Update doppelt
Begonnen von SmartFan, 03 August 2015, 20:59:18
SmartFan
Moin Moin,
kann mir jemand erklären warum FHEM plötzlich die File doppelt lädt.
Hier mein Log dazu.
2015-08-03 20:56:12 Global global RMDIR: ./restoreDir/2015-07-29
2015-08-03 20:56:12 Global global UPD FHEM/00_HMLAN.pm
2015-08-03 20:56:13 Global global UPD FHEM/00_SONOS.pm
2015-08-03 20:56:16 Global global UPD FHEM/10_CUL_HM.pm
2015-08-03 20:56:17 Global global UPD FHEM/21_SONOSPLAYER.pm
2015-08-03 20:56:17 Global global UPD FHEM/36_JeeLink.pm
2015-08-03 20:56:17 Global global UPD FHEM/TimeSeries.pm
2015-08-03 20:56:18 Global global UPD FHEM/firmware/JeeLink_LaCrosse.hex
2015-08-03 20:56:18 Global global UPD FHEM/36_JeeLink.pm
2015-08-03 20:56:18 Global global UPD FHEM/lib/openzwave_deviceconfig.xml.gz
2015-08-03 20:56:18 Global global UPD FHEM/TimeSeries.pm
2015-08-03 20:56:18 Global global UPD FHEM/lib/openzwave_manufacturer_specific.xml
2015-08-03 20:56:18 Global global Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015-08-03 20:56:19 Global global UPD FHEM/lib/openzwave_manufacturer_specific.xml
2015-08-03 20:56:19 Global global Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015-08-03 20:56:41 Global global
2015-08-03 20:56:42 Global global
2015-08-03 20:56:42 Global global update finished, "shutdown restart" is needed to activate the changes.
2015-08-03 20:56:42 Global global Please consider using the global attribute sendStatistics
Danke und Gruß
Michael
2x Raspberry Pi2 B+
Enocean Pi
8x Thermokon SR04, SR04PT, SR04PST, 3x SAB02, 1xMD15
dblog
Icinger
Kann ich nicht nachvollziehen:
2015.08.03 21:08:40 1: RMDIR: ./restoreDir/2015-06-23
2015.08.03 21:08:41 1: UPD FHEM/00_HMLAN.pm
2015.08.03 21:08:41 1: UPD FHEM/00_SONOS.pm
2015.08.03 21:08:42 1: UPD FHEM/10_CUL_HM.pm
2015.08.03 21:08:44 1: UPD FHEM/21_SONOSPLAYER.pm
2015.08.03 21:08:44 1: UPD FHEM/36_JeeLink.pm
2015.08.03 21:08:44 1: UPD FHEM/70_PHTV.pm
2015.08.03 21:08:45 1: UPD FHEM/72_FRITZBOX.pm
2015.08.03 21:08:46 1: UPD FHEM/TimeSeries.pm
2015.08.03 21:08:46 1: UPD FHEM/firmware/JeeLink_LaCrosse.hex
2015.08.03 21:08:46 1: UPD FHEM/lib/openzwave_deviceconfig.xml.gz
2015.08.03 21:08:47 1: UPD FHEM/lib/openzwave_manufacturer_specific.xml
2015.08.03 21:08:47 1: Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015.08.03 21:09:20 1:
2015.08.03 21:09:20 1: update finished, "shutdown restart" is needed to activate the changes.
2015.08.03 21:09:23 1: fheminfo server response: ==> ok
lg, Ici
Verwende deine Zeit nicht mit Erklärungen. Die Menschen hören (lesen) nur, was sie hören (lesen) wollen. (c) Paulo Coelho
SmartFan
prima.
auch bei erneuter Update Anfrage kommmt die Meldung doppelt.
2015-08-03 21:20:23 Global global nothing to do...
Michael
2x Raspberry Pi2 B+
Enocean Pi
dblog
chris1284
hin und wieder hat updates seine tage...
