HttpUtils.pm - nach Update Webif nicht erreichbar
Begonnen von Bennemannc, 04 November 2015, 16:47:21
Bennemannc
nach dem Update von heute (16:30) war das Webif nicht mehr erreichbar. Das wiederherstellen der alten HttpUtils.pm hat das Problem behoben. Das ist der Log nach dem Update und dem Restart.
2015.11.04 16:21:48 1: RMDIR: ./restoreDir/2015-10-31
2015.11.04 16:21:48 1: UPD ./CHANGED
2015.11.04 16:21:48 1: UPD ./fhem.pl
2015.11.04 16:21:49 1: UPD FHEM/10_EnOcean.pm
2015.11.04 16:21:52 1: UPD FHEM/20_GUEST.pm
2015.11.04 16:21:53 1: UPD FHEM/20_ROOMMATE.pm
2015.11.04 16:21:53 1: UPD FHEM/33_readingsProxy.pm
2015.11.04 16:21:53 1: UPD FHEM/70_PHTV.pm
2015.11.04 16:21:54 1: UPD FHEM/70_Pushover.pm
2015.11.04 16:21:54 1: UPD FHEM/75_MSG.pm
2015.11.04 16:21:54 1: UPD FHEM/75_msgConfig.pm
2015.11.04 16:21:54 1: UPD FHEM/98_DOIF.pm
2015.11.04 16:21:54 1: UPD FHEM/98_Text2Speech.pm
2015.11.04 16:21:55 1: UPD FHEM/HttpUtils.pm
2015.11.04 16:21:55 1: UPD FHEM/msgSchema.pm
2015.11.04 16:21:56 1: UPD www/images/default/icoMusic.png
2015.11.04 16:21:56 1: UPD www/images/default/icoRollo.png
2015.11.04 16:21:57 1:
2015.11.04 16:21:57 1: New entries in the CHANGED file:
2015.11.04 16:21:57 1:   - change:  ATTENTION: Removed deprecated module 75_MSG.pm. Users will need to
2015.11.04 16:21:57 1:              manually change their device definitions to MSGFile or MSGMail
2015.11.04 16:21:57 1:              respectively.
2015.11.04 16:21:57 1:   - feature: Introduce FHEM message routing by new command 'msg'
2015.11.04 16:21:57 1:   - bugfix:  98_Text2Speech: Google fixed, svox-pico added
2015.11.04 16:21:57 1:   - bugfix:  00_SIGNALduino: Updated Firmware (3.8.1-HF1)
2015.11.04 16:21:57 1:              fixed send raw
2015.11.04 16:21:57 1:   - updated: 74_AMAD: New Mijor Release 0.8.1
2015.11.04 16:21:57 1:   - bugfix:  74_AMAD: fix call statusRequest then screen off is set
2015.11.04 16:21:57 1:                       fix change room then device modify
2015.11.04 16:21:57 1:   - feature: 74_AMAD: insert first code parts of voice input
2015.11.04 16:21:57 1:   - change:  55_GDS.pm new version released, see forum ,,Announcements"
2015.11.04 16:21:57 1:   - change:  fhem_codemirror.js: Enabled indentWithTabs by default
2015.11.04 16:21:57 1:                                  Enabled autoCloseBrackets by default
2015.11.04 16:21:57 1:                                  Disabled smartIndent by default
2015.11.04 16:21:57 1:   - bugfix:  74_AMAD: wrong flowset xml file on lib/
2015.11.04 16:21:57 1:   - updated: 74_AMAD: New Major Release 0.8.0
2015.11.04 16:21:57 1:                       !!! IMPORTANT: please forget to update the Flowset !!!
2015.11.04 16:21:57 1:   - feature: 74_AMAD: AMADCommBridge (AMADCommunication Device)
2015.11.04 16:21:57 1:                       toggle between to BT Devices, clear Notificationbar
2015.11.04 16:21:57 1:                       (Automagic,All), play Notify Soundfile (WallClock),
2015.11.04 16:21:57 1:                       check for a activ task on the tablet/phone
2015.11.04 16:21:57 1:   - bugfix:  74_AMAD:  improved error handling
2015.11.04 16:21:57 1:   - bugfix:  70_PIONEERAVR: fixed the decoding for the reading "display".
2015.11.04 16:21:57 1:   - feature: 93_DbLog: Added support for longpoll SVG.
2015.11.04 16:21:57 1:   - feature: contrib/98_openweathermap.pm - add support for stationByZip.
2015.11.04 16:21:57 1: ... rest of lines skipped.
2015.11.04 16:21:57 1: Calling perl ./contrib/commandref_join.pl, this may take a while
2015.11.04 16:21:57 1: PERL WARNING: Use of uninitialized value $ret in split at ./FHEM/98_update.pm line 280.
