Hello World
Begonnen von nesges, 05 März 2015, 21:47:29
nesges
Um mir selbst zu visualisieren, wie das Grundgerüst eines Fhem-Moduls auszusehen hat, habe ich ein klassisches "Hello World" anhand von http://www.fhemwiki.de/wiki/DevelopmentModuleIntro  implementiert. Vielleicht kann ja jemand etwas damit anfangen.
98_Hello.pm:
package main;
use strict;
use warnings;
my %Hello_gets = (
"whatyouwant" => "can't",
"whatyouneed" => "try sometimes",
"satisfaction"  => "no"
sub Hello_Initialize($) {
    my ($hash) = @_;
    $hash->{DefFn}      = 'Hello_Define';
    $hash->{UndefFn}    = 'Hello_Undef';
    $hash->{SetFn}      = 'Hello_Set';
    $hash->{GetFn}      = 'Hello_Get';
    $hash->{AttrFn}     = 'Hello_Attr';
    $hash->{ReadFn}     = 'Hello_Read';
    $hash->{AttrList} =
          "formal:yes,no "
        . $readingFnAttributes;
sub Hello_Define($$) {
    my ($hash, $def) = @_;
    my @param = split('[ \t]+', $def);
    if(int(@param) < 3) {
        return "too few parameters: define <name> Hello <greet>";
    my $hash->{name}  = $param[0];
    my $hash->{greet} = $param[2];
    return undef;
sub Hello_Undef($$) {
    my ($hash, $arg) = @_;
    # nothing to do
    return undef;
sub Hello_Get($@) {
my ($hash, @param) = @_;
return '"get Hello" needs at least one argument' if (int(@param) < 2);
my $name = shift @param;
my $opt = shift @param;
if(!$Hello_gets{$opt}) {
my @cList = keys %Hello_gets;
return "Unknown argument $opt, choose one of " . join(" ", @cList);
if($attr{$name}{formal} eq 'yes') {
    return $Hello_gets{$opt}.', sir';
return $Hello_gets{$opt};
sub Hello_Set($@) {
return '"set Hello" needs at least one argument' if (int(@param) < 2);
my $value = join("", @param);
if(!defined($Hello_gets{$opt})) {
    $hash->{STATE} = $Hello_gets{$opt} = $value;
return "$opt set to $value. Try to get it.";
sub Hello_Attr(@) {
my ($cmd,$name,$attr_name,$attr_value) = @_;
if($cmd eq "set") {
        if($attr_name eq "formal") {
if($attr_value !~ /^yes|no$/) {
    my $err = "Invalid argument $attr_value to $attr_name. Must be yes or no.";
    Log 3, "Hello: ".$err;
    return $err;
} else {
    return "Unknown attr $attr_name";
return undef;
1;
=pod
=begin html
<a name="Hello"></a>
<h3>Hello</h3>
<ul>
    <i>Hello</i> implements the classical "Hello World" as a starting point for module development.
    You may want to copy 98_Hello.pm to start implementing a module of your very own. See
    <a href="http://www.fhemwiki.de/wiki/DevelopmentModuleIntro">DevelopmentModuleIntro</a> for an
    in-depth instruction to your first module.
    <br><br>
    <a name="Hellodefine"></a>
    <b>Define</b>
    <ul>
        <code>define &lt;name&gt; Hello &lt;greet&gt;</code>
        <br><br>
        Example: <code>define HELLO Hello TurnUrRadioOn</code>
        <br><br>
        The "greet" parameter has no further meaning, it just demonstrates
        how to set a so called "Internal" value. See <a href="http://fhem.de/commandref.html#define">commandref#define</a>
        for more info about the define command.
    </ul>
    <br>
    <a name="Helloset"></a>
    <b>Set</b><br>
    <ul>
        <code>set &lt;name&gt; &lt;option&gt; &lt;value&gt;</code>
        <br><br>
        You can <i>set</i> any value to any of the following options. They're just there to
        <i>get</i> them. See <a href="http://fhem.de/commandref.html#set">commandref#set</a>
        for more info about the set command.
        <br><br>
        Options:
        <ul>
              <li><i>satisfaction</i><br>
                  Defaults to "no"</li>
              <li><i>whatyouwant</i><br>
                  Defaults to "can't"</li>
              <li><i>whatyouneed</i><br>
                  Defaults to "try sometimes"</li>
        </ul>
    </ul>
    <br>
    <a name="Helloget"></a>
    <b>Get</b><br>
    <ul>
        <code>get &lt;name&gt; &lt;option&gt;</code>
        <br><br>
        You can <i>get</i> the value of any of the options described in
        <a href="#Helloset">paragraph "Set" above</a>. See
        <a href="http://fhem.de/commandref.html#get">commandref#get</a> for more info about
        the get command.
    </ul>
    <br>
    <a name="Helloattr"></a>
    <b>Attributes</b>
    <ul>
        <code>attr &lt;name&gt; &lt;attribute&gt; &lt;value&gt;</code>
        <br><br>
        See <a href="http://fhem.de/commandref.html#attr">commandref#attr</a> for more info about
        the attr command.
        <br><br>
        <ul>
            <li><i>formal</i> no|yes<br>
                When you set formal to "yes", all output of <i>get</i> will be in a
                more formal language. Default is "no".
            </li>
        </ul>
    </ul>
</ul>
=end html
=cut
hexenmeister
nesges
Berechtigter Einwand, wird ergänzt! :-)
hexenmeister
Ist bei mir eine Art Berufskrankheit ;)
Wuppi68
auch wenn es blöd klingt ...
kannst Du das dann wenn die Doku mit dran hängt auch einchecken?
FHEM unter Proxmox als VM
nesges
Habe noch ein wenig Doku ergänzt.
Einchecken: Gerne! Aber ich glaube es wäre albern nur dafür einen Developer-Account anzulegen. Wenn's jemand von euch zum einchecken übernehmen möchte, bin ich der letzte der etwas dagegen hätte. Kann natürlich ebenso gerne erweitert werden.
fhainz
Meiner Meinung nach gehört das ins Wiki zum DevelopmentModuleIntro Eintrag.
P.A.Trick
Sehe ich auch so! Ich hab's mal hinzugefügt!
http://www.fhemwiki.de/wiki/DevelopmentModuleIntro#.22Hello_World.22_Beispiel
FHEM + Homeassistant - meine HW -> https://www.trinityonline.de/hardware/
