[Gelöst] max.rtr von reichi
Begonnen von jeti, 05 Januar 2017, 13:23:30
jeti
ich bin gerade dabei meine MAX Thermostate per smartvisu zu steuern, dabei habe ich folgendes im WIKI gefunden:
https://forum.fhem.de/index.php?topic=30909.msg241379#msg241379
Ich habe also dies:
* Small RTR (Room Temperatur Regulator)
* @param       unique id for this widget
* @param       name of the rtr
* @param       a gad/item for the actual temperature
* @param       a gad/item for the set temperature
* @param       a gad/item for the current state of the actor
* @param       step for plus/minus buttons (optional, default 0.5°)
{% macro smallrtr(id, txt, gad_actual, gad_set, gad_state, step) %}
{% import "basic.html" as basic %}
{% set uid = uid(page, id) %}
/** Design */
<div id="{{ uid }}" class="rtr">
    <table style="width:100%; text-align: left;">
        <tr>
            <th width="25%">{% if txt %} {{ txt }} {% endif %}</th>
            <td width="15%"><div class="temp">{{ basic.float(id~'actual', gad_actual, '°C' ) }}</div></td>
            <td width="15%">
                {% if gad_set %}
                    {{ basic.button(id~'minus', '', '', 'minus', '', 'micro') }}
                {% endif %}
            </td>
            <td width="15%"><div class="temp">{{ basic.float(id~'set', gad_set, '°C' ) }}</div></td>
            <td width="15%">
                {% if gad_set %}
                    {{ basic.button(id~'plus', '', '', 'plus', '', 'micro') }}
                {% endif %}
            </td>
            <td width="15%">
                {{ basic.symbol(id~'stateon', gad_state, '', icon1~'sani_floor_heating.png', 1) }}
                {{ basic.symbol(id~'stateoff', gad_state, '', icon0~'sani_floor_heating.png', 0) }}
            </td>
        </tr>
    </table>
    {% if gad_set %}
        /** Events */
        <script type="text/javascript">
            // plus / minus
            $("#{{ uid~'minus' }}").unbind('click').bind('click', function(){
                var temp = (Math.round((parseFloat($("#{{ uid~'set' }}").html().replace(',','.')) - {{ step|default(0.5) }}) * 10) / 10).toFixed(1);
            $("#{{ uid~'set' }}").html(temp + ' °C');
            io.write("{{ gad_set }}", temp);
            $("#{{ uid~'plus' }}").unbind('click').bind('click', function(){
                var temp = (Math.round((parseFloat($("#{{ uid~'set' }}").html().replace(',','.')) + {{ step|default(0.5) }}) * 10) / 10).toFixed(1);
        </script>
    {% endif %}
</div>
* Max RTR (Room Temperatur Regulator)
* @param step for plus/minus buttons (optional, default 0.5)
{% macro rtr(id, txt, gad_actual, gad_set, gad_state, step) %}
        <div id="{{ uid(page, id) }}" data-widget="device.rtr" data-step="{{ step|default(0.5) }}"
                class="rtr">
                <div class="actual">
                        <div class="text">{{ txt }} {% if gad_state != 0 %} ({{ gad_state }}) {% endif %}</div>
                </div>
                {% if gad_set %}
                        <div class="set">
                                <a data-role="button" data-icon="minus" data-inline="true" data-iconpos="notext" class="ui-mini"></a>
                                <a data-role="button" data-icon="plus" data-inline="true" data-iconpos="notext" class="ui-mini"></a>
                        </div>
                {% endif %}
        </div>
{% endmacro %}
{% endmacro %}
in device.html im widget Ordner eingefügt.
wenn ich nun meinen device definiere:
{{ max.rtr('Sch_Hzg_rtr', '', 'Sch_Hzg_rtr_act', 'Sch_Hzg_rtr_set', 'Sch_Hzg_rtr_state')}}
wird nichts angezeigt.
wo liegt hier mein Fehler?
Gruß und Danke im voraus
Edit:
Langsam kommt etwas Licht ins Dunkel. Ich denke ich habe nicht alle notwendige files angepasst...
Ich finde dazu leider auch keine Anleitung  :(
Welche Dateien muss ich wo erstellen/anpassen um ein eigenes Widget (max.rtr) zu verwirklichen?
raman
Ich würde den Code in eine neue Datei "max.html" im widget-Ordner speichern und ihn aus der
device.html wieder löschen.
Die Definition sollte dann so auschauen (zusätzlicher Import des Widgets vor der Definition):
{% import max.html" as max %}
jeti
