dblog configcheck logmode check falsche Angabe
Begonnen von Amenophis86, 04 September 2017, 11:32:16
Amenophis86
Ich habe heute mal den configcheck bei meinem dblog ausgeführt. Coole Sache, allerdings ist mir folgendes aufgefallen. Ausgegeben wurde:
Result of logmode check
Logmode of DbLog-device Logdb_Heizung is: synchronous
Recommendation: Switch Logdb_Heizung to the asynchronous logmode by setting the 'asyncMode' attribute. The advantage of this mode is to log events non-blocking.
There are attributes 'syncInterval' and 'cacheLimit' relevant for this working mode.
Please refer to Commandref attributes for further informations.
Wobei ich schon längst auf asynchron laufe:
   CFGFN
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db_Heizung.conf
   DEF        ./db_Heizung.conf (SZ.Fuehler|WZ.NASStat|.*_Clima):(state|desired-temp|measured-temp|ValvePosition|temperature|hdd1_temp|hdd2_temp|humidity).*
   MODE       synchronous
   MODEL      MYSQL
   NAME       Logdb_Heizung
   NR         136
   NTFY_ORDER 50-Logdb_Heizung
   PID        955
   REGEXP     (SZ.Fuehler|WZ.NASStat|.*_Clima):(state|desired-temp|measured-temp|ValvePosition|temperature|hdd1_temp|hdd2_temp|humidity).*
   STATE      connected
   TYPE       DbLog
   UTF8       1
   VERSION    2.22.3
   dbconn     mysql:database=xxx;host=xxx;port=xxx
   dbuser     xxx
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     READINGCOL 64
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     2017-09-04 11:27:56   CacheUsage      3
     2017-09-04 11:27:11   NextSync        2017-09-04 11:32:11 or if CacheUsage 500 reached
     2017-09-04 11:27:12   background_processing_time 0.3651
     2017-09-04 11:27:56   notify_processing_time 0.0015
     2017-09-04 11:27:12   sql_processing_time 0.2376
     2017-09-04 11:27:12   state           connected
   cache:
     index      37855
     memcache:
       37853      2017-09-04 11:27:49|WZ.NASStat|SYSSTAT|state: 0.25 0.29 0.21|state|0.25 0.29 0.21|
       37854      2017-09-04 11:27:49|WZ.NASStat|SYSSTAT|temperature: 46|temperature|46|°C
       37855      2017-09-04 11:27:56|Bad.HZ_Clima|CUL_HM|measured-temp: 20.7|measured-temp|20.7|
   DbLogType  History
   asyncMode  1
   disable    0
   showNotifyTime 1
   showproctime 1
   shutdownWait 3
   syncInterval 300
Und wo wir gerade dabei sind noch eine Sache. Schließt man die db mittels reopen für einige Zeit, wegen Updates etc. und öffnet sie dann wieder manuell, weil man das Zeitintervall von reopen zu lange angesetzt hat, dann werden erst beim erreich von max CacheUsage Daten wieder geschrieben. Das Synintervall wird nicht neu gestartet und bleibt auf dem letzten vergangen Wert stehen.
DS_Starter
Der check wertet das Internal MODE aus. Das steht bei dir komischerweise noch auf "synchronous".   Ich schau mir das mal an wie das kommen kann.
Auch den anderen Aspekt.
Wie genau öffnest du wieder manuell ? (habe es gerade nicht vor mir)
Gruss
Heiko
Amenophis86
#2
Auf das Internal habe ich gar nicht geachtet. Habe jetzt einfach nochmal das Attr auf 1 gesetzt und dann hat das Internal es auch angenommen. Bin mir aber sicher, dass die DB bereits im async Mode gearbeitet hat.
Ich mache folgendes:
set DB reopen 7200
Mach ein Update meiner NAS
set DB reopen
jetzt ist die Verbindung wieder da. Allerdings steht NextSync noch auf der letzten eigentlichen Uhrzeit, wann es wieder dran gewesen wäre. Nun wartet die DB quasi bis CacheUsage auf max ist und schreibt dann. Ab dann geht auch NextSync wieder los. Es sieht danach aus, dass der NextSync Timer bei reopen nicht zurück gesetzt wird.
Edit:
Habe gerade folgendes festgestellt. Sobald man die DEF ändert und speichert, fällt das Internal auf sync Mode. Man muss danach wieder das Attr nochmal neu setzen, damit das Internal auf async wechselt.
DS_Starter
#3
Hallo Amenophis,
habe dir eine Version 2..22.5 angehängt.
Mit der Version sollten die von dir beschriebenen Probleme beseitigt sein.
Teste mal bitte mit allen Scenarien die du so einsetzt.
Heiko
Amenophis86
Werde es die Tage machen, heute komme ich leider nicht mehr dazu. Dank dir.
Amenophis86
Der Typ wird wohl richtig erkannt jetzt. Allerdings das reopen Problem bleibt bestehen. Habe die Verbindung um 11:25 Uhr für 7200 Sek mit reopen geschlossen, gewartet bis der NextSyn Timer (11:30) überschritten wurde, mittels reopen neu um 11:31 Uhr geöffnet, aber der Timer für NextSyn bleibt 11:30 Uhr.
DS_Starter
Schaue ich mir nochmal an .... wir schaffen das schon  ;)
Amenophis86
DS_Starter
Habe die Version in #3 nochmal angepasst und auch den Fehler gefunden (hoffe ich  :) )
Bitte nochmal testen ...
Heiko
Amenophis86
DS_Starter
#10
ZitatJetzt klappt es
prima, kommt ins nächste Release.
EDIT: V2.22.5 eingecheckt
