[HMConfig.pm] patch für Roto Tasterschnittstelle
Begonnen von betateilchen, 20 April 2016, 19:40:18
Hallo Martin,
für das Roto Device ROTO_ZEL-STG-RM-FST-UP4 fehlt in der HMConfig.pm die Definition der channels.
Mit folgendem patch werden dann auch die vier Channels für die Buttons korrekt angelegt.
Index: HMConfig.pm
--- HMConfig.pm (revision 11237)
+++ HMConfig.pm (working copy)
@@ -196,7 +196,7 @@
  ,"007C" => {name=>"ROTO_ZEL-STG-RM-FZS"     ,st=>'switch'            ,cyc=>''      ,rxt=>''       ,lst=>'1,3'          ,chn=>"",}  # radio-controlled socket adapter switch actuator 1-channel
  ,"007D" => {name=>"ROTO_ZEL-STG-RM-WT-2"    ,st=>'pushButton'        ,cyc=>''      ,rxt=>'c:w:l'  ,lst=>'1,4'          ,chn=>"",}  # HM Push Button 2
  ,"007E" => {name=>"ROTO_ZEL-STG-RM-DWT-10"  ,alias=>"HM-PB-4DIS-WM-2"}
- ,"007F" => {name=>"ROTO_ZEL-STG-RM-FST-UP4" ,st=>'pushButton'        ,cyc=>''      ,rxt=>'c'      ,lst=>'1,4'          ,chn=>"",}  # HM Push Button Interface
+ ,"007F" => {name=>"ROTO_ZEL-STG-RM-FST-UP4" ,st=>'pushButton'        ,cyc=>''      ,rxt=>'c'      ,lst=>'1,4'          ,chn=>"Btn:1:4",} # HM Push Button Interface
  ,"0080" => {name=>"ROTO_ZEL-STG-RM-HS-4"    ,st=>'remote'            ,cyc=>''      ,rxt=>'c'      ,lst=>'1,4'          ,chn=>"",}  # HM Remote 4 buttons
  ,"0081" => {name=>"ROTO_ZEL-STG-RM-FDK"     ,st=>'threeStateSensor'  ,cyc=>'28:00' ,rxt=>'c:w'    ,lst=>'1,4'          ,chn=>"",}  # HM Rotary Handle Sensor
  ,"0082" => {name=>"Roto_ZEL-STG-RM-FFK"     ,st=>'threeStateSensor'  ,cyc=>'28:00' ,rxt=>'c:w'    ,lst=>'1,4'          ,chn=>"",}  # HM Shutter Contact
martinp876