2015.11.04 16:21:57 1: update finished, "shutdown restart" is needed to activate the changes.
2015.11.04 16:22:07 1: fheminfo server response: ==> ok
2015.11.04 16:22:33 0: Server shutdown
2015.11.04 16:23:24 1: Including fhem.cfg
Subroutine CompassPoint redefined at ./FHEM/99_myUtils.pm line 8, <$fh> line 8.
Subroutine WindChill redefined at ./FHEM/99_myUtils.pm line 50, <$fh> line 8.
2015.11.04 16:23:25 3: telnetPort: port 7072 opened
2015.11.04 16:23:25 1: reload: Error:Modul 01_FHEMWEB deactivated:
Type of arg 1 to keys must be hash or array (not hash element) at FHEM/HttpUtils.pm line 246, near "})"
Compilation failed in require at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 27.
BEGIN failed--compilation aborted at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 27.
2015.11.04 16:23:25 0: Type of arg 1 to keys must be hash or array (not hash element) at FHEM/HttpUtils.pm line 246, near "})"
Attempt to reload HttpUtils.pm aborted.
Compilation failed in require at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 39.
BEGIN failed--compilation aborted at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 39.
2015.11.04 16:23:25 0: Attempt to reload HttpUtils.pm aborted.
Compilation failed in require at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 44.
BEGIN failed--compilation aborted at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 44.
Compilation failed in require at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 58.
BEGIN failed--compilation aborted at ./FHEM/01_FHEMWEB.pm line 8, <$fh> line 58.
2015.11.04 16:23:25 1: HMLAN_Parse: HMLAN1 new condition disconnected
2015.11.04 16:23:25 3: Opening HMLAN1 device 192.168.10.25:1000
2015.11.04 16:23:25 3: HMLAN1 device opened
2015.11.04 16:23:25 1: HMLAN_Parse: HMLAN1 new condition init
2015.11.04 16:23:25 3: Opening PANStick device /dev/ttyUSB0
2015.11.04 16:23:25 3: Setting PANStick serial parameters to 38400,8,N,1
2015.11.04 16:23:25 3: PANStick device opened
2015.11.04 16:23:29 1: Including Fritzbox.cfg
2015.11.04 16:23:29 1: reload: Error:Modul 72_FB_CALLMONITOR deactivated:
Compilation failed in require at ./FHEM/72_FB_CALLMONITOR.pm line 35, <> line 4.
BEGIN failed--compilation aborted at ./FHEM/72_FB_CALLMONITOR.pm line 35, <> line 4.
2015.11.04 16:23:29 0: Attempt to reload HttpUtils.pm aborted.
2015.11.04 16:23:30 1: Including Schalter.cfg
2015.11.04 16:23:32 3: additional HM config file loaded: ./FHEM/HMConfig_SenTHPL.pm
2015.11.04 16:23:34 1: Including Funktaster.cfg
2015.11.04 16:23:34 1: Including Thermostate.cfg
2015.11.04 16:23:36 1: Including Rollos.cfg
2015.11.04 16:23:37 1: Including Fernbedienungen.cfg
2015.11.04 16:23:38 1: Including Fensterkontakte.cfg
2015.11.04 16:23:39 1: Including Virtual.cfg
2015.11.04 16:23:40 1: Including THPL_Sensors.cfg
2015.11.04 16:23:41 1: Including Steuerung.cfg
2015.11.04 16:23:45 2: eventTypes: loaded 4238 events from ./log/eventTypes.txt
could not find ParserDetails.ini in /var/media/ftp/JetFlash-Transcend4GB-01/fhem/lib/perl5/site_perl/5.12.2/XML/SAX
2015.11.04 16:23:48 3: SWAP_F1: I/O device is PANStick
2015.11.04 16:23:49 3: SWAP_F2: I/O device is PANStick
2015.11.04 16:23:49 1: reload: Error:Modul 95_Dashboard deactivated:
Global symbol "$FW_sp" requires explicit package name at ./FHEM/95_Dashboard.pm line 239, <$fh> line 283.
BEGIN not safe after errors--compilation aborted at ./FHEM/95_Dashboard.pm line 825, <$fh> line 283.
2015.11.04 16:23:49 0: Global symbol "$FW_sp" requires explicit package name at ./FHEM/95_Dashboard.pm line 239, <$fh> line 283.
Subroutine Dashboard_Initialize redefined at ./FHEM/95_Dashboard.pm line 122, <$fh> line 423.
Subroutine Dashboard_DetailFN redefined at ./FHEM/95_Dashboard.pm line 183, <$fh> line 423.
Subroutine Dashboard_Set redefined at ./FHEM/95_Dashboard.pm line 199, <$fh> line 423.
