PIONEERAVR: bugfix: set StatusRequest now updates the input names. This is important if you start Fhem when the PioneerAVR is not accessible via network. As soon as the connection is established also ...
Begonnen von System, 21 Mai 2015, 01:00:15
System
PIONEERAVR: bugfix: set StatusRequest now updates the input names. This is important if you start Fhem when the PioneerAVR is not accessible via network. As soon as the connection is established also the input names are rereadView Changes
Source: PIONEERAVR: bugfix: set StatusRequest now updates the input names. This is important if you start Fhem when the PioneerAVR is not accessible via network. As soon as the connection is established also ...
