Retiring MAXLAN. which is the best coc \ cul to support pi and Max?
Begonnen von bigmacd, 09 Januar 2015, 07:43:58
bigmacd
I have a ten Max device system.
Finally had enough of MAXLAN's issues.
Please recommend the best replacement for my MAXLAN.
Currently have fhem on raspberry pi.
I could in the future move to fhem on a PC system.
TX
fruit
Are you using the MAX Lan Adapter or Cube? Not that it makes much difference perhaps. Edit: Brain not working, I was confusing with HM :\
I have been running a Cube here for 15 months with only one major problem, this week, it forgot all my devices!
I believe others here have had issues with the Cube though.
I am wondering whether to get a CUL as backup
Feel free to follow up in German if you prefer
bigmacd
Hi Fruit,
Exactly the problem I have had! Lost all the setup. >:(
Are you just using fhem to monitor?
Rince
After fuguring out the right place, my 868MHz Cul is running fine with Max!
chris1284
i dont think that your pc has an gpio header   ;) so you should use an usb-device like CUL / nanoCUL / ohter self-made CUL (http://www.fhemwiki.de/wiki/Selbstbau_CUL).
with a pi module you're not flexible (example: evtl problems with banana pi gpio, not for cubietruck, not for the most pc-systems)
fruit
Zitat von: bigmacd am 10 Januar 2015, 06:36:28
Hi Fruit,
It has only happened to me once. I searched the forum, as much as I'm able, but didn't find any obvious common links to this 'til I got back to 2013
It was easy enough to get everything back - but all at default settings. Yesterday I knocked up a rough script to save all my valve settings ready for next time.
My boiler on/off is controlled using valveposition data from the CUbe, so no Cube, no heating :(
@chris1284 I looked at that link for DIY CUL yesterday, looks interesting and somthing I may try.
Rince
ZitatMy boiler on/off is controlled using valveposition data from the CUbe, so no Cube, no heating :(
No problem to do this with fhem and Cul 868.
Example:
http://forum.fhem.de/index.php/topic,11119.0.html
This might be important!
http://forum.fhem.de/index.php/topic,11624.0.html
fruit
Example:
DIY CUL could be my next project then!
My control is somewhat similar to the first example though spread across a number of dummy thresholds and demand levels, both in 99_myUtils.pm and fhem.cfg.
My house is only small so I work only with total of valvepositions, no per-room priorities.
I have looked at the Temperatur-Scanner many times but what I have works OK, maybe sometime in the future I'll try it.