Subroutine Dashboard_Escape redefined at ./FHEM/95_Dashboard.pm line 213, <$fh> line 423.
2015.11.04 16:23:51 1: reload: Error:Modul 95_Dashboard deactivated:
Global symbol "$FW_sp" requires explicit package name at ./FHEM/95_Dashboard.pm line 239, <$fh> line 423.
BEGIN not safe after errors--compilation aborted at ./FHEM/95_Dashboard.pm line 825, <$fh> line 423.
2015.11.04 16:23:51 0: Global symbol "$FW_sp" requires explicit package name at ./FHEM/95_Dashboard.pm line 239, <$fh> line 423.
2015.11.04 16:23:53 1: define Telefonliste FB_CALLLIST Callmon: FB_CALLLIST_define: the selected device Callmon does not exist.
2015.11.04 16:23:54 1: Including ./log/fhem.save
2015.11.04 16:24:06 1: configfile: Cannot load module FHEMWEB
Cannot load module FB_CALLMONITOR
Cannot load module Dashboard
FB_CALLLIST_define: the selected device Callmon does not exist.statefile: Please define Callmon first
Please define InfoDash first
Please define MY_DASH first
2015.11.04 16:24:07 3: Device CombiOutdoorSensor added to ActionDetector with 000:10 time
2015.11.04 16:24:07 1: rain_notify: no values for calculation found!
2015.11.04 16:24:08 3: Device Display_WDC7000 added to ActionDetector with 000:10 time
2015.11.04 16:24:08 3: Device Fensterkontakt_01 added to ActionDetector with 028:00 time
2015.11.04 16:24:08 3: Device Fensterkontakt_02 added to ActionDetector with 028:00 time
2015.11.04 16:24:08 3: Device Fensterkontakt_03 added to ActionDetector with 028:00 time
2015.11.04 16:24:08 3: Device Fensterkontakt_04 added to ActionDetector with 028:00 time
2015.11.04 16:24:08 3: Device Fensterkontakt_05 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_06 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_07 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_08 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_09 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_10 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_11 added to ActionDetector with 028:00 time
2015.11.04 16:24:09 3: Device Fensterkontakt_12 added to ActionDetector with 000:50 time
2015.11.04 16:24:09 3: Device Fensterkontakt_13 added to ActionDetector with 028:00 time
2015.11.04 16:24:10 3: Device Fensterkontakt_14 added to ActionDetector with 028:00 time
2015.11.04 16:24:10 3: Device HM_379E3F added to ActionDetector with 000:10 time
2015.11.04 16:24:12 3: Device Schaltsteckdose_1 added to ActionDetector with 000:10 time
2015.11.04 16:24:13 3: Device Temp_1 added to ActionDetector with 000:10 time
2015.11.04 16:24:13 3: Device Temp_2 added to ActionDetector with 000:10 time
2015.11.04 16:24:14 3: Device Thermostat_1 added to ActionDetector with 000:10 time
2015.11.04 16:24:14 3: Device Thermostat_2 added to ActionDetector with 000:10 time
2015.11.04 16:24:14 3: Device Thermostat_3 added to ActionDetector with 000:10 time
2015.11.04 16:24:14 3: Device Thermostat_3.1 added to ActionDetector with 028:00 time
2015.11.04 16:24:15 3: Device Thermostat_3.2 added to ActionDetector with 028:00 time
2015.11.04 16:24:15 3: Device Thermostat_3.3 added to ActionDetector with 028:00 time
2015.11.04 16:24:15 3: Device Thermostat_4 added to ActionDetector with 000:10 time
2015.11.04 16:24:15 3: Device Thermostat_5 added to ActionDetector with 000:10 time
2015.11.04 16:24:16 3: Device Thermostat_6 added to ActionDetector with 000:10 time
2015.11.04 16:24:16 3: Device Thermostat_6.1 added to ActionDetector with 028:00 time
2015.11.04 16:24:16 3: Device Thermostat_6.2 added to ActionDetector with 028:00 time
2015.11.04 16:24:16 3: Device Thermostat_7 added to ActionDetector with 000:10 time
2015.11.04 16:24:16 3: Device Thermostat_7.1 added to ActionDetector with 028:00 time
