massenweise Fehlereinträge im log
Begonnen von Syntaxterror, 15 Dezember 2015, 21:57:04
Syntaxterror
bei mir läuft das log seit geraumer Zeit unendlich hiermit voll:
2015.12.15 21:38:14 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:38:15 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:38:25 1: PERL WARNING: Use of uninitialized value in hash element at fhem.pl line 1410.
2015.12.15 21:38:34 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:38:50 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:38:52 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:38:56 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:00 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:07 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:10 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:12 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:18 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:27 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:45 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:39:53 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:40:00 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:40:02 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:40:11 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:40:21 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:40:35 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:40:55 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:05 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:11 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:14 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:15 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:16 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:18 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:25 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:50 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:41:57 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:05 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:13 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:15 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:17 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:19 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:26 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:33 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:42:59 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:17 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:19 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:20 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:22 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:25 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:37 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:43:39 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:00 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:12 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:21 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:22 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:23 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:25 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:42 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:44:48 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:45:02 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:45:23 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:45:25 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:45:27 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:45:29 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 21:45:31 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
dann kommt
2015.12.15 19:03:13 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 19:03:33 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
2015.12.15 19:03:42 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/01_FHEMWEB.pm line 1460.
2015.12.15 19:03:42 1: Error:
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
has no TYPE
und weiter gehts mit
... PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4475.
Kennt einer das Phänomen ?
FHEM5.7produktiv Pi3+Pi2,CUL868,CUL433,ser2net,DS2482 mit ca.30Sensoren/Aktoren, ca.100xHomematic,Gertboard+GPIO, 10xLaCrosse
marvin78
Um heraus zu finden, welches Modul oder welche Funktion diese Warnung (nicht Fehler) verursacht, könntest du stacktrace anschalten.
