[erledigt] wunderground down?
Begonnen von franky08, 05 März 2016, 12:31:52
franky08
Ich bekomme seit heute morgen ca. 05:45 Uhr keine Daten mehr von wunderground.com. Abfrage läuft über HTTPMOD.
Im Log:
Date: Sat, 05 Mar 2016 11:07:39 GMT
Content-Length: 350
Connection: close, buffer empty,
Error read from to http://api.wunderground.com:80 timed out
2016.03.05 12:11:43 3: Wetter_Wouderground: Read callback: request type was Update,
header: HTTP/1.0 404 Not Found
Server: Apache/2.2.15 (CentOS)
Content-Type: text/html; charset=iso-8859-1
Expires: Sat, 05 Mar 2016 11:07:39 GMT
Cache-Control: max-age=0, no-cache
Pragma: no-cache
Content-Length: 350
2016.03.05 12:13:39 3: Wetter_Wouderground: Defined with URL http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=ISACHSEN110 and interval 600
2016.03.05 12:13:42 3: Wetter_Wouderground: Read callback: request type was Update,
Pragma: no-cache
Content-Length: 350
2016.03.05 12:13:47 3: Wetter_Wouderground: Read callback: request type was Update,
Pragma: no-cache
List:
   BUSY       0
   CHANGED
   DEF        http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=ISACHSEN110 600
   GetSeq     0
   HTTPHEADER
   Interval   600
   LASTSEND   1457177021.22811
   MainURL    http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=ISACHSEN110
   NAME       Wetter_Wouderground
   NR         1798
   STATE      Temperatur 3.8 °C, Wind 0.0 km/h
   TRIGGERTIME 1457177621.22674
   TRIGGERTIME_FMT 2016-03-05 12:33:41
   TYPE       HTTPMOD
   addr       http://api.wunderground.com:80
   buf
   code       404
   data
   displayurl http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=ISACHSEN110
   header
   host       api.wunderground.com
   httpheader HTTP/1.0 404 Not Found
Pragma: no-cache
Content-Length: 350
Connection: close
   ignoreredirects 0
   loglevel   4
   path       /weatherstation/WXCurrentObXML.asp?ID=ISACHSEN110
   protocol   http
   redirects  0
   timeout    4
   QUEUE:
   Readings:
     2016-03-05 06:41:17   Pressure        981.9
     2016-03-05 06:41:17   datetime        Sat, 05 Mar 2016 05:41:08 GMT
     2016-03-05 06:41:17   temperature     3.8
     2016-03-05 06:41:17   windChill       3.8
     2016-03-05 06:41:17   windDegrees     230
     2016-03-05 06:41:17   windDirection   SW
     2016-03-05 06:41:17   windGust        0
     2016-03-05 06:41:17   windSpeed       0
   Request:
     data
     header
     ignoreredirects 0
     retryCount 0
     type       Update
   Sslargs:
   DbLogExclude .*
   reading01Name datetime
   reading01Regex <observation_time_rfc822>([^<]+)
   reading02Name temperature
   reading02Regex <temp_c>([^<]+)
   reading03Name windDegrees
   reading03Regex <wind_degrees>([^<]+)
   reading04Name windDirection
   reading04Regex <wind_dir>([^<]+)
   reading05Expr $val * 1.6
   reading05Name windGust
   reading05Regex <wind_gust_mph>([^<]+)
   reading06Expr $val * 1.6
   reading06Name windSpeed
   reading06Regex <wind_mph>([^<]+)
   reading07Expr ReadingsVal($name, 'windSpeed', 0) > 5 ? 13.12 + 0.6215 * ReadingsVal($name, 'temperature', 0) - 11.37*(ReadingsVal($name, 'windSpeed', 0)**0.16) + 0.3965 * ReadingsVal($name, 'temperature', 0) * (ReadingsVal($name, 'windSpeed', 0)**0.16) : ReadingsVal($name, 'temperature', 0)
   reading07Name windChill
   reading07Regex <temp_c>([^<]+)
   reading08Name Pressure
   reading08Regex <pressure_mb>([^<]+)
   room       Wetter
   stateFormat {sprintf("Temperatur %.1f °C, Wind %.1f km/h", ReadingsVal($name,"temperature",0), ReadingsVal($name,"windSpeed",0))}
   timeout    4
   userattr   DbLogExclude reading01Name reading01Regex reading02Name reading02Regex reading03Name reading03Regex reading04Name reading04Regex reading05Expr reading05Name reading05Regex reading06Expr reading06Name reading06Regex reading07Expr reading07Name reading07Regex reading08Name reading08Regex stateFormat timeout
Kann das jemand bestätigen ?
VG
Frank
mit FHEM aktuell
frank
gib die url doch direkt in den browser ein.
FHEM: 6.0(SVN) => Pi3(buster)
tomster
Seit heut in der Früh ~06:45 geht bei mir auch nix mehr.
Der Server kommt schon wieder...
Benni
spikeh1
Kann ich hier nicht bestätigen.
httpheader HTTP/1.0 200 OK
MfG
franky08
So schnell kann es gehen, Seite ist wieder online  ;)
datetime Sat, 05 Mar 2016 12:23:33 GMT 2016-03-05 13:23:41
VG
Frank
mit FHEM aktuell
