PERL WARNING: Argument "57b" isn't numeric in addition (+) at /usr/share/fhem/FH
Begonnen von JoWiemann, 30 Dezember 2015, 11:57:07
JoWiemann
habe beim Anlernen eines MAX Fensterkontakt folgendes Stracktrace bekommen:
14_CUL_MAX.pm 10168 2015-12-13 22:55:58Z mgehre
2015.12.30 12:08:32 3:     main::CallFn                        called by /usr/share/fhem/fhem.pl (661)
2015.12.30 12:08:32 3:     main::CUL_Read                      called by /usr/share/fhem/fhem.pl (3194)
2015.12.30 12:08:32 3:     main::CUL_Parse                     called by /usr/share/fhem/FHEM/00_CUL.pm (796)
2015.12.30 12:08:32 3:     main::Dispatch                      called by /usr/share/fhem/FHEM/00_CUL.pm (938)
2015.12.30 12:08:32 3:     main::CUL_MAX_Parse                 called by /usr/share/fhem/fhem.pl (3353)
2015.12.30 12:08:32 3:     main::__ANON__                      called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (317)
2015.12.30 12:08:32 3: stacktrace:
2015.12.30 12:08:32 1: PERL WARNING: Use of uninitialized value in string eq at /usr/share/fhem/FHEM/14_CUL_MAX.pm line 317.
2015.12.30 12:08:32 3: cm: Unknown code MAX,1,Ack,11afb8,0112, help me!
2015.12.30 12:08:31 1: readingsUpdate(,RSSI,-80.5) missed to call readingsBeginUpdate first.
2015.12.30 12:08:31 3:     main::CallFn                        called by /usr/share/fhem/fhem.pl (661)
2015.12.30 12:08:31 3:     main::CUL_Read                      called by /usr/share/fhem/fhem.pl (3194)
2015.12.30 12:08:31 3:     main::CUL_Parse                     called by /usr/share/fhem/FHEM/00_CUL.pm (796)
2015.12.30 12:08:31 3:     main::Dispatch                      called by /usr/share/fhem/FHEM/00_CUL.pm (938)
2015.12.30 12:08:31 3:     main::CUL_MAX_Parse                 called by /usr/share/fhem/fhem.pl (3353)
2015.12.30 12:08:31 3:     main::Dispatch                      called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (303)
2015.12.30 12:08:31 3:     main::MAX_Parse                     called by /usr/share/fhem/fhem.pl (3370)
2015.12.30 12:08:31 3:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (881)
2015.12.30 12:08:31 3:     main::__ANON__                      called by /usr/share/fhem/fhem.pl (4011)
2015.12.30 12:08:31 3: stacktrace:
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at /usr/share/fhem/fhem.pl line 4011.
2015.12.30 12:08:31 1: readingsUpdate(,state,waiting for data) missed to call readingsBeginUpdate first.
2015.12.30 12:08:31 3:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (880)
2015.12.30 12:08:31 2: MAX_Parse: Don't know how to interpret Ack payload for
2015.12.30 12:08:31 3:     main::__ANON__                      called by /usr/share/fhem/FHEM/10_MAX.pm (850)
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at /usr/share/fhem/FHEM/10_MAX.pm line 850.
2015.12.30 12:08:31 3:     main::__ANON__                      called by /usr/share/fhem/FHEM/10_MAX.pm (839)
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value in string eq at /usr/share/fhem/FHEM/10_MAX.pm line 847.
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value in string eq at /usr/share/fhem/FHEM/10_MAX.pm line 845.
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value in string eq at /usr/share/fhem/FHEM/10_MAX.pm line 843.
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value in string eq at /usr/share/fhem/FHEM/10_MAX.pm line 841.
2015.12.30 12:08:31 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at /usr/share/fhem/FHEM/10_MAX.pm line 839.
