LCD funktioniert nicht in FHEM mit OWServer / OWDevice
Begonnen von harry-th, 14 Januar 2016, 12:37:18
fruit
#15
There were changes between wheezy and jessie versions of owfs that caused problems with OWNet.pm See https://sourceforge.net/p/owfs/mailman/message/34936918/ for details
This has now been fixed but at present the new module (dated later than 18-03-2016) is probably only available from https://sourceforge.net/p/owfs/code/ci/master/tree/ or updated with a patch in the above mentioned thread
Replacing jessie OWNet.pm with the new fixes the text display issue, nb. OWNet.pm may be installed in more than one place!
Edit: changed date - I had used my local copy :/
Feel free to follow up in German if you prefer
