Perfmon freeze
Begonnen von stgeran, 02 Januar 2016, 20:59:45
stgeran
Ich habe
2016.01.02 12:47:49 1: Cannot fork: Nicht genügend Hauptspeicher verfügbar
2016.01.02 12:47:49 1: Perfmon: possible freeze starting at 12:45:55, delay is 114.678
2016.01.02 12:56:21 1: 192.168.100.110:1000 disconnected, waiting to reappear (HMLAN1)
2016.01.02 12:56:21 1: HMLAN_Parse: HMLAN1 new condition disconnected
2016.01.02 12:56:54 1: Perfmon: possible freeze starting at 12:47:50, delay is 544.782
2016.01.02 12:56:57 1: 192.168.100.110:1000 reappeared (HMLAN1)
2016.01.02 12:56:57 1: HMLAN_Parse: HMLAN1 new condition init
2016.01.02 12:56:57 1: Perfmon: possible freeze starting at 12:56:55, delay is 2.358
2016.01.02 12:56:57 1: HMLAN_Parse: HMLAN1 new condition ok
2016.01.02 13:01:36 1: Perfmon: possible freeze starting at 13:01:35, delay is 1.113
2016.01.02 13:06:48 1: Perfmon: possible freeze starting at 13:06:47, delay is 1.449
2016.01.02 13:12:20 1: Perfmon: possible freeze starting at 13:12:19, delay is 1.836
2016.01.02 13:12:57 1: Perfmon: possible freeze starting at 13:12:56, delay is 1.685
2016.01.02 13:30:31 1: Perfmon: possible freeze starting at 13:30:30, delay is 1.026
2016.01.02 14:12:25 1: Perfmon: possible freeze starting at 14:12:24, delay is 1.035
2016.01.02 14:18:26 1: Perfmon: possible freeze starting at 14:18:25, delay is 1.165
2016.01.02 14:22:19 1: Perfmon: possible freeze starting at 14:22:14, delay is 5.04
2016.01.02 14:34:46 1: Perfmon: possible freeze starting at 14:34:45, delay is 1.306
2016.01.02 15:14:58 1: Perfmon: possible freeze starting at 15:14:56, delay is 2.083
2016.01.02 15:16:53 1: Perfmon: possible freeze starting at 15:16:52, delay is 1.143
2016.01.02 15:33:59 1: Perfmon: possible freeze starting at 15:33:57, delay is 2.058
2016.01.02 15:35:58 1: Perfmon: possible freeze starting at 15:35:57, delay is 1.478
2016.01.02 15:48:31 1: Perfmon: possible freeze starting at 15:48:30, delay is 1.186
2016.01.02 16:00:14 1: Perfmon: possible freeze starting at 16:00:13, delay is 1.394
2016.01.02 16:08:10 1: Perfmon: possible freeze starting at 16:08:09, delay is 1.497
2016.01.02 16:22:36 1: Perfmon: possible freeze starting at 16:22:34, delay is 2.043
2016.01.02 16:32:23 1: Perfmon: possible freeze starting at 16:32:22, delay is 1.609
2016.01.02 16:47:38 1: Perfmon: possible freeze starting at 16:47:37, delay is 1.343
2016.01.02 17:27:03 1: Perfmon: possible freeze starting at 17:27:02, delay is 1.259
2016.01.02 18:07:07 1: Perfmon: possible freeze starting at 18:07:06, delay is 1.151
2016.01.02 18:52:06 1: Perfmon: possible freeze starting at 18:52:05, delay is 1.309
2016.01.02 19:00:00 3: CUL_HM set Vent_K on
2016.01.02 19:08:59 1: Perfmon: possible freeze starting at 19:08:58, delay is 1.135
2016.01.02 19:30:00 3: CUL_HM set Roll_Buegel 25
2016.01.02 19:42:05 1: Perfmon: possible freeze starting at 19:42:04, delay is 1.225
2016.01.02 19:55:00 1: Perfmon: possible freeze starting at 19:54:59, delay is 1.456
2016.01.02 20:00:00 3: CUL_HM set Vent_K off
wie kann ich eingrenzen was das verursacht?
Und was verursacht den "Hauptspeicherfehler"?
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
LuckyDay
hast ein paar langweiler drin, :)
hat aber nichts mit homematic zu tun
stell
attr global verbose 5
attr global mseclog 1
und dann siehst du wer aufruft,
edit: verschieben kannst du selber ;)
stgeran
Zu Sicherheit: Deine zwei Befehle gebe ich die in die Befehlszeile ein oder soll ich die in die cfg einbinden.
Und wohin verschieben bez. wie? So fit bin ich im forum nicht
FHEM auf Raspberry
LuckyDay
#3
ZitatZu Sicherheit: Deine zwei Befehle gebe ich die in die Befehlszeile ein oder soll ich die in die cfg einbinden.
ja, auch, oder im Webif unter unsorted global die attribute setzen, und dann save
dass sollte doch nach der Zeit im Forum bei dir doch auch kar sein
edit für mseclog brauch man einen shutdown restart zur aktivierung , soweit ich es noch weis
stgeran
Gesagt getan.
Das logfile erschlägt mich jetzt. Nach was soll ich suchen?
FHEM auf Raspberry
