sysstat killt fhem
Begonnen von P.A.Trick, 10 Januar 2016, 17:02:52
P.A.Trick
Mir ist eben mein komplettes FHEM abgekachelt bei der Nutzung des SYSSTAT Moduls in Verbindung mit SNMP.
Hier mal das Log:
2016.01.10 16:47:34.549 1: PERL WARNING: Useless use of a constant (7200) in void context at (eval 15616) line 1.
2016.01.10 16:47:34.549 3: stacktrace:
2016.01.10 16:47:34.550 3:     main::__ANON__                      called by (eval 15616) (1)
2016.01.10 16:47:34.550 3:     (eval)                              called by ./FHEM/98_DOIF.pm (1137)
2016.01.10 16:47:34.550 3:     main::DOIF_SetSleepTimer            called by ./FHEM/98_DOIF.pm (741)
2016.01.10 16:47:34.550 3:     main::DOIF_cmd                      called by ./FHEM/98_DOIF.pm (1182)
2016.01.10 16:47:34.551 3:     main::DOIF_SleepTrigger             called by ./FHEM/98_apptime.pm (104)
2016.01.10 16:47:34.551 3:     main::apptime_getTiming             called by ./FHEM/98_apptime.pm (45)
2016.01.10 16:47:34.551 3:     main::HandleTimeout                 called by fhem.pl (593)
2016.01.10 16:56:12.210 1: PERL WARNING: Argument "noSuchInstance" isn't numeric in subtraction (-) at ./FHEM/32_SYSSTAT.pm line 301.
2016.01.10 16:56:12.210 3: stacktrace:
2016.01.10 16:56:12.211 3:     main::__ANON__                      called by ./FHEM/32_SYSSTAT.pm (301)
2016.01.10 16:56:12.211 3:     main::SYSSTAT_GetUpdate             called by ./FHEM/98_apptime.pm (104)
2016.01.10 16:56:12.211 3:     main::apptime_getTiming             called by ./FHEM/98_apptime.pm (45)
2016.01.10 16:56:12.212 3:     main::HandleTimeout                 called by fhem.pl (593)
Illegal division by zero at ./FHEM/32_SYSSTAT.pm line 304.
Und noch die Def:
   DEF        60 600 trinity
   HAS_Net::SNMP 1
   HAS_Sys::Statistics 0
   HOST       trinity
   INTERVAL   60
   INTERVAL_FS 600
   NAME       sysstat
   NR         2167
   STATE      5
   TYPE       SYSSTAT
   USE_SNMP   1
   interval_fs 540
   snmpVersion 2
   Readings:
     2016-01-10 13:57:30   /share/HDA_DATA 346552987648
     2016-01-10 13:57:30   /share/HDB_DATA 1355684503552
     2016-01-10 13:57:30   /share/HDC_DATA 222465904640
     2016-01-10 17:01:43   load            0.05
     2016-01-10 17:01:43   state           5
     2016-01-10 17:01:43   uptime          1 day, 01:15:26.51
   filesystems:
     1
     3
     33
     34
     35
   filesystems 1,3,33,34,35
   showpercent 1
   snmp       1
   snmpVersion 2
   uptime     1
   verbose    5
Im Log habe ich noch das hier entdeckt:
2016.01.10 17:01:43.043 4: sysstat: got empty result from snmp query Received noSuchName(2) error-status at error-index 3
FHEM + Homeassistant - meine HW -> https://www.trinityonline.de/hardware/
