[FHZ] Relative at command yields wrong absolute time
Begonnen von rudolfkoenig, 28 Mai 2009, 21:09:24
I have been a proud owner of automatic shutters for just one week now.
Enough time to get even more out of fhem.
I want the shutters on the first floor to open at sunset plus half an
hour, but not before my regular waking time at 06:10. The respective
command is in the commandref. It worked well on the first and second day
but since then shutters open before 06:10. And here is why:
list at.sunrise.2
   DEF        +*{max(abstime2rel("06:10"),sunrise_rel(1800))} set
2.sz.roll,2.kiz.roll,2.bad.roll,2.og.roll on
   NAME       at.sunrise.2
   NR         117
   NTM        05:59:06
   REP        -1
   STATE      Next: 05:59:06
   TRIGGERTIME 1243569546.3687
   TYPE       at
==> Next is 05:59.
At 21:05 I tried  { abstime2rel("06:10") } which yields 09:04:51, correct.
What's the best way to debug this?
Regards,
Boris
You received this message because you are subscribed to the Google Groups "FHEM users on Linux" group.
To post to this group, send email to fhem-users@googlegroups.com
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en
Let's say it is 06:10, and sunrise is earlier. The relative time to
06:10 is 00:00, to the next sunrise is 23:something, max() takes the
next sunrise. The same happens if sunrise is before 06:10. Better is
to use absolute times: max("06:10", sunrise_abs(1800)) and forget the
+ in the at definition.
But there is a generic problem with repetitive sunrise dependent at
commands: All absolute sunrise/sunset commands will be executed twice
each day, relative commands are just a little bit better: sunrise_rel
is executed twice in the spring, and sunset_rel twice in the fall.
Proposal: The at command should set a global flag when computing the
repetition (not the first event), and the sunrise/sunset is computed
for the following day if this flag is set (and not just the next
event, which can be on the same day), and add 24:00:00 to the returned
time. Ugly: The problem above can only be solved by integrating a min/
max in sunrise.
As this is a quite ugly hack, I'd like to hear some better ideas.
Dr. Boris Neubert
what about repeatedly dynamically generating single sunrise/sunset at
command at midnight?
define at.generator at *00:01 define at.sunset at max("06:10",
sunrise_abs(1800)) set 1.sz.roll on
BTW, is the at definition a perl command? Would max(if($we) { "07:30" ;;
} else { "06:10" ;; }) work as a time spec?
Boris
Ugly hack implemented, documented and checked in. You shall define
your command as:
define at.sunrise.2  at *{sunrise(1800, "6:10"))} set 2.*roll on
If the at time-spec is enclosed in {} then it well be evaluated as a
perl expression, your example is probably still wrong. The timespec
calculates the _next_ event,
so it will be 7:30 for sunday and monday.
Dr. Boris Neubert
Am Samstag, 30. Mai 2009 schrieb Rudolf Koenig:
> your command as:
   define at.sunrise.1 at *{ sunrise(1800, "05:30") } set blabla on
gives me
   Wrong timespec {: either HH:MM:SS or {perlcode}
because
yields
   29:30:00
Oops, and I did not even mention that the windows should open later not only
on weekends but also on holidays. As far as I see the holiday get function
must be extended to check whether _tomorrow_ is a holiday. This becomes quite
complex.
The problem seems to be in the head of the user (me). The at command does what
the at command does on unix systems: execute a command at a specified time in
the future (and optionally reschedule another at command at the time of
execution). What the user expects is functionality like cron: execute a
command on a given time schedule (open shutters not before 07:30 on weekends
and holidays). I have to think about it before I can come up with a intuitive
solution.
Regards,
Boris
Dr. Boris Neubert
Am Sonntag, 31. Mai 2009 schrieb Boris Neubert:
> gives me
Postscriptum: the problem is not the timespec but the parsing of the timespec
in fhem.pl, sub GetTimSpec($), line 1765.
The pattern ^{(.*)}$ seems to match the timespec only up to the first blank.
If I omit the blank after the comma between the parameters of the subrise
function, the define works.
Boris
Hi Boris,
> execution).
Just the following suggestions shot in my mind:
1. Define an at-command that executes at 1:00 O'Clock of every night.
Within this at-Command check for subsequent events that need to be
scheduled for the day and schedule them.
This will lead into a fairly big at-bloc.
So maybe you will write your own module and just call the method out
of the at command?
2. To solve your problem (after sunrise but not before 7:30):
Define an at-Commenad at 7:30 and check if sunrise will still happen
or already happened and either switch on the devices directly or set
an onetime at command for the time of sunrise.
What do you think?
greetings
Maz
Dr. Boris Neubert
Hi Maz,
thank you for your suggestions!
Am Sonntag, 31. Mai 2009 schrieb Maz:
> of the at command?
That sounds similar to my idea in the post from 2009-05-30 09:37 (repeatedly
dynamically generating single sunrise/sunset at  command at midnight)
I am still wondering whether I will change my configuration according to the
above suggestions or implement a cron-like command into fhem. The latter
needs quite some thinking about.
define sunriseaction cronjob day timespec command
day= a function that evaluates to false or true depending on whether the
command is to be executed today or not
timespec= when should the command be executed
example:
define openshutters_workday cronjob { !$we || $holiday } {
sunset(1800,"07:30") } set 2.sz.roll on
Regards,
Boris
Why don't you just define two at jobs, one for weekend/holiday, and
one for the working days?
define he holiday
attr global holiday2we he
define rollon_wd at *{sunrise(1800,"06:10")} { fhem("set 2 sz.*roll
on") if(!$we) }
define rollon_we at *{sunrise(1800,"07:30")} { fhem("set 2 sz.*roll
on") if($we) }
This is how I do it since 2 years now (well, up till now without
holidays and for fixed times).
Dr. Boris Neubert
I slept the night over it and I came to the conclusion that it would be
best to resort to what is already available. I will follow your suggestion.
I just saw that you already implemented an extension of the notion of
$we depending on whether the global attribute holiday2we is set or not.
I missed that completely.
So the new sunset command combined with the perl special $we will do it!
Thank you very much.
Best regards,
Boris
