fs20rsu status
Begonnen von Guest, 10 Januar 2011, 14:10:33
Guest
I'm using a fs20rsu for my shutters. The only thing what is so strange
in fhem you seethe states on and off, that is it the shutter is open,
it's on and when it's closed.
Is it possible to change it in fhem software to open and closed for
the fs20rsu?
fhem> l Rolluik
   BTN        10
   DEF        4661 10
   IODev      CUL
   NAME       Rolluik
   NR         58
   STATE      on
   TYPE       FS20
   XMIT       4661
   Code:
     1          4661 10
   Readings:
     2011-01-10 06:32:00   state           on
   model      fs20rsu
   room       Woonkamer
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Guest
Rudolf,
the eventmap works like described, only when restarting fhem it
doesn't work
Undefined value closed at /usr/bin/fhem.pl line 306.
and fhem doesn't start. When in statefile changed to off, it works.
> There is a new (one week old) global attribute in CVS exactly for this purpose:
> eventMap
> Exchange event or command names to a device specific version. This will also be
> used to exchange set arguments (if possible). Example:
>   attr store eventMap on:open off:closed
>   set store open
Guest
Hi Rudi,
I can confirm this, it's here:
if($attr{global}{statefile} && -r $attr{global}{statefile}) {
  $ret = CommandInclude(undef, $attr{global}{statefile});
  die($ret) if($ret);
Ciao, Arno
2011/1/31 kroon040 :
> Rudolf,
> doesn't work
>> eventMap
>>   set store open
Arno Willig
>   die($ret) if($ret);
The problem is, that since the last fhem.pl update CommandInclude actually
returns the errors so the "old" check is now has something to check. I replaced
it yesterday with a log message, as I dont think it is worth dying.
> doesn't work
Correct, I hope I could fixed it now.
To manually fix it add in fhem.pl/CommandSetstate() the line
  ReplaceEventMap($sdev, $b[2]);
before the CallFn line.
Guest
I grabbed the new fhem.pl, and now it works.
Richard
> > doesn't work
Guest
But other question. I want to set a memory setting with eventmap.
How must I do it?
I have this
attr Schutter eventMap on:open off:closed off-for-timer 10:mem
regards Richard
> Richard
> > > doesn't work
Nice idea, but currently won't work, sorry.
eventMap
  set store open
