Plot vom fan Status von dewpoint
Begonnen von LaSto, 29 August 2016, 13:44:58
LaSto
ich bin grad am verzweifeln :(
Ich schreibe ein Filelog wo der Fan Status von dewpoint geloggt wird.
Dieser sieht so aus:
2016-08-29_12:30:53 bz_Temp fan: off   << addLog
2016-08-29_12:31:53 bz_Temp fan: off   << addLog
2016-08-29_12:32:53 bz_Temp fan: off   << addLog
2016-08-29_12:33:53 bz_Temp fan: off   << addLog
2016-08-29_12:34:53 bz_Temp fan: off   << addLog
2016-08-29_12:35:53 bz_Temp fan: off   << addLog
2016-08-29_12:36:44 bz_Temp fan: on
2016-08-29_12:36:53 bz_Temp fan: on   << addLog
2016-08-29_12:37:53 bz_Temp fan: on   << addLog
2016-08-29_12:38:53 bz_Temp fan: on   << addLog
2016-08-29_12:39:53 bz_Temp fan: on   << addLog
2016-08-29_12:40:53 bz_Temp fan: on   << addLog
2016-08-29_12:54:45 bz_Temp fan: on   << addLog
2016-08-29_13:04:45 bz_Temp fan: on   << addLog
2016-08-29_13:05:39 bz_Temp fan: off
2016-08-29_13:11:27 bz_Temp fan: on
2016-08-29_13:14:20 bz_Temp fan: off
2016-08-29_13:19:14 bz_Temp fan: off   << addLog
2016-08-29_13:20:14 bz_Temp fan: off   << addLog
2016-08-29_13:21:14 bz_Temp fan: off   << addLog
2016-08-29_13:23:21 bz_Temp fan: off   << addLog
2016-08-29_13:24:21 bz_Temp fan: off   << addLog
2016-08-29_13:25:21 bz_Temp fan: off   << addLog
2016-08-29_13:26:21 bz_Temp fan: off   << addLog
2016-08-29_13:27:21 bz_Temp fan: off   << addLog
2016-08-29_13:30:01 bz_Temp fan: off   << addLog
2016-08-29_13:31:01 bz_Temp fan: off   << addLog
2016-08-29_13:32:01 bz_Temp fan: off   << addLog
2016-08-29_13:33:01 bz_Temp fan: off   << addLog
2016-08-29_13:34:01 bz_Temp fan: off   << addLog
2016-08-29_13:35:01 bz_Temp fan: off   << addLog
2016-08-29_13:36:01 bz_Temp fan: off   << addLog
2016-08-29_13:37:01 bz_Temp fan: off   << addLog
2016-08-29_13:38:01 bz_Temp fan: off   << addLog
2016-08-29_13:39:01 bz_Temp fan: off   << addLog
2016-08-29_13:40:01 bz_Temp fan: off   << addLog
2016-08-29_13:41:01 bz_Temp fan: off   << addLog
2016-08-29_13:42:01 bz_Temp fan: off   << addLog
Nun würde ich diesen Log gern als Plot darstellen. Dies wollte ich mit dem Typischen FS20 Log machen da es hier ja auch den Status "on" und "off" gibt.
Leider funktioniert dies nicht. Es wird immer nur "off" geloggt.
Ich habe schon einige Plots gebaut, aber hier stehe ich richtig auf dem Schlauch.
Konfig im Plot Editor:
Fan    FileLog_bz_Temp_Fan    4    bz:Temp.*    0    $fld[2]=~"on"?1:0    right    step     I0    1
Wäre super wenn mir jemand die Tomaten von den Augen kratzen könnte ;)
Danke schon mal.
MfG
Lars
FS20, 3x S300TH, 1x CUL868, FritzBox 7390
LaSto
Toll, kaum hab ich den Beitrag geschrieben, finde ich die Lösung selbst :o >:(
$fld[2]=~"on"?1:0 muss $fld[3]=~"on"?1:0 heisen. Einfach das falsche Feld angegeben...
