HMinfo und ERR_Names
Begonnen von SVLoneStar, 31 Oktober 2016, 16:09:37
SVLoneStar
HMinfo meldet mir meine beiden HM-LC-SW1-BA-PCB immer unter ERR_Names.
sumERROR beinhaltet:
battery:ok,sabotageError:off,powerError:ok,overload:off,overheat:off,reduced:off,motorErr:ok,error:none,uncertain:[no|yes],smoke_detect:none,cover:closed
Das List eines der beiden HM-LC-SW1-BA-PCB sieht wie folgt aus:
   .triggerUsed 0
   DEF        361D63
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     39
   NAME       BattFunkAct.1
   NOTIFYDEV  global
   NR         2675
   STATE      off
   TYPE       CUL_HM
   hmusb_MSGCNT 39
   hmusb_RAWMSG E361D63,0000,0AD72C44,FF,FFCE,1AA010361D63AB42FE030000
   hmusb_RSSI -50
   hmusb_TIME 2016-10-30 22:23:15
   lastMsg    No:1A - t:10 s:361D63 d:AB42FE 030000
   peerList   self01,
   protLastRcv 2016-10-30 22:23:15
   protSnd    30 last_at:2016-10-30 22:23:15
   protState  CMDs_done
   rssi_at_hmusb avg:-53.17 lst:-50 cnt:39 max:-50 min:-60
   rssi_hmusb cnt:7 lst:-54 avg:-56.85 min:-58 max:-54
   Readings:
     2016-04-28 00:13:17   .D-devInfo      410100
     2016-04-28 00:13:17   .D-stc          10
     2016-10-30 22:23:14   .peerListRDate  2016-10-30 22:23:14
     2016-10-30 22:23:15   .protLastRcv    2016-10-30 22:23:15
     2016-10-30 22:23:06   CommandAccepted yes
     2016-04-28 00:13:17   D-firmware      1.7
     2016-04-28 00:13:17   D-serialNr      MEQ0592487
     2016-10-30 22:23:13   PairedTo        0xAB42FE
     2016-10-30 22:23:13   R-intKeyVisib   visib
     2016-04-28 00:13:24   R-ledMode       off
     2016-10-30 22:20:12   R-lowBatLimitBA 8 V
     2016-04-28 00:13:24   R-pairCentral   0xAB42FE
     2016-10-30 22:23:15   R-self01-lgActionType jmpToTarget
     2016-10-30 22:23:15   R-self01-lgCtDlyOff geLo
     2016-10-30 22:23:15   R-self01-lgCtDlyOn geLo
     2016-10-30 22:23:15   R-self01-lgCtOff geLo
     2016-10-30 22:23:15   R-self01-lgCtOn geLo
     2016-10-30 22:23:15   R-self01-lgCtValHi 100
     2016-10-30 22:23:15   R-self01-lgCtValLo 50
     2016-10-30 22:23:15   R-self01-lgMultiExec on
     2016-10-30 22:23:15   R-self01-lgOffDly 0 s
     2016-10-30 22:23:15   R-self01-lgOffTime unused
     2016-10-30 22:23:15   R-self01-lgOffTimeMode absolut
     2016-10-30 22:23:15   R-self01-lgOnDly 0 s
     2016-10-30 22:23:15   R-self01-lgOnTime unused
     2016-10-30 22:23:15   R-self01-lgOnTimeMode absolut
     2016-10-30 22:23:15   R-self01-lgSwJtDlyOff off
     2016-10-30 22:23:15   R-self01-lgSwJtDlyOn on
     2016-10-30 22:23:15   R-self01-lgSwJtOff dlyOn
     2016-10-30 22:23:15   R-self01-lgSwJtOn dlyOff
     2016-10-30 22:23:15   R-self01-shActionType jmpToTarget
     2016-10-30 22:23:15   R-self01-shCtDlyOff geLo
     2016-10-30 22:23:15   R-self01-shCtDlyOn geLo
     2016-10-30 22:23:15   R-self01-shCtOff geLo
     2016-10-30 22:23:15   R-self01-shCtOn geLo
     2016-10-30 22:23:15   R-self01-shCtValHi 100
     2016-10-30 22:23:15   R-self01-shCtValLo 50
