10_IT.pm: On startup setstate entries from fhem.save produce an an "Undefined value" error if an eventMap was defined for an IT-Device. As other modules also do not return errors I Removed the related...
Begonnen von System, 27 Oktober 2014, 16:00:04
System
10_IT.pm: On startup setstate entries from fhem.save produce an an "Undefined value" error if an eventMap was defined for an IT-Device. As other modules also do not return errors I Removed the related code.View Changes
Source: 10_IT.pm: On startup setstate entries from fhem.save produce an an "Undefined value" error if an eventMap was defined for an IT-Device. As other modules also do not return errors I Removed the related...