2015.12.30 12:08:31 3:     main::readingsBeginUpdate           called by /usr/share/fhem/FHEM/10_MAX.pm (642)
2015.12.30 12:08:31 1: ERROR: empty name in readingsBeginUpdate
2015.12.30 12:08:31 3:     main::MAX_Parse                     called by /usr/share/fhem/fhem.pl (3353)
2015.12.30 12:08:30 3:     main::CallFn                        called by /usr/share/fhem/fhem.pl (661)
2015.12.30 12:08:30 3:     main::CUL_Read                      called by /usr/share/fhem/fhem.pl (3194)
2015.12.30 12:08:30 3:     main::CUL_Parse                     called by /usr/share/fhem/FHEM/00_CUL.pm (796)
2015.12.30 12:08:30 3:     main::Dispatch                      called by /usr/share/fhem/FHEM/00_CUL.pm (938)
2015.12.30 12:08:30 3:     main::CUL_MAX_Parse                 called by /usr/share/fhem/fhem.pl (3353)
2015.12.30 12:08:30 3:     main::CUL_MAX_Send                  called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (368)
2015.12.30 12:08:30 3:     main::CUL_MAX_SendQueueHandler      called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (433)
2015.12.30 12:08:30 3:     main::CUL_MAX_Check                 called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (499)
2015.12.30 12:08:30 3:     main::__ANON__                      called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (145)
2015.12.30 12:08:30 3: stacktrace:
2015.12.30 12:08:30 1: PERL WARNING: Argument "57b" isn't numeric in addition (+) at /usr/share/fhem/FHEM/14_CUL_MAX.pm line 145.
2015.12.30 12:08:30 3: CUL_MAX_Parse: Pairing device 11afb8 of type ShutterContact with serial MEQ0380423
Beim define erhalte ich dann: MAX_Define: Device with addr 11afb8 is already defined
Grüße Jörg
Jörg Wiemann
SirUli
Habe das gleiche Problem beim Anlernen von Thermostaten nach einem Batteriewechsel:
2016.01.09 13:07:30 3: CUL_MAX_Parse: Re-Pairing device 014c4f of type HeatingThermostat with serial JEQ0333392
2016.01.09 13:07:30 1: ERROR: empty name in readingsBeginUpdate
2016.01.09 13:07:30 3: stacktrace:
2016.01.09 13:07:30 3:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2016.01.09 13:07:30 3:     main::MAX_Parse                     called by fhem.pl (3360)
2016.01.09 13:07:30 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (356)
2016.01.09 13:07:30 3:     main::CUL_MAX_Parse                 called by fhem.pl (3360)
2016.01.09 13:07:30 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (939)
2016.01.09 13:07:30 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (797)
2016.01.09 13:07:30 3:     main::CUL_Read                      called by fhem.pl (3201)
2016.01.09 13:07:30 3:     main::CallFn                        called by fhem.pl (661)
2016.01.09 13:07:30 1: Device changed type from  to HeatingThermostat
2016.01.09 13:07:30 1: readingsUpdate(,groupid,0) missed to call readingsBeginUpdate first.
2016.01.09 13:07:30 1: readingsUpdate(,state,waiting for data (rf error)) missed to call readingsBeginUpdate first.
2016.01.09 13:07:30 1: readingsUpdate(,RSSI,-81.5) missed to call readingsBeginUpdate first.
2016.01.09 13:07:30 3:     main::MAX_Parse                     called by fhem.pl (3377)
2016.01.09 13:07:30 3: mc: Unknown code MAX,1,define,014c4f,HeatingThermostat,JEQ0333392,0, help me!
2016.01.09 13:07:30 3:     main::readingsBeginUpdate           called by ./FHEM/14_CUL_MAX.pm (361)
2016.01.09 13:07:30 1: readingsUpdate(,firmware,1.6) missed to call readingsBeginUpdate first.
2016.01.09 13:07:30 1: readingsUpdate(,testresult,255) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: ERROR: empty name in readingsBeginUpdate
2016.01.09 13:07:33 3: stacktrace:
2016.01.09 13:07:33 3:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2016.01.09 13:07:33 3:     main::MAX_Parse                     called by fhem.pl (3360)
2016.01.09 13:07:33 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (297)
2016.01.09 13:07:33 3:     main::CUL_MAX_Parse                 called by fhem.pl (3360)
2016.01.09 13:07:33 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (939)
2016.01.09 13:07:33 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (797)
2016.01.09 13:07:33 3:     main::CUL_Read                      called by fhem.pl (3201)
2016.01.09 13:07:33 3:     main::CallFn                        called by fhem.pl (661)
2016.01.09 13:07:33 1: readingsUpdate(,mode,manual) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: readingsUpdate(,battery,ok) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: readingsUpdate(,desiredTemperature,20.5) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: readingsUpdate(,temperature,20.9) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: readingsUpdate(,valveposition,0) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: readingsUpdate(,state,waiting for data) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 1: readingsUpdate(,RSSI,-67) missed to call readingsBeginUpdate first.