2015.11.04 16:24:17 3: Device Thermostat_8 added to ActionDetector with 000:10 time
2015.11.04 16:24:17 3: Device Thermostat_8.1 added to ActionDetector with 028:00 time
2015.11.04 16:24:17 3: Device Thermostat_9 added to ActionDetector with 000:10 time
2015.11.04 16:24:18 3: Device Weather_1 added to ActionDetector with 000:10 time
2015.11.04 16:24:19 3: Device Weather_2 added to ActionDetector with 000:10 time
2015.11.04 16:24:19 2: Error messages while initializing FHEM: configfile: Cannot load module FHEMWEB Cannot load module FHEMWEB Cannot load module FHEMWEB Cannot load module FHEMWEB Cannot load module FB_CALLMONITOR Cannot load module Dashboard Cannot load module Dashboard FB_CALLLIST_define: the selected device Callmon does not exist.statefile: Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define Callmon first Please define InfoDash first Please define InfoDash first Please define MY_DASH first Please define MY_DASH first
2015.11.04 16:24:19 0: Featurelevel: 5.6
2015.11.04 16:24:19 0: Server started with 334 defined entities (version $Id: fhem.pl 9755 2015-11-02 19:34:14Z rudolfkoenig $, os linux, user fhem, pid 14251)
2015.11.04 16:24:20 3: CUL_HM set Thermostat_3 statusRequest
2015.11.04 16:24:20 3: CUL_HM set Thermostat_8 statusRequest
2015.11.04 16:24:21 1: HMLAN_Parse: HMLAN1 new condition ok
2015.11.04 16:24:21 3: CUL_HM set 1_CH_PLATINE_01 statusRequest
2015.11.04 16:24:23 3: CUL_HM set 4_CH_PLATINE_02_Sw_01 statusRequest
2015.11.04 16:24:24 3: CUL_HM set 4_CH_PLATINE_02_Sw_02 statusRequest
2015.11.04 16:24:25 3: CUL_HM set 4_CH_PLATINE_02_Sw_03 statusRequest
2015.11.04 16:24:26 3: CUL_HM set 4_CH_PLATINE_02_Sw_04 statusRequest
2015.11.04 16:24:27 3: CUL_HM set Dimmer_LED_Sw statusRequest
2015.11.04 16:24:28 3: CUL_HM set Dimmer_LED_Sw1_V_01 statusRequest
2015.11.04 16:24:29 3: CUL_HM set Dimmer_LED_Sw1_V_02 statusRequest
2015.11.04 16:24:30 3: CUL_HM set Lichtschalter_01 statusRequest
2015.11.04 16:24:31 3: CUL_HM set Lichtschalter_02 statusRequest
2015.11.04 16:24:32 3: CUL_HM set Lichtschalter_03 statusRequest
2015.11.04 16:24:33 3: CUL_HM set Lichtschalter_04_Sw_01 statusRequest
2015.11.04 16:24:34 3: CUL_HM set Lichtschalter_04_Sw_02 statusRequest
2015.11.04 16:24:35 3: CUL_HM set Lichtschalter_05 statusRequest
2015.11.04 16:24:36 3: CUL_HM set Anzeige_Led_11 led green
2015.11.04 16:24:36 3: CUL_HM set Rollo_01 statusRequest
2015.11.04 16:24:37 3: CUL_HM set Rollo_02 statusRequest
2015.11.04 16:24:38 3: CUL_HM set Rollo_03 statusRequest
2015.11.04 16:24:39 3: CUL_HM set Rollo_04 statusRequest
2015.11.04 16:24:40 3: CUL_HM set Rollo_05 statusRequest
2015.11.04 16:24:41 3: CUL_HM set Schaltsteckdose_1_Sw statusRequest
2015.11.04 16:24:42 3: CUL_HM set WIGA_SCHALTER_1_Sw_01 statusRequest
2015.11.04 16:24:44 3: CUL_HM set WIGA_SCHALTER_1_Sw_02 statusRequest
2015.11.04 16:24:45 3: CUL_HM set WIGA_SCHALTER_2_Sw_01 statusRequest
2015.11.04 16:24:46 3: CUL_HM set WIGA_SCHALTER_2_Sw_02 statusRequest
2015.11.04 16:24:56 3: CUL_HM set Thermostat_7 statusRequest
2015.11.04 16:25:08 3: CUL_HM set Thermostat_6 statusRequest
2015.11.04 16:27:42 1: PERL WARNING: Subroutine CompassPoint redefined at ./FHEM/99_myUtils.pm line 8.
2015.11.04 16:27:42 1: PERL WARNING: Subroutine WindChill redefined at ./FHEM/99_myUtils.pm line 50.
2015.11.04 16:27:42 1: Including fhem.cfg
2015.11.04 16:27:42 1: PERL WARNING: Subroutine CompassPoint redefined at ./FHEM/99_myUtils.pm line 8, <$fh> line 8.
2015.11.04 16:27:42 1: PERL WARNING: Subroutine WindChill redefined at ./FHEM/99_myUtils.pm line 50, <$fh> line 8.
2015.11.04 16:27:42 3: telnetPort: port 7072 opened
2015.11.04 16:27:42 1: reload: Error:Modul 01_FHEMWEB deactivated:
Gruß Christoph
Cubietruck, Fhem 5.8
justme1968
