Neue Meldung im Log nach gestrigem Update
Begonnen von Helmi55, 20 Juni 2016, 12:17:26
Helmi55
Hallo
habe gestern am Abend wieder ein FHEM update gemacht und seit dem habe ich folgende Meldung im Log   "General"
2016.06.20 11:00:00 3: CUL_HM set PoolPumpe on
2016.06.20 11:00:00 1: General 100-0
2016.06.20 11:13:41 3: Wetter: 0 result(s) retrieved
2016.06.20 11:59:57 3: EMONITOR_Statistik: tmpdevices abgearbeitet
2016.06.20 11:59:57 3: EMONITOR_Statistiks (end): Calc next call - found 6 devices 49 59 12 20 5 116 1 171 1
2016.06.20 12:11:43 3: CUL_HM set PoolPumpe off
2016.06.20 12:11:43 1: General 0-0
2016.06.20 12:15:47 3: CUL_HM set SolarPumpe on
2016.06.20 12:15:47 1: General 100-0
2016.06.20 12:15:54 3: CUL_HM set SolarPumpe off
2016.06.20 12:15:54 1: General 0-0
Es handelt sich um einen HM 4fach Hutschienenaktor
Hier das List
   DEF        324B1501
   NAME       PoolPumpe
   NR         138
   NTFY_ORDER 50-PoolPumpe
   STATE      on
   TYPE       CUL_HM
   chanNo     01
   device     HM_4_Switch_Garage
   offtime    1466417503
   oldenergy  0
   oldenergytime 1466356212
   ontime     1466417515
   Readings:
     2016-06-20 12:11:55   CommandAccepted yes
     2016-03-22 18:33:22   R-powerUpAction off
     2016-03-22 18:33:22   R-sign          off
     2016-05-30 06:02:08   RegL_01.        08:00  30:06 57:24 56:00 00:00
     2016-06-20 12:11:55   deviceMsg       on (to HMUSB)
     2016-06-20 12:11:55   level           100
     2016-06-20 12:11:45   lifetime        2301094
     2016-06-20 12:11:55   pct             100
     2016-06-20 11:59:54   power-daily     1035.2
     2016-06-19 23:59:54   power-daily-last 5925.1
     2016-06-20 12:11:58   power-hourly    135.916701388889
     2016-06-20 11:59:54   power-hourly-last 689.0
     2016-06-20 11:59:54   power-monthly   132533.1
     2016-05-31 23:59:53   power-monthly-last 189854.100000001
     2016-06-20 11:59:54   power-weekly    1035.2
     2016-06-19 23:59:54   power-weekly-last 48883.9999999999
     2016-06-20 11:59:54   power-yearly    440229.799999993
     2016-06-20 12:11:55   recentStateType ack
     2016-06-20 12:11:55   state           on
     2016-06-20 12:11:55   timedOn         off
   Helper:
     dlvlCmd    ++A011220355324B150201C80000
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Role:
       chn        1
   model      HM-LC-SW4-DR
   peerIDs    00000000,
   power-off  0.125
   power-on   690.125
   room       Favoriten,Poolsteuerung
   sortby     1
   webCmd     on:off
Ich nehme nicht an dass es eine Fehlermeldung ist, aber kann mir bitte jemand sagen was das bedeutet? Oder einfach ignorieren?
Helmut
System1 fhem 6.1 auf RPi 4B mit 4GB, HMUSBConfig, DS9490R-1Wire, Busware USB 868, Pool-Solarsteuerung mit FHEM. System2 fhem 6.1 auf RPi 4B mit 4GB (Bullseye) mit Busware USB 868 und 433 und HMUARTLGW für Haussteuerung
https://www.flickr.com/photos/canonhelmi/
Erstmal ignorieren. Ich denke, das ist noch debug-Code von martin und hängt mit den Schaltbefehlen (genauer: den Werten für Level) zusammen. Da gab es am Wochenende eine Änderung im Coding. Das ist nix Schlimmes.
kumue
schließe mich an...
Hab diese Meldungen seit dem gestrigen Update.
Geht der HM-Aktor auf on, wird General 100-0 geloggt, bei off General 0-0
Eine FM ist es sicher nicht...
Helmi55
Danke für die raschen Antworten.
Wird ja dann sicher mit den nächsten Updates wieder ausgebügelt. wenn nicht stört auch nicht
Schönen Tag
Helmut
