Fehler bei Jeelink Clone flashen
Begonnen von Cihan, 13 März 2015, 20:57:14
Cihan
Ich habe mir die aktuelle Ino für der den Jeelink Cloner heruntergeladen. Leider bekomme ich beim Flashen mit der Arduino IDE folgenden Fehler.
Arduino: 1.6.1 (Windows 7), Platine: "Arduino Nano, ATmega328"
LaCrosse-LaCrosseITPlusReader\EMT7110.cpp.o: In function `EMT7110::CrcIsValid(unsigned char*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/EMT7110.cpp:124: multiple definition of `EMT7110::CrcIsValid(unsigned char*)'
EMT7110.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/EMT7110.cpp:124: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/EMT7110.cpp:124: multiple definition of `EMT7110::DecodeFrame(unsigned char*, EMT7110::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/EMT7110.cpp:124: multiple definition of `EMT7110::AnalyzeFrame(unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/EMT7110.cpp:124: multiple definition of `EMT7110::GetFhemDataString(EMT7110::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/EMT7110.cpp:124: multiple definition of `EMT7110::TryHandleData(unsigned char*)'
LaCrosse-LaCrosseITPlusReader\Help.cpp.o: In function `Help::Show()':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/Help.cpp:21: multiple definition of `Help::Show()'
Help.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/Help.cpp:21: first defined here
LaCrosse-LaCrosseITPlusReader\JeeLink.cpp.o: In function `JeeLink::JeeLink()':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/JeeLink.cpp:4: multiple definition of `JeeLink::JeeLink()'
JeeLink.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/JeeLink.cpp:4: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/JeeLink.cpp:4: multiple definition of `JeeLink::SwitchLed(bool)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/JeeLink.cpp:4: multiple definition of `JeeLink::Blink(unsigned char)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/JeeLink.cpp:4: multiple definition of `JeeLink::EnableLED(bool)'
LaCrosse-LaCrosseITPlusReader\LaCrosse.cpp.o: In function `LaCrosse::CalculateCRC(unsigned char*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::CalculateCRC(unsigned char*)'
LaCrosse.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/LaCrosse.cpp:29: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::EncodeFrame(LaCrosse::Frame*, unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::DecodeFrame(unsigned char*, LaCrosse::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::USE_OLD_ID_CALCULATION'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::GetFhemDataString(LaCrosse::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::AnalyzeFrame(unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LaCrosse.cpp:29: multiple definition of `LaCrosse::TryHandleData(unsigned char*)'
LaCrosse-LaCrosseITPlusReader\LevelSenderLib.cpp.o: In function `LevelSenderLib::CalculateCRC(unsigned char*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LevelSenderLib.cpp:171: multiple definition of `LevelSenderLib::CalculateCRC(unsigned char*)'
LevelSenderLib.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/LevelSenderLib.cpp:171: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LevelSenderLib.cpp:171: multiple definition of `LevelSenderLib::DecodeFrame(unsigned char*, LevelSenderLib::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LevelSenderLib.cpp:171: multiple definition of `LevelSenderLib::AnalyzeFrame(unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LevelSenderLib.cpp:171: multiple definition of `LevelSenderLib::EncodeFrame(LevelSenderLib::Frame*, unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LevelSenderLib.cpp:171: multiple definition of `LevelSenderLib::GetFhemDataString(LevelSenderLib::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/LevelSenderLib.cpp:171: multiple definition of `LevelSenderLib::TryHandleData(unsigned char*)'
LaCrosse-LaCrosseITPlusReader\RFMxx.cpp.o: In function `RFMxx::GetPayload(unsigned char*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetPayload(unsigned char*)'
RFMxx.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/RFMxx.cpp:35: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::PayloadIsReady()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::spi8(unsigned char)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::spi16(unsigned short)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::ReadReg(unsigned char)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetByteFromFifo()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::Receive()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::WriteReg(unsigned char, unsigned char)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::SetDataRate(unsigned long)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::SetFrequency(unsigned long)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::EnableTransmitter(bool)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::ClearFifo()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::EnableReceiver(bool)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::PowerDown()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetTemperature()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetRadioType()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetRadioName()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::InitialzeLaCrosse()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::RFMxx(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::SetDebugMode(bool)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetDataRate()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::GetFrequency()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::SendByte(unsigned char)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/RFMxx.cpp:35: multiple definition of `RFMxx::SendArray(unsigned char*, unsigned char)'
LaCrosse-LaCrosseITPlusReader\SensorBase.cpp.o: In function `SensorBase::CalculateCRC(unsigned char*, unsigned char)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/SensorBase.cpp:8: multiple definition of `SensorBase::CalculateCRC(unsigned char*, unsigned char)'
SensorBase.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/SensorBase.cpp:8: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/SensorBase.cpp:8: multiple definition of `SensorBase::SetDebugMode(bool)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/SensorBase.cpp:8: multiple definition of `SensorBase::m_debug'
LaCrosse-LaCrosseITPlusReader\Transmitter.cpp.o: In function `Transmitter::Transmitter(RFMxx*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/Transmitter.cpp:4: multiple definition of `Transmitter::Transmitter(RFMxx*)'
Transmitter.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/Transmitter.cpp:4: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/Transmitter.cpp:4: multiple definition of `Transmitter::Enable(bool)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/Transmitter.cpp:4: multiple definition of `Transmitter::Transmit()'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/Transmitter.cpp:4: multiple definition of `Transmitter::SetParameters(unsigned char, unsigned int, bool, unsigned long, unsigned long)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/Transmitter.cpp:4: multiple definition of `Transmitter::SetValues(float, unsigned char)'
LaCrosse-LaCrosseITPlusReader\TX38IT.cpp.o: In function `TX38IT::CalculateCRC(unsigned char*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/TX38IT.cpp:25: multiple definition of `TX38IT::CalculateCRC(unsigned char*)'
TX38IT.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/TX38IT.cpp:25: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/TX38IT.cpp:25: multiple definition of `TX38IT::EncodeFrame(TX38IT::Frame*, unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/TX38IT.cpp:25: multiple definition of `TX38IT::DecodeFrame(unsigned char*, TX38IT::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/TX38IT.cpp:25: multiple definition of `TX38IT::GetFhemDataString(TX38IT::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/TX38IT.cpp:25: multiple definition of `TX38IT::AnalyzeFrame(unsigned char*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/TX38IT.cpp:25: multiple definition of `TX38IT::TryHandleData(unsigned char*)'
LaCrosse-LaCrosseITPlusReader\WT440XH.cpp.o: In function `WT440XH::CrcIsValid(unsigned char*)':
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/WT440XH.cpp:63: multiple definition of `WT440XH::CrcIsValid(unsigned char*)'
WT440XH.cpp.o:C:\Users\Cihan\AppData\Local\Temp\build5459474324120614887.tmp/WT440XH.cpp:63: first defined here
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/WT440XH.cpp:63: multiple definition of `WT440XH::DecodeFrame(unsigned char*, LaCrosse::Frame*)'
C:\Users\Cihan\Documents\Arduino\libraries\LaCrosse-LaCrosseITPlusReader/WT440XH.cpp:63: multiple definition of `WT440XH::TryHandleData(unsigned char*)'
collect2.exe: error: ld returned 1 exit status
Fehler beim Kompilieren.
  Dieser Report hätte mehr Informationen mit
  "Ausführliche Ausgabe während der Kompilierung"
  aktiviert in Datei > Einstellungen
Was heisst das?
RPi4 Shelly Zigbee
Cihan
Die Library musste importiert werden.
RPi4 Shelly Zigbee
