MaxScanner müllt mir an einem Heizkörper das System zu und reduziert die Perform
Begonnen von dieda, 03 August 2016, 21:12:08
dieda
Hallo in der Runde,
ich brauch mal wieder eure Hilfe. Einer meiner Heizkörper scheint viel Datenmüll und -Last zu produzieren. Hier die Def:
   CHANGED
   DEF        HeatingThermostat 002abf
   IODev      ml
   LASTInputDev ml
   MSGCNT     8
   NAME       bu_HK
   NR         145
   STATE      off °C
   TYPE       MAX
   addr       002abf
   backend    ml
   dstsetting 1
   ml_MSGCNT  8
   ml_TIME    2016-02-09 21:06:17
   mode       1
   rferror    0
   serial     IEQ0200333
   type       HeatingThermostat
   Readings:
     2016-02-09 21:06:17   MAXLAN_error    0
     2016-02-09 21:06:17   MAXLAN_errorInCommand
     2016-02-09 21:06:17   MAXLAN_initialized 1
     2016-02-09 21:06:17   MAXLAN_isAnswer 0
     2016-02-09 21:06:17   MAXLAN_valid    1
     2016-02-09 21:06:17   battery         ok
     2016-02-09 21:03:12   boostDuration   0
     2016-02-09 21:03:12   boostValveposition 80
     2016-02-09 21:03:12   comfortTemperature 19.5
     2016-02-09 21:03:12   decalcification Sat 12:00
     2016-02-09 21:06:17   desiredTemperature off
     2016-02-09 21:03:12   ecoTemperature  18.0
     2016-02-09 21:03:12   firmware        1.4
     2016-02-09 21:03:12   groupid         8
     2015-09-01 13:26:37   humidity        0
     2016-02-09 21:03:12   maxValveSetting 100
     2016-02-09 21:03:12   maximumTemperature on
     2016-02-09 21:03:12   measurementOffset 2.0
     2016-02-09 21:03:12   minimumTemperature off
     2016-02-09 21:06:17   mode            manual
     2016-02-09 21:06:17   state           off °C
     2016-02-09 21:03:13   temperature     23.1
     2016-02-09 21:03:12   testresult      255
     2016-02-09 21:03:12   valveOffset     0
     2016-02-09 21:06:17   valveposition   0
     2016-02-09 21:03:12   weekprofile-0-Sat-temp 18.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-0-Sat-time 00:00-10:05  /  10:05-20:15  /  20:15-00:00
     2016-02-09 21:03:12   weekprofile-1-Sun-temp 18.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-1-Sun-time 00:00-10:05  /  10:05-20:25  /  20:25-00:00
     2016-02-09 21:03:12   weekprofile-2-Mon-temp 18.0 °C  /  18.0 °C  /  20.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-2-Mon-time 00:00-06:05  /  06:05-09:05  /  09:05-13:10  /  13:10-20:10  /  20:10-00:00
     2016-02-09 21:03:12   weekprofile-3-Tue-temp 18.0 °C  /  18.0 °C  /  18.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-3-Tue-time 00:00-06:05  /  06:05-09:10  /  09:10-13:05  /  13:05-20:05  /  20:05-00:00
     2016-02-09 21:03:12   weekprofile-4-Wed-temp 18.0 °C  /  18.0 °C  /  18.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-4-Wed-time 00:00-06:05  /  06:05-09:10  /  09:10-13:05  /  13:05-20:05  /  20:05-00:00
     2016-02-09 21:03:12   weekprofile-5-Thu-temp 18.0 °C  /  18.0 °C  /  18.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-5-Thu-time 00:00-06:05  /  06:05-09:10  /  09:10-13:05  /  13:05-20:05  /  20:05-00:00
     2016-02-09 21:03:12   weekprofile-6-Fri-temp 18.0 °C  /  18.0 °C  /  18.0 °C  /  20.0 °C  /  18.0 °C
     2016-02-09 21:03:12   weekprofile-6-Fri-time 00:00-06:05  /  06:05-09:10  /  09:10-13:05  /  13:05-20:05  /  20:05-00:00
     2016-02-09 21:03:12   windowOpenDuration 15
     2016-02-09 21:03:12   windowOpenTemperature off
   Helper:
     DesiTime   1455048193
     LastCmdDate 1455048195.10164
     NextScan   1455048915
     TempBeforeWindOpen 5.0
     TemperatureTime 1455048193
     WinWasOpen 0
     desiredOffset -13
     gotTempTS  1
     leadDesiTemp 18.0
     switchDate 1455058800
     shutterContacts:
       bue_Fensterkontakt
     interfaces thermostat;battery;temperature
   IODev      ml
   event-on-change-reading temperature, desiredTemperature, valveposition, state
   room       Buero
   scanTemp   1
   scnModeHandling MANUAL
   scnProcessByDesiChange 1
   scnShutterList bue_Fensterkontakt
   userattr   scnProcessByDesiChange:0,1 scnShutterList scnModeHandling:NOCHANGE,AUTO,MANUAL
und hier ein paar Beispieleinträge:2016.08.02 21:40:43 3: MaxScanner bu_HK Work.852 reading desiredTemperature: thermostat is forced on/off. Skipping thermostat
2016.08.02 21:40:48 3: MaxScanner bu_HK Work.852 reading desiredTemperature: thermostat is forced on/off. Skipping thermostat
2016.08.02 21:40:53 3: MaxScanner bu_HK Work.852 reading desiredTemperature: thermostat is forced on/off. Skipping thermostat
2016.08.02 21:40:58 3: MaxScanner bu_HK Work.852 reading desiredTemperature: thermostat is forced on/off. Skipping thermostat
2016.08.02 21:41:03 3: MaxScanner bu_HK Work.852 reading desiredTemperature: thermostat is forced on/off. Skipping thermostat
Komponenten:
Sensoren und Aktoren: FS20, Max!, Zigbee, Zwave
IODev:  Cul1101, MaxLan, ZWAVE, Deconz
Router: KD-Fritte (6360)
Sonstiges: Raspberries,  1x LMS,1 FHEM, 1 x zum Testen,  Logitech-Clients,  Onkyo, SamsungTV, Squeezebox, TabletUIs
willyk
NUC mit Ubuntu, MAX!Cube, CUNO, 6 MAX WT, 16 MAX HT, 2 MAX Fensterkontakt, MaxScanner