2016.01.09 13:07:33 3:     main::MAX_Parse                     called by fhem.pl (3377)
2016.01.09 13:07:33 3: mc: Unknown code MAX,0,ThermostatState,017632,19002900D1, help me!
2016.01.09 13:07:36 1: ERROR: empty name in readingsBeginUpdate
2016.01.09 13:07:36 3: stacktrace:
2016.01.09 13:07:36 3:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2016.01.09 13:07:36 3:     main::MAX_Parse                     called by fhem.pl (3360)
2016.01.09 13:07:36 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (297)
2016.01.09 13:07:36 3:     main::CUL_MAX_Parse                 called by fhem.pl (3360)
2016.01.09 13:07:36 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (939)
2016.01.09 13:07:36 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (797)
2016.01.09 13:07:36 3:     main::CUL_Read                      called by fhem.pl (3201)
2016.01.09 13:07:36 3:     main::CallFn                        called by fhem.pl (661)
2016.01.09 13:07:36 1: readingsUpdate(,mode,manual) missed to call readingsBeginUpdate first.
2016.01.09 13:07:36 1: readingsUpdate(,desiredTemperature,0.0) missed to call readingsBeginUpdate first.
2016.01.09 13:07:36 1: readingsUpdate(,state,waiting for data (rf error)) missed to call readingsBeginUpdate first.
2016.01.09 13:07:36 1: readingsUpdate(,RSSI,-80) missed to call readingsBeginUpdate first.
2016.01.09 13:07:36 3:     main::MAX_Parse                     called by fhem.pl (3377)
2016.01.09 13:07:36 3: mc: Unknown code MAX,0,SetTemperature,014c4f,40, help me!
2016.01.09 13:07:58 1: ERROR: empty name in readingsBeginUpdate
2016.01.09 13:07:58 3: stacktrace:
2016.01.09 13:07:58 3:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2016.01.09 13:07:58 3:     main::MAX_Parse                     called by fhem.pl (3360)
2016.01.09 13:07:58 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (297)
2016.01.09 13:07:58 3:     main::CUL_MAX_Parse                 called by fhem.pl (3360)
2016.01.09 13:07:58 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (939)
2016.01.09 13:07:58 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (797)
2016.01.09 13:07:58 3:     main::CUL_Read                      called by fhem.pl (3201)
2016.01.09 13:07:58 3:     main::CallFn                        called by fhem.pl (661)
2016.01.09 13:07:58 1: readingsUpdate(,mode,manual) missed to call readingsBeginUpdate first.
2016.01.09 13:07:58 1: readingsUpdate(,desiredTemperature,0.0) missed to call readingsBeginUpdate first.
2016.01.09 13:07:58 1: readingsUpdate(,state,waiting for data (rf error)) missed to call readingsBeginUpdate first.
2016.01.09 13:07:58 1: readingsUpdate(,RSSI,-71.5) missed to call readingsBeginUpdate first.
2016.01.09 13:07:58 3:     main::MAX_Parse                     called by fhem.pl (3377)
2016.01.09 13:07:58 3: mc: Unknown code MAX,0,SetTemperature,014c4f,40, help me!
Ich habe auch probiert das gerät mal zu löschen, aber das hatte nichts gebracht...
Meine Versionen:
10_MAX.pm                    8681 2015-06-02 21:40:29Z mgehre
SirUli
Habe den Thermostat via delete aus der Datenstruktur geworfen (So wie es bei einem undef gemacht wird) und unmittelbar danach manuell definiert, jetzt tuts. Unschön, aber zumindest Fehler bereinigt.