     2016-10-30 22:23:15   R-self01-shMultiExec off
     2016-10-30 22:23:15   R-self01-shOffDly 0 s
     2016-10-30 22:23:15   R-self01-shOffTime unused
     2016-10-30 22:23:15   R-self01-shOffTimeMode absolut
     2016-10-30 22:23:15   R-self01-shOnDly 0 s
     2016-10-30 22:23:15   R-self01-shOnTime unused
     2016-10-30 22:23:15   R-self01-shOnTimeMode absolut
     2016-10-30 22:23:15   R-self01-shSwJtDlyOff off
     2016-10-30 22:23:15   R-self01-shSwJtDlyOn on
     2016-10-30 22:23:15   R-self01-shSwJtOff dlyOn
     2016-10-30 22:23:15   R-self01-shSwJtOn dlyOff
     2016-04-28 00:13:25   R-sign          off
     2016-10-30 22:23:13   RegL_00.          02:81 05:00 0A:AB 0B:42 0C:FE 12:50  00:00
     2016-10-30 22:23:13   RegL_01.         08:00 00:00
     2016-10-30 22:23:15   RegL_03.self01   02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:63 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:14 8C:63 00:00
     2016-10-30 22:20:20   battery         ok
     2016-10-30 22:20:20   deviceMsg       off (to vccu)
     2016-10-30 22:20:20   level           0
     2016-10-30 22:20:20   pct             0
     2016-10-30 22:23:14   peerList        self01,
     2016-10-30 22:12:52   powerOn         2016-10-30 22:12:52
     2016-10-30 22:20:20   recentStateType info
     2016-10-30 22:20:20   state           off
     2016-10-30 22:20:20   timedOn         off
   Helper:
     HM_CMDNR   26
     PONtest    0
     cSnd       01AB42FE361D630103,01AB42FE361D630104361D630103
     dlvlCmd    ++A011AB42FE361D630201000000
     mId        006C
     peerIDsRaw ,361D6301,00000000
     rxType     2
     Expert:
       def        1
       det        1
       raw        1
       tpl        1
     Io:
       newChn     +361D63,00,00,00
       nextSend   1477862595.45826
       rxt        0
       vccu       vccu
       p:
         361D63
         00
         00
         00
     Mrssi:
       mNo        1A
       Io:
         hmusb      -48
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       prs        1
     Rpt:
       IO         hmusb
       flg        A
       ts         1477862595.37823
       ack:
         HASH(0x5fc7828)
         1A8002AB42FE361D6300
     Rssi:
     Shadowreg:
     Tmpl:
   IODev      hmusb
   IOgrp      vccu
   alias      HM Batterie-Funkaktor 1 (unused)
   autoReadReg 0_off
   expert     251_anything
   firmware   1.7
   icon       message_socket
   model      HM-LC-SW1-BA-PCB
   msgRepeat  1
   peerIDs    00000000,361D6301,
   room       9 - HM Devices
   serialNr   MEQ0592487
   subType    switch
   webCmd     statusRequest:toggle:on:off
Was übersehe ich? Meines Erachtens sollte der nicht in ERR_Names auftauchen...?
Danke, Stefan
FHEM 21222 auf Gigabyte NUC, CubieTruck & RasPis (Test)
CUL 868MHz, nanoCUL 868MHz, nanoCUL 433MHz, JeeLink Clone, JeeLink Classic, HM-CFG-USB2, Rademacher
Devices: FHT, FS20, KS300, MAX, IT, HMS100, LaCrosse, PCA301, Revolt, HomeMatic, ESA2000, UNIRoll, Sonos, Duofern, Tasmota, MySensors
