[Gelöst]Wert eines Dummys an Device übergebeben
Begonnen von Tommy82, 14 März 2015, 17:03:20
Tommy82
ich habe einen Knob Dummy definiert um die Temperatur meiner Heizungstermostate HM-CC-RT-DN zu steuern.
Das Knob Element sieht so aus:
   NAME       Knob_Gaeste_WC
   NR         282
   STATE      21
   TYPE       dummy
   Readings:
     2015-03-14 16:53:10   state           21
   alias      Gäste WC
   fp_Heizung 233,663,7,,
   group      Knob
   setList    state:knob,min:5,max:30,step:0.5,fgColor:#FF9900,anglearc:180,angleoffset:270,bgcolor:#9999CC,width:250,linecap:round,font:lcars,displayPrevious:true
   webCmd     state
Der HM-CC-RT-DN
   DEF        2237FB04
   NAME       Gaeste_WC_Clima
   NR         94
   STATE      T: 20.2 desired: 19.0 valve: 4
   TYPE       CUL_HM
   chanNo     04
   device     Gaeste_WC
   Readings:
     2014-11-27 11:53:00   R-boostPeriod   5 min
     2014-11-27 11:53:00   R-boostPos      80 %
     2014-12-03 20:13:22   R-btnNoBckLight off
     2014-11-27 11:53:00   R-dayTemp       21 C
     2014-12-03 20:13:22   R-daylightSaveTime on
     2014-12-03 20:13:22   R-decalcTime    11:00
     2014-12-03 20:13:22   R-decalcWeekday Sat
     2014-12-03 20:13:22   R-modePrioManu  all
     2014-12-03 20:13:22   R-modePrioParty all
     2014-11-27 11:53:00   R-nightTemp     17 C
     2014-12-03 20:13:22   R-noMinMax4Manu off
     2014-12-03 20:13:22   R-regAdaptive   on
     2014-12-03 20:13:22   R-reguExtI      15
     2014-12-03 20:13:22   R-reguExtP      30
     2014-12-03 20:13:22   R-reguExtPstart 30
     2014-12-03 20:13:22   R-reguIntI      15
     2014-12-03 20:13:22   R-reguIntP      30
     2014-12-03 20:13:22   R-reguIntPstart 30
     2014-12-03 20:13:22   R-showInfo      time
     2014-12-03 20:13:22   R-showWeekday   off
     2014-12-03 20:13:18   R-sign          off
     2014-11-27 11:53:00   R-tempMax       30.5 C
     2014-11-27 11:53:00   R-tempMin       4.5 C
     2014-12-03 20:13:22   R-tempOffset    0.0K
     2014-11-27 11:53:00   R-valveErrPos   15 %
     2014-11-27 11:53:00   R-valveMaxPos   100 %
     2014-11-27 11:53:00   R-valveOffsetRt 0 %
     2014-12-03 20:13:22   R-winOpnBoost   off
     2014-11-27 11:53:00   R-winOpnDetFall 1.4 K
     2014-12-03 20:13:22   R-winOpnMode    on
     2014-11-27 11:53:00   R-winOpnPeriod  15 min
     2014-11-27 11:53:00   R-winOpnTemp    5 C
     2014-12-03 20:13:22   R_0_tempListSat 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_1_tempListSun 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_2_tempListMon 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_3_tempListTue 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_4_tempListWed 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_5_tempListThu 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_6_tempListFri 05:30 10.0 07:00 15.0 20:30 19.0 24:00 15.0
     2014-12-03 20:13:22   R_tempList_State verified
     2015-03-14 16:58:57   ValvePosition   4
     2015-03-14 16:58:57   boostTime       -
     2015-03-14 16:58:57   controlMode     auto
     2015-03-14 16:58:57   desired-temp    19.0
     2015-03-14 16:58:57   measured-temp   20.2
     2015-03-14 16:58:57   motorErr        ok
     2015-03-14 16:58:57   partyEnd        -
     2015-03-14 16:58:57   partyStart      -
     2015-03-14 16:58:57   partyTemp       -
     2015-03-14 16:58:57   state           T: 20.2 desired: 19.0 valve: 4
   Helper:
     Role:
       chn        1
     Shregr:
       07         00
     Shadowreg:
   expert     1
   group      Heizung
   model      HM-CC-RT-DN
   peerIDs    00000000,
   room       Gäste_WC,Favourites
   tempListTmpl none
und das notify
   CFGFN
   DEF        Knob_Gaeste_WC:state set Gaeste_WC_Clima:desired-temp
   NAME       nt_Temp_Gaeste_WC
   NOTIFYDEV  Knob_Gaeste_WC
   NR         3682
   NTFY_ORDER 50-nt_Temp_Gaeste_WC
   REGEXP     Knob_Gaeste_WC:state
   STATE      active
   TYPE       notify
   Readings:
     2015-03-14 16:52:36   state           active
Allerdings wird das Device nicht geregelt wenn ich das Knob Element verändere.