nothing to do bekommem ich auch öfter mal doppelt. aber auch beim update sind teils meldungen doppelt
2015.08.04 06:25:40 1: UPD FHEM/00_HMLAN.pm
2015.08.04 06:25:40 1: UPD FHEM/00_SONOS.pm
2015.08.04 06:25:42 1: UPD FHEM/10_CUL_HM.pm
2015.08.04 06:25:42 1: UPD FHEM/21_SONOSPLAYER.pm
2015.08.04 06:25:43 1: UPD FHEM/36_JeeLink.pm
2015.08.04 06:25:43 1: UPD FHEM/10_CUL_HM.pm
2015.08.04 06:25:43 1: UPD FHEM/49_IPCAM.pm
2015.08.04 06:25:43 1: UPD FHEM/70_PHTV.pm
2015.08.04 06:25:44 1: UPD FHEM/72_FRITZBOX.pm
2015.08.04 06:25:44 1: UPD FHEM/21_SONOSPLAYER.pm
2015.08.04 06:25:44 1: UPD FHEM/98_HTTPMOD.pm
2015.08.04 06:25:45 1: UPD FHEM/36_JeeLink.pm
2015.08.04 06:25:45 1: UPD FHEM/98_Modbus.pm
2015.08.04 06:25:45 1: UPD FHEM/70_PHTV.pm
2015.08.04 06:25:45 1: UPD FHEM/98_ModbusAttr.pm
2015.08.04 06:25:46 1: UPD FHEM/HMConfig.pm
2015.08.04 06:25:46 1: UPD FHEM/72_FRITZBOX.pm
2015.08.04 06:25:46 1: UPD FHEM/TimeSeries.pm
2015.08.04 06:25:46 1: UPD FHEM/98_HTTPMOD.pm
2015.08.04 06:25:46 1: UPD FHEM/firmware/JeeLink_LaCrosse.hex
2015.08.04 06:25:47 1: UPD FHEM/98_Modbus.pm
2015.08.04 06:25:47 1: UPD FHEM/98_ModbusAttr.pm
2015.08.04 06:25:47 1: UPD FHEM/lib/openzwave_deviceconfig.xml.gz
2015.08.04 06:25:47 1: UPD FHEM/HMConfig.pm
2015.08.04 06:25:47 1: UPD FHEM/lib/openzwave_manufacturer_specific.xml
2015.08.04 06:25:48 1: UPD www/pgm2/fhemweb_fbcalllist.js
2015.08.04 06:25:48 1: Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015.08.04 06:25:48 1: UPD FHEM/TimeSeries.pm
2015.08.04 06:25:48 1: UPD FHEM/firmware/JeeLink_LaCrosse.hex
2015.08.04 06:25:49 1: UPD FHEM/lib/openzwave_deviceconfig.xml.gz
2015.08.04 06:25:49 1: UPD FHEM/lib/openzwave_manufacturer_specific.xml
2015.08.04 06:25:49 1: UPD www/pgm2/fhemweb_fbcalllist.js
2015.08.04 06:25:50 1: Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015.08.04 06:25:58 1: EN FHEM/00_FHEMduino.pm: Unbalanced ul (1, last line ok: 736)
2015.08.04 06:25:58 1: EN FHEM/14_FHEMduino_HX.pm: No a-tag with name="FHEMduino_HX"
2015.08.04 06:25:58 1: EN FHEM/98_LW12.pm: Unbalanced ul (1, last line ok: 508)
2015.08.04 06:25:58 1: EN FHEM/00_SIGNALduino.pm: Unbalanced ul (1, last line ok: 1529)
2015.08.04 06:25:58 1: *** EN FHEM/14_SIGNALduino_RSL.pm: No document text found
2015.08.04 06:25:58 1: *** EN FHEM/95_WebViewControl.pm: No document text found
2015.08.04 06:25:58 1: *** EN FHEM/32_WifiLight.pm: No document text found
2015.08.04 06:25:58 1: EN FHEM/60_allergy.pm: Unbalanced li (1, last line ok: 279)
2015.08.04 06:25:58 1: EN FHEM/60_allergy.pm: Unbalanced b (-1, last line ok: 259)
2015.08.04 06:25:58 1: *** EN FHEM/01_fronthem.pm: No document text found
2015.08.04 06:25:58 1: *** EN FHEM/31_fronthemDevice.pm: No document text found
2015.08.04 06:25:58 1: EN FHEM/98_websocket.pm: No a-tag with name="websocket"
2015.08.04 06:25:58 1: update finished, "shutdown restart" is needed to activate the changes.
Virsacer
Ja, ist mir letztens auch aufgefallen - hab gerade mal im Log geschaut:
2015.07.26 09:05:19 1: UPD FHEM/10_CUL_HM.pm
2015.07.26 09:05:20 1: Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015.07.26 09:05:21 1: Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015.07.26 09:06:15 1:
2015.07.26 09:06:15 1: update finished, "shutdown restart" is needed to activate the changes.
2015.07.26 09:06:17 1:
2015.07.26 09:06:17 1: update finished, "shutdown restart" is needed to activate the changes.
2015.07.26 09:06:17 1: fheminfo server response: ==> ok
2015.07.26 09:06:19 1: fheminfo server response: ==> ok
Ist aber auch nicht immer - dachte der Fehler sei behoben worden, aber dann kams doch nochmal...
Elektrolurch
Scheint bei mir auch wohl doppelt aufgerufen zu werden.
Nach "update" und der Anzeige der aktualisierten Dateien, kommt dann ein
"nothing to do"
configDB und Windows befreite Zone!
SmartFan
vielen Dank für die Anworten. Dann mache ich eingfach nix und warte bis der "Spuk" wieder vorüber ist.
Gruß Michael
2x Raspberry Pi2 B+
Enocean Pi
dblog
chris1284
oder postest es noch mal im richtigen forum
FHEM/98_update.pm            rudolfkoenig         http://forum.fhem.de Sonstiges
in der maintainer http://fhem.de/MAINTAINER.txt steht immer wer für was wo im forum zu finden ist
