[FHZ] Problem getting my house code
Begonnen von Guest, 16 Oktober 2008, 21:50:21
Guest
The big question is, how do i get to know the housecode of my fs20
dimmer?
I already hooked it up to the buttons of the fs20 piri-2 and if i
check the logs, while pushing a button on the piri i get this logfile
entry in my fhem.log :
2008.10.16 21:43:53 5: FHZ/RAW: 810c042d0101a001000001003a4f
(Unparsed: )
2008.10.16 21:43:53 2: FS20 lamp on-old-for-timer 60
2008.10.16 21:43:53 5: Triggering lamp (1 changes)
It would be nice if anybody could help me out with that problem.
Regards Friedrich
You received this message because you are subscribed to the Google Groups "FHZ1000 users on Linux" group.
To post to this group, send email to FHZ1000-users-on-unix@googlegroups.com
To unsubscribe from this group, send email to FHZ1000-users-on-unix+unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/FHZ1000-users-on-unix?hl=en
Guest
hi,
your house code is not set by default. The device uses 0000:
> 2008.10.16 21:43:53 5: FHZ/RAW: 810c042d0101a001 *0000* 01003a4f
The idea of the house code is that you make up your own.
The dimmer will accept any house/device code. Once you've put it in
the learning mode it picks up the next FS20 data package and extracts
the code.
The easiest way to programm any device is to define it in the FHEM
configuration and send a "on" or "off" to it.
regards,
Peter
Guest
Thanks Peter! I got it working.
Regards,
Friedrich
Pest schrieb:
> hi,
> the code.
> regards,
> Peter
