Android tasker with webauth protected FHEM
Begonnen von homer, 28 Mai 2013, 00:36:27
homer
Hi All,
I can turn a light on using tasker by issuing the following with HTTP GET:
my_url:my_port/fhem?cmd.LOUNGELIGHT=set%20LOUNGELIGHT%20on
... but only if I turn webauth off in FHEM. I assume I need to pass my username and password in the URL? Can someone please let me know how to do this?
Thanks
Homer
homer
Ok. I've worked out what to do:
username:password@my_url:my_port/fhem?cmd.LOUNGELIGHT=set%20LOUNGELIGHT%20on
homer
Thanks everyone for your help. Joerg, your suggest seems sensible. I'm giving it a try!
Thanks
Homer
forum-merlin
Thanks Homer!
Nice to know how it works if web auth is enabled!
Now I can trigger FHEM commands from my "CRON Server" which controls several devices via shell script from outside.
cu
FHEM 5.8 auf RasPi3; CULv3-868; RFXtrx433; HM-Sec-SC-2; HM-CFG-LAN; HM-LC-Bl1-FM; HM-CC-RT-DN; HM-ES-PMSw1-Pl; HM-LC-Sw4-DR; Hunter Ventile; 8ch Relais; ENIGMA2; ONKYO_AVR; SONOS; Harmony; telegram; HM-PB-6-WM55; GPIO; HM-Sen-MDIR-O; HM-SEC-SD; HM-LC-Dim1L-Pl-3;
