StatusRequest Meldungen
Begonnen von Rampler, 11 Juli 2016, 19:44:49
Rampler
nach jedem Restart von Fhem bekomme ich folgende Meldungen.
2016.07.11 19:16:29 3: CUL_HM set AZ.rm statusRequest
2016.07.11 19:16:30 3: CUL_HM set Alarm_sir_ext statusRequest
2016.07.11 19:16:31 3: CUL_HM set Alarm_sir_int statusRequest
2016.07.11 19:16:33 3: CUL_HM set BD.licht statusRequest
2016.07.11 19:16:34 3: CUL_HM set BD.spiegel statusRequest
2016.07.11 19:16:35 3: CUL_HM set EM.pm.sw statusRequest
2016.07.11 19:16:36 3: CUL_HM set FC.shutter statusRequest
2016.07.11 19:16:37 3: CUL_HM set FL.AZ.pm.sw statusRequest
2016.07.11 19:16:38 3: CUL_HM set FL.EG.licht statusRequest
2016.07.11 19:16:39 3: CUL_HM set FL.OG.licht statusRequest
2016.07.11 19:16:40 3: CUL_HM set FL.OG.rm statusRequest
2016.07.11 19:16:41 3: CUL_HM set FL.UG.licht statusRequest
2016.07.11 19:16:42 3: CUL_HM set FL.UG.rm statusRequest
2016.07.11 19:16:43 3: CUL_HM set FL.UG.strahler statusRequest
2016.07.11 19:16:44 3: CUL_HM set FL.ZG.licht statusRequest
2016.07.11 19:16:45 3: CUL_HM set GA.keymatic statusRequest
2016.07.11 19:16:46 3: CUL_HM set GA.licht statusRequest
2016.07.11 19:16:47 3: CUL_HM set GA.taster statusRequest
2016.07.11 19:16:48 3: CUL_HM set HW.licht statusRequest
2016.07.11 19:16:49 3: CUL_HM set HZ.zs statusRequest
2016.07.11 19:16:50 3: CUL_HM set KG.rm statusRequest
2016.07.11 19:16:51 3: CUL_HM set KK.rm statusRequest
2016.07.11 19:16:52 3: CUL_HM set KU.licht statusRequest
2016.07.11 19:16:53 3: CUL_HM set KU.rm statusRequest
2016.07.11 19:16:54 3: CUL_HM set KU.spuele statusRequest
2016.07.11 19:16:55 3: CUL_HM set SZ.rm statusRequest
2016.07.11 19:16:56 3: CUL_HM set WC.licht statusRequest
2016.07.11 19:16:57 3: CUL_HM set WC.ventilator statusRequest
2016.07.11 19:16:58 3: CUL_HM set WF.keymatic statusRequest
2016.07.11 19:16:59 3: CUL_HM set WF.licht statusRequest
2016.07.11 19:17:00 3: CUL_HM set WZ.rm statusRequest
Ist das Normal, mich wundert's nur, dass nicht alle Geräte abgefragt werden.
Kann ich das beeinflussen ?
  Klaus
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, Matter und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
LuckyDay
je nach gesetztem attr autoReadReg
ist gut erklärt in der commandref
Rampler
Zitatje nach gesetztem attr autoReadReg
Habe jetz mal alle devices auf 3_onChange gesetzt, Meldungen sind weg...
Bin mal gespannt, welche Nebenwirkungen das hat ...
Bis die Tage
   Klaus
