doif auch Check all setze bekomme ich die Nachrichten. Auch bei cmd1 manuell ausführen klappt es.
Nur im Automatik Modus nicht.
Warum löst das doif nicht aus. Wenn eines der Super E10 readings unter 1,70 € fällt?
Gruß und danke
Sascha
Raspi 4B+ Bullseye ;LaCrosse; HomeMatic; MapleCUL; ZigBee; Signalduino ESP32 ; Shellys; MQTT2; Grafana mit Influxdb
Per
Du fragst ein Event ab, das gibt true oder false zurück. Du kannst aber eine Vorgabe als weiteren Parameter angeben, dann bekommst du den Wert zurück.
sash.sc
Habe es jetzt abgeändert. Habe eigentlich gehofft es ein bisschen einfacher bzw kürzer machen zu können.
Aber so funktioniert es.
[AVIA:SuperE10:d] <= 1.68 or
[Raiffeisen:SuperE10:d] <= 1.68 or
[PM_Raesfeld:SuperE10:d] <=1.68 or
[avia_express:Super E10:d] <=1.68
Per
Zitat von: sash.sc am 01 Februar 2026, 20:20:02Habe eigentlich gehofft es ein bisschen einfacher bzw kürzer machen zu können.
Trigger allgemein:
([#min:"":"E10"] < 1.70)
Liste:
([@:"":"E10":$_< 1.70)
Anzahl:
([#:"":"E10":$_< 1.70)
Wenn du deine Tankstellen Devices mit TS_* oder Tabkstelle_* oder was anderem Sinnvollen benennst, kannst du das in den ersten Term mit einfügen und erzeugst so wesentlich weniger Rechenlast. Um trotzdem an die bisherigen Namen zu kommen, kannst du Alias verwenden:
Oder
([@:a"TS_":"E10":$_< 1.70)
PS: am Handy geschrieben, Code kann Fehler enthalten!
sash.sc
Wann würde diese Definition auslösen?
([@:a"^TS_":SuperE10:$_ < 1.70])
Wenn einer der Werte von 5 Tankstellen unter 1.7 ist?
Gruß sascha
Per
Gar nicht, weil die Variable SuperE10 leer ist. Du suchst den Sting "SuperE10". Und ja, wenn bei einem Device mit "TS_" beginnnend ein Reading, welches "SuperE10" im Namen hat, kleiner als 1.7 ist.
Ich hatte aber extra "E10" gewählt, weil eins deiner Readings "Super E10" hieß.
