Signalduino und Somfy RTS anlernen
Begonnen von rolf, 12 November 2017, 12:54:32
rolf
Habe jetzt das halbe Wochenende mit Somfy RTS und Signalduino verbracht - aber leider wenig erfolgreich.
Auf einem Raspberry läuft FHEM, angeschlossen ein NanoCul868 (ja, ich weiss nicht optimal für Somfy/RTS) - auf dem NanoCul ist Signalduino geflasht.
List des signalduino-devices:
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:SIGNALduino_un:
   DEF        /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0@57600
   DMSG       nothing
   DevState   initialized
   DeviceName /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0@57600
   FD         12
   LASTDMSG   nothing
   NAME       haduino
   NR         76
   PARTIAL
   STATE      opened
   TIME       1510481833
   TYPE       SIGNALduino
   sendworking 0
   version    V 3.3.1-dev SIGNALduino cc1101 - compiled at Mar 10 2017 22:54:50
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}F[A-Fa-f0-9]{2}(#R[A-F0-9][A-F0-9]){0,1}$
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^u30#.*
     18:FLAMINGO ^P13#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2017-11-12 10:05:48   ITParms         Unsupported command
     2017-11-12 11:32:45   ccconf          freq:433.420MHz bWidth:325KHz rAmpl:42dB sens:4dB  (DataRate:5603.79Baud)
     2017-11-12 12:24:37   ccreg           C3E = 00 84 00 00 00 00 00 00
     2017-11-12 12:37:58   ping            OK
     2017-11-12 11:17:15   state           opened
     2017-11-12 11:17:15   version         V 3.3.1-dev SIGNALduino cc1101 - compiled at Mar 10 2017 22:54:50
   getcmd:
   keepalive:
     ok         1
     retry      0
   mcIdList:
     10
     11
     12
     12.1
     18
     43
     47
     52
     57
     58
   msIdList:
     0
     1
     13
     14
     15
     17
     2
     22
     23
     25
     3
     3.1
     32
     33
     35
     38
     4
     41
     51
     55
     6
     68
     7
     72.1
   muIdList:
     13.1
     16
     20
     21
     24
     26
     27
     28
     29
     30
     31
     34
     36
     37
     39
     40
     44
     44.1
     45
     46
     48
     49
     5
     50
     56
     59
     60
     61
     62
     64
     65
     66
     67
     69
     70
     71
     72
     8
     9
   cc1101_frequency 433.42
   flashCommand avrdude -c arduino -b [BAUDRATE] -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   hardware   nanoCC1101
   room       Z-Technik
Frequenz ist per cc1101_freq fest auf 433.42 eingestellt - Sendeleistung per cc1101_sens auf 4.
Mit den Einstellungen wurden alle 15 Somfy/RTS-Wandtaster im Haus sofort erkannt und per Autocreate angelegt - danach
hab ich Autocreate deaktiviert und dann zusätzliche SOMFY-Devices für die Rolladen angelegt
z.B.
   ADDRESS    46521A
   DEF        46521A
   IODev      haduino
   NAME       HA_Rainer_Rolladen
   NR         56
   STATE      open
   TYPE       SOMFY
   move       stop
   CODE:
     1          46521A
     2017-11-12 11:08:21   enc_key         AC
     2017-11-12 11:35:01   exact           0
     2017-11-11 17:36:42   parsestate      on
     2017-11-12 11:35:01   position        0
     2017-11-12 11:08:21   rolling_code    005C
     2017-11-12 11:35:01   state           open
   IODev      haduino
   devStateIcon open:fts_shutter_10 10:fts_shutter_10 20:fts_shutter_20 30:fts_shutter_30 40:fts_shutter_40 50:fts_shutter_50 60:fts_shutter_60 70:fts_shutter_70 80:fts_shutter_80 90:fts_shutter_90 down:fts_shutter_100 closed:fts_shutter_100
   drive-down-time-to-100 23
   drive-down-time-to-close 27
   drive-up-time-to-100 4
   drive-up-time-to-open 28
   eventMap   on:Zu stop:Stop off:Auf
   room       HA_Rainer
   webCmd     Zu:Stop:Auf
Jetzt das Problem - der Rolladen lernt einfach die FHEM-Device nicht, ich weiss nicht was ich falsch mache...
- ich drücke auf dem Somfy-Wandtaster die Prog-Taste -> der Rolladen quittiert durch zucken
- ich sende im FHEM den Befehl "set xxxxxx prog" - aber nichts passiert, d.h. Rolladen ruckelt nicht und danach funktoniert auch die FHEM-Device nicht
Oft ist es dann auch so das der Somfy-Wandtaster auch nicht mehr funktioniert - neu an den Rolladen angelernt werden muss.
Hab jetzt gefühlt >100 Versuche hinter mir - komme nicht weiter....
