featurelevel 5.7
Begonnen von fruit, 16 November 2015, 19:36:03
fruit
I updated this morning but saw errors so restored and looked over my config but cannot see anything obvious - possibly looking too hard :(
So, I updated again this evening but still see the same errors
define Heating_Changes_notify notify .*([Mm]ode|[Pp]ower[Oo]n|[Hh]eating[Tt]hreshold|[Vv]alve[Pp]osition).* {\
valve_pos( ReadingsVal( "HeatingThreshold", "state", 50 ) );;\
my $valve = 0;;\
my @@pos = ( );;\
my $demand = 0;;\
my @@Max_HT = devspec2array( "DEF=HeatingThermostat.*" );;\
foreach( @@Max_HT ) \
  $valve = ReadingsVal( $_, "valveposition", 101 );;\
  push( @@pos, $valve );;\
  $demand = $demand + $valve;;\
fhem "set Demand $demand";;\
   DEF        .*([Mm]ode|[Pp]ower[Oo]n|[Hh]eating[Tt]hreshold|[Vv]alve[Pp]osition).* {
my $valve = 0;
my @@pos = ( );
my $demand = 0;
foreach( @@Max_HT )
   NAME       Heating_Changes_notify
   NR         753
   NTFY_ORDER 50-Heating_Changes_notify
   REGEXP     .*([Mm]ode|[Pp]ower[Oo]n|[Hh]eating[Tt]hreshold|[Vv]alve[Pp]osition).*
   STATE      2015-11-16 18:29:18
   TYPE       notify
   Readings:
     2015-11-16 18:07:19   state           active
   room       Heat_Control
syntax error at (eval 1249) line 12, at EOF
syntax error at (eval 1249) line 10, near "@@pos"
syntax error at (eval 1249) line 7, near "@@Max_HT "
syntax error at (eval 1249) line 6, near "@@Max_HT "
Can't use global @@ in "my" at (eval 1249) line 6, near "my @@"
syntax error at (eval 1249) line 4, near "@@pos"
2015.11.16 18:09:59 3: Heating_Changes_notify return value: Can't use global @@ in "my" at (eval 1249) line 4, near "my @@"
foreach( @@Max_HT )
my $demand = 0;
my @@pos = ( );
my $valve = 0;
2015.11.16 18:09:59 3: eval: {
2015.11.16 18:09:59 1: PERL WARNING: Bareword found where operator expected at (eval 1249) line 7, near "@@Max_HT"
foreach( @@Max_HT )
my $demand = 0;
my @@pos = ( );
my $valve = 0;
2015.11.16 18:09:59 1: PERL WARNING: Bareword found where operator expected at (eval 1249) line 6, near "@@Max_HT"
foreach( @@Max_HT )
my $demand = 0;
my @@pos = ( );
my $valve = 0;
2015.11.16 18:09:59 1: PERL WARNING: "state" variable @@ masks earlier declaration in same scope at (eval 1249) line 6.
I guess it does not like the @@ but what is the alternative in this situation?
Feel free to follow up in German if you prefer
dev0
With featurelevel 5.7 and above you have to use @ instead of @@. Please have a look at commandref and search for "deprecated".
fruit
I wondered if that was the case, I even changed them after restore but got errors so changed back.
I should have tried before the restore :(
Many thanks
hobu
Just ran in this issue as well.
After using the workaround "attr global featurelevel 5.6" at least my skript (similar to your one) was working again.
Obviously not the final solution...
Anyway: Thx to dev0 for the hint to this in the commandref.
Raspberry Pi (Model B)
HM-CFG-USB, HM-CC-RT-DN, HM-LC-SW1-FM, HM-Dis-WM55, HM-FK-SCO
fruit
The problem is that if you edit the script ready for 5.7 while running 5.6 it errors
Best is to try and disable it or alter from the def window then copy back a suitably modified script after update
