FHEM Update
Begonnen von jeep, 03 Januar 2016, 09:58:40
jeep
seit einiger Zeit habe ich bei jedem Update am Ende immer die folgenden Meldungen:
2016-01-03 09:40:05 Global global   - feature: PHILIPS_AUDIO: Favorite station selection
2016-01-03 09:40:05 Global global   - feature: YAMAHA_AVR: new set commands and readings for tuner control
2016-01-03 09:40:05 Global global ... rest of lines skipped.
2016-01-03 09:40:05 Global global Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2016-01-03 09:41:00 Global global EN FHEM/95_Alarm.pm: Unbalanced tr (-1, last line ok: 856)
2016-01-03 09:41:00 Global global EN FHEM/57_Calendar.pm: Unbalanced table (-3, last line ok: 1259)
2016-01-03 09:41:00 Global global EN FHEM/00_MAXLAN.pm: Unbalanced tr (1, last line ok: 868)
2016-01-03 09:41:00 Global global EN FHEM/00_MAXLAN.pm: Unbalanced td (1, last line ok: 868)
2016-01-03 09:41:00 Global global EN FHEM/45_Plugwise.pm: Unbalanced tr (1, last line ok: 1372)
2016-01-03 09:41:00 Global global EN FHEM/45_Plugwise.pm: Unbalanced td (1, last line ok: 1372)
2016-01-03 09:41:00 Global global EN FHEM/40_RFXCOM.pm: Unbalanced tr (1, last line ok: 381)
2016-01-03 09:41:00 Global global EN FHEM/40_RFXCOM.pm: Unbalanced td (1, last line ok: 381)
2016-01-03 09:41:00 Global global EN FHEM/51_RPI_GPIO.pm: Unbalanced table (-4, last line ok: 705)
2016-01-03 09:41:00 Global global EN FHEM/42_SYSMON.pm: Unbalanced table (-1, last line ok: 5074)
2016-01-03 09:41:00 Global global EN FHEM/42_SYSMON.pm: Unbalanced td (-66, last line ok: 4982)
2016-01-03 09:41:00 Global global EN FHEM/45_TRX.pm: Unbalanced tr (1, last line ok: 411)
2016-01-03 09:41:00 Global global EN FHEM/45_TRX.pm: Unbalanced td (1, last line ok: 411)
2016-01-03 09:41:00 Global global EN FHEM/73_km200.pm: Unbalanced td (-28, last line ok: 2985)
2016-01-03 09:41:00 Global global EN FHEM/95_remotecontrol.pm: Unbalanced td (-1, last line ok: 409)
2016-01-03 09:41:00 Global global DE FHEM/57_Calendar.pm: Unbalanced table (-3, last line ok: 1465)
2016-01-03 09:41:00 Global global DE FHEM/98_HMinfo.pm: Unbalanced tr (1, last line ok: 2888)
2016-01-03 09:41:00 Global global DE FHEM/98_HMinfo.pm: Unbalanced td (1, last line ok: 2888)
2016-01-03 09:41:00 Global global DE FHEM/51_RPI_GPIO.pm: Unbalanced table (-4, last line ok: 898)
2016-01-03 09:41:00 Global global DE FHEM/42_SYSMON.pm: Unbalanced table (-1, last line ok: 5736)
2016-01-03 09:41:00 Global global DE FHEM/42_SYSMON.pm: Unbalanced td (-66, last line ok: 5644)
2016-01-03 09:41:00 Global global DE FHEM/73_km200.pm: Unbalanced td (-28, last line ok: 3176)
2016-01-03 09:41:00 Global global DE FHEM/95_remotecontrol.pm: Unbalanced td (-1, last line ok: 495)
2016-01-03 09:41:00 Global global update finished, "shutdown restart" is needed to activate the changes.
Könnte mich nicht erinnern dass es die schon immer gab.
Vielleicht kann mich jemand aufklären.
Besten Dank und noch ein gutes Neues Jahr!
Grüße,
Josef
Ein wenig HomeMatic
RPi2  - UZB1, FHEM Testsystem - 8 devices
HC2  - 72 devices  (95 % sind Fibaro devices)
krikan
Wenn Du die lokale commandref auf Deinem fhem vielleicht gar nicht benötigst, kannst Du auch einfach
attr global exclude_from_update commandref
setzen und die Meldungen verschwinden.
jeep
Danke Euch für die schnellen Antworten. Ja alles kein Problem. Hätte die Zeile
Zitat2016-01-03 09:40:05 Global global Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
mehr beachten sollen.
Als Anfänger schaue ich natürlich schon recht oft in die commandref.
Grüße,
Josef
Ein wenig HomeMatic
