Can fhem on rpi work with Pi Crust (ex ninjablocks board)
Begonnen von moshel, 14 April 2015, 07:40:33
moshel
Hi all,
My first post!
I have installed fhem yesterday and it went pretty smooth (other than raspebian not liking the repository certificate so had to install manually).
this rpi used to be a ninjablocks system (apparently they deserted the product so it is almost unsupported). the communication to 433 devices was done using a board called picrust (bit to be confused with other picrusts - this one is sold by ninjablocks). it has arduino and transiver on it and hooks to the gpio pins. it worked really well while it worked and I was wondering if any of you knows if it conforms to any protocol or better yet, managed to get it working with fhem
Thanks!
Best regards,
Moshe