Was mach ich falsch?
Allnetl Wandtablett mit FTUI
justme1968
du verwendest kein gültiges set. der : muss weg und du musst das event auswerten und im set verwenden. also etwa so: Knob_Gaeste_WC:state set Gaeste_WC_Clima desired_temp $EVENT
mit widgetOverride kannst du den knob auch direkt im device verwenden ohne umweg über einen dummy.
  andre
Tommy82
Hi Andre, das mit dem Knob im Device wäre mir ntürlich noch viel lieber, wie muss ich es definieren?
So hat es nicht geklappt
   DEF        2237FB04
   NR         94
   STATE      T: 19.3 desired: 19.0 valve: 13
   TYPE       CUL_HM
   chanNo     04
   device     Gaeste_WC
   Readings:
     2015-03-14 18:15:14   ValvePosition   13
     2015-03-14 18:15:14   boostTime       -
     2015-03-14 18:15:14   controlMode     auto
     2015-03-14 18:15:14   desired-temp    19.0
     2015-03-14 18:15:14   measured-temp   19.3
     2015-03-14 18:15:14   motorErr        ok
     2015-03-14 18:15:14   partyEnd        -
     2015-03-14 18:15:14   partyStart      -
     2015-03-14 18:15:14   partyTemp       -
     2015-03-14 18:15:14   state           T: 19.3 desired: 19.0 valve: 13
   Helper:
     Role:
       chn        1
     Shregr:
       07         00
     Shadowreg:
   expert     1
   group      Heizung
   model      HM-CC-RT-DN
   peerIDs    00000000,
   tempListTmpl none
   widgetOverride state:knob,min:5,max:30,step:0.5,fgColor:#FF9900,anglearc:180,angleoffset:270,bgcolor:#9999CC,width:250,linecap:round,font:lcars,displayPrevious:true
Auch mit Knob_Gaeste_WC:state set Gaeste_WC_Clima desired_temp $EVENT funktioniert es nicht, kommt aber auch nichts im Log
justme1968
wenn das kommando das du absetzen willst desired_temp heisst dann musst du das im widgetOverride auch angeben und nicht state.
zu der version mit dummy und notify: was steht im event monitor wenn du am knob drehst?
Tommy82
hab jetzt im Device desired-temp gesetzt, und jetzt kommt auch das Knob Elemt, allerdings nicht wie definiert mit min:5 und max:30, sondern 0 bis 100, undauch die Farben stimmen nicht, sind jetzt grün und weiss.
ZitatwidgetOverride desired-temp:knob,min:5,max:30,step:0.5,fgColor:#FF9900,anglearc:180,angleoffset:270,bgcolor:#9999CC,width:250,linecap:round,font:lcars,displayPrevious:true
Der Eventmonitor zeigt
2015-03-14 19:44:44.128 dummy Knob_Gaeste_WC 20.5
2015-03-14 19:44:44.674 dummy Knob_Gaeste_WC 22.5
wenn ich den Knob Dummy betätige
Tommy82
justme1968
ich habe eben noch einen bug in fhemweb gefunden bei dem alle parameter nach dem zweiten : abgeschnitten und ignoriert wurden.
siehe hier: http://forum.fhem.de/index.php/topic,35224.msg275352.html#msg275352
  andre
