Raspberry + HM-CFG-USB + HM-CC-RT-DN
Begonnen von too231, 20 November 2014, 21:15:11
too231
Dank dir schonmal !
Ich habe das ganze in Heizung.Wohnzimmer umbenannt.
Hier die Ausgabe:
   DEF        2EEE4A
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     465
   NAME       Heizung.Wohnzimmer
   NR         22
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 Heizung.Wohnzimmer.Weather
   channel_02 Heizung.Wohnzimmer.Climate
   channel_03 Heizung.Wohnzimmer.WindowsRec
   channel_04 Heizung.Wohnzimmer.Clima
   channel_05 Heizung.Wohnzimmer.ClimaTeam
   channel_06 Heizung.Wohnzimmer.remote
   hmusb_MSGCNT 465
   hmusb_RAWMSG E2EEE4A,0000,03035F7B,FF,FFD9,DD86102EEE4A0000000AA8C7105900
   hmusb_RSSI -39
   hmusb_TIME 2014-11-22 09:32:12
   lastMsg    No:DD - t:10 s:2EEE4A d:000000 0AA8C7105900
   protLastRcv 2014-11-22 09:32:12
   protSnd    119 last_at:2014-11-22 07:38:31
   protState  CMDs_done
   rssi_at_hmusb avg:-42.47 min:-53 max:-35 lst:-39 cnt:465
   rssi_hmusb avg:-45.5 min:-49 max:-42 lst:-42 cnt:2
   Readings:
     2014-11-21 19:31:12   Activity        alive
     2014-11-21 19:47:07   CommandAccepted yes
     2014-11-21 19:31:12   D-firmware      1.3
     2014-11-21 19:31:12   D-serialNr      LEQ0780868
     2014-11-21 19:34:37   PairedTo        0x2CC7F7
     2014-11-21 19:31:05   R-backOnTime    10 s
     2014-11-21 19:31:05   R-btnLock       off
     2014-11-21 19:31:05   R-burstRx       on
     2014-11-21 19:31:05   R-cyclicInfoMsg on
     2014-11-21 19:31:05   R-cyclicInfoMsgDis 0
     2014-11-21 19:31:05   R-globalBtnLock off
     2014-11-21 19:31:05   R-localResDis   off
     2014-11-21 19:31:05   R-lowBatLimitRT 2.1 V
     2014-11-21 19:31:05   R-modusBtnLock  off
     2014-11-21 19:31:05   R-pairCentral   0x2CC7F7
     2014-11-21 19:34:37   RegL_00:          01:01 02:01 09:01 0A:2C 0B:C7 0C:F7 0E:0A 0F:00  11:00 12:15 16:00 18:00 19:00 1A:00 00:00
     2014-11-22 07:38:31   RegL_07:         01:2A 02:22 03:09 04:3D 05:18 06:03 07:00 08:16 09:07 0A:30 0B:00 0C:64 0D:0F 0E:05 0F:00 10:00 11:00 12:09 13:8E 14:44 15:48 16:55 17:08 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:44 2F:48 30:55 31:08 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:44 49:48 4A:54 4B:6C 4C:44 4D:CC 4E:55 4F:08 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:44 63:48 64:54 65:6C 66:44 67:CC 68:55 69:08 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:44 7D:48 7E:54 7F:6C 80:44 81:CC 82:55 83:08 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:44 97:48 98:54 99:6C 9A:44 9B:CC 9C:55 9D:08 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:44 B1:48 B2:54 B3:6C B4:44 B5:CC B6:55 B7:08 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:12 CB:21 CC:2A CD:0F CE:1E CF:1E 00:00
     2014-11-22 09:32:12   actuator        89
     2014-11-21 19:47:08   battery         ok
     2014-11-22 09:32:12   batteryLevel    3.1
     2014-11-22 09:32:12   desired-temp    21.0
     2014-11-22 09:32:12   measured-temp   19.9
     2014-11-22 07:38:31   state           CMDs_done
     2014-11-21 19:31:34   time-request    -
   Helper:
     cSnd       112CC7F72EEE4A86042A
     mId        0095
     rxType     140
     Io:
       newChn     +2EEE4A,00,01,00
       nextSend   1416645132.32629
       prefIO
       rxt        0
       vccu
       p:
         2EEE4A
         00
         01
         00
     Mrssi:
       mNo        DD
       Io:
         hmusb      -37
     Prt:
       bErr       0
       sProc      0
       sleeping   1
       try        1
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmusb:
         avg        -42.47311827957
         cnt        465
         lst        -39
         max        -35
         min        -53
       Hmusb:
         avg        -45.5
         cnt        2
         lst        -42
         max        -42
         min        -49
     Shadowreg:
       RegL_07:
   IODev      hmusb
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_full
   firmware   1.3
   model      HM-CC-RT-DN
   room       Wohnzimmer
   serialNr   LEQ0780868
   subType    thermostat
tpm88
Sieht doch jetzt prima aus. Auch der Weather Channel ist da.
Test FHEM Server on RPi, CUL_HM
Prod FHEM Server on Odroid HC1, HM-USB, JeeLink
Devices: diverse HM, IT1500, 1wire, LaCrosse, MQTT
too231
Ja die Channel sind nun da, aber die Meldungen sind immer noch da
tpm88
Hmm - ich benutze jetzt mal meine Kristallkugen und vermute, Du  meinst folgende Meldungen??
tatefile: Please define ActionDetector first
Please define CUL_HM_HM_CC_RT_DN_2EEE4A_Weather first
Kurz zum Verständnis - während eines HomeMatic Pairing Vorgangs werden in FHEM von autocreate (=> command reference) neue Devices und zugehörige Channels (z.B. Weather) definiert. Diese werden aber nicht automatisch in der fhem.cfg auch gesichert. Das MUSST Du manuell mit "save" machen.
Was passiert sonst? Du machst ein stutdown von FHEM, FHEM sichert vor dem Beenden den Zustand aller Devices in das sog. statefile. Beim Neustart von FHEM bemerkt es, daß es zwar einen Zustand für ein Device im statefile findet, NICHT aber dessen Definition in der fhem.cfg. Daher kommen die Warnungen.
Wenn jetzt alles da ist, kannst Du sie ignorieren - den Weather Channel haben wir ja schon verifiziert. Falls Dir der ActionDectector noch fehlt (Kontrolle: list ActionDetector), kannst Du ihn auch manuell anlegen. Siehe obigen Link ins Wiki.
Tip: Auch wenn Du das FHEM Einsteiger PDF schon einmal gelesen hast - es lohnt sich wirklich, es ein zweites Mal zu lesen NACHDEM man schon einige Experimente mit FHEM hinter sich hat. Dann werden plötzlich Zusammenhänge klar, die man beim ersten Mal überlesen und/oder einfach noch nicht verstanden hat.
Tobias