Habe mit Verbose 5 auch mal noch mitgeloggt was der signalduino protokolliert wenn ich den Befehl "set xxxxx prog" absetze- eventuell kann
sich das mal jemand anschauen der mehr davon versteht als ich :-)
2017.11.12 11:39:10 3: haduino: setting Verbose to: 5
2017.11.12 11:39:36 4: haduino/msg READ: MC;LL=-1294;LH=1280;SL=-656;SH=639;D=A7272146D05911;C=644;L=56;R=61;
2017.11.12 11:39:36 4: haduino: Found manchester Protocol id 43 clock 644 RSSI -43.5 -> Somfy RTS
2017.11.12 11:39:36 5: haduino: extracted data 10100111001001110010000101000110110100000101100100010001 (bin)
2017.11.12 11:39:36 4: haduino: Somfy bitdata: 10100111001001110010000101000110110100000101100100010001 (56)
2017.11.12 11:39:36 5: haduino Dispatch: YsA7272146D05911, test ungleich: disabled
2017.11.12 11:39:36 5: haduino Dispatch: YsA7272146D05911, -43.5 dB, dispatch
2017.11.12 11:39:36 5: haduino: dispatch YsA7272146D05911
2017.11.12 11:39:36 4: haduino: Somfy RTS preprocessing check: 0 enc: A7272146D05911 dec: A7800667968948
2017.11.12 11:39:36 4: haduino/msg READ: MC;LL=-1296;LH=1285;SL=-649;SH=636;D=A7272146D05911;C=644;L=56;R=61;
2017.11.12 11:39:36 5: haduino Dispatch: YsA7272146D05911, test gleich
2017.11.12 11:39:36 4: haduino Dispatch: YsA7272146D05911, Dropped due to short time or equal msg
2017.11.12 11:39:36 4: haduino/msg READ: MC;LL=-1294;LH=1282;SL=-675;SH=612;D=A7272146D05911;C=643;L=56;R=61;
2017.11.12 11:39:36 4: haduino: Found manchester Protocol id 43 clock 643 RSSI -43.5 -> Somfy RTS
2017.11.12 11:39:36 4: haduino/msg READ: MC;LL=-1295;LH=1279;SL=-656;SH=620;D=539390A3682C888;C=641;L=57;R=61;
2017.11.12 11:39:36 4: haduino: Found manchester Protocol id 43 clock 641 RSSI -43.5 -> Somfy RTS
2017.11.12 11:39:36 5: haduino: extracted data 010100111001001110010000101000110110100000101100100010001000 (bin)
2017.11.12 11:39:36 4: haduino: Somfy bitdata: 010100111001001110010000101000110110100000101100100010001000 (57)
2017.11.12 11:39:36 4: haduino: Somfy bitdata: _10100111001001110010000101000110110100000101100100010001 (56). Bit am Anfang entfernt
2017.11.12 11:39:36 4: haduino/msg READ: MC;LL=-1310;LH=1281;SL=-672;SH=612;D=A7272146D05911;C=645;L=56;R=61;
2017.11.12 11:39:36 4: haduino: Found manchester Protocol id 43 clock 645 RSSI -43.5 -> Somfy RTS
2017.11.12 11:39:38 5: haduino/write: adding to queue sendMsg P43#A12B2B4A500244#R6
2017.11.12 11:39:38 5: haduino: sendmsg msg=P43#A12B2B4A500244#R6
2017.11.12 11:39:38 5: haduino: sendmsg Preparing manchester protocol=43, repeats=0, clock=645 data=A12B2B4A500244
2017.11.12 11:39:38 5: AddSendQueue: haduino: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A; (1)
2017.11.12 11:39:38 4: haduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A;
2017.11.12 11:39:38 5: haduino SW: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A;
2017.11.12 11:39:38 4: haduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A;
2017.11.12 11:39:38 4: haduino/msg READ: write new ccreg  10AB85550A
2017.11.12 11:39:38 4: haduino/msg READ: Received answer (write new ccreg  10AB85550A) for sendraw does not match ^S(R|C|M);
2017.11.12 11:39:38 4: haduino/msg READ: ccreg write back 10AB855700
2017.11.12 11:39:38 4: haduino/msg READ: Received answer (ccreg write back 10AB855700) for sendraw does not match ^S(R|C|M);
2017.11.12 11:39:39 4: haduino/msg READ: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A;
2017.11.12 11:39:39 5: haduino/msg READ: regexp=^S(R|C|M); cmd=sendraw msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A;
2017.11.12 11:39:39 4: haduino/read sendraw answer: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A12B2B4A500244;F=10AB85550A;
2017.11.12 11:39:39 4: haduino/HandleWriteQueue: nothing to send, stopping timer
2017.11.12 11:39:50 4: haduino/keepalive ok, retry = 0
2017.11.12 11:40:43 4: haduino: Calling Getting Attr sub with args: del verbose =
2017.11.12 11:40:43 3: haduino: setting Verbose to:
Liegt es daran das ich einen NanoCul868 verwende - hatte gelesen das es eigentlich mit dem auch funktionieren sollte und bei meinen Tests sitze ich mit meinem Raspi nur 3m neben dem Rolladen.
Über jeden Tip dankbar !!!
Geekom (ubuntu 24.04.2 LTS mit diversen MQTT-Devices (Shelly etc.) + CUNO mit Uniroll/Hoermann + RFXTRX mit TFA + EnOcean mit Eltako + Alexa + Harmony + PV (Solarforecast)
rolf
Nach Umstellung auf einen NANOCUL433 hat jetzt das Anlernen problemlos funktioniert !
