Logfile Einstellung
Begonnen von visionsurfer, 12 November 2016, 13:15:14
visionsurfer
kann ich eigentlich meine Logfile irgendwie besser einstellen ? Die ist MEGA Groß. Wenn ich auf Logfile klicke, dann brauchte s gefühlt 2 Minuten, bis die geladen ist.
Kann ich das irgendwie kürzer machen ?
Hier mal nur ein MINI Auszug:
2016.11.12 13:11:03 3: meinLGW: Unknown code A0C80867019B99200000080CB35::-86:meinLGW, help me!
2016.11.12 13:11:05 3: KNX Unknown device 6206 (6/2/6), Value 00, please define it
2016.11.12 13:11:05 2: autocreate: define FileLog_KNX_0602006 FileLog ./log/KNX_0602006-%Y.log KNX_0602006
2016.11.12 13:11:23 3: meinLGW: Unknown code A0B80A25819B9921B78C2007F::-85:meinLGW, help me!
2016.11.12 13:11:23 3: meinLGW: Unknown code A0E8082021B78C219B992010162003D::-83:meinLGW, help me!
2016.11.12 13:11:29 2: huebridge_lounge: message for unknow device received: huebridge_lounge-3
2016.11.12 13:11:29 2: huebridge_lounge: message for unknow device received: huebridge_lounge-5
2016.11.12 13:11:29 2: huebridge_lounge: message for unknow device received: huebridge_lounge-4
2016.11.12 13:11:29 2: huebridge_tv: message for unknow device received: huebridge_tv-4
2016.11.12 13:11:29 3: SONOS0: Connection accepted from localhost:35896
2016.11.12 13:11:34 3: KNX Unknown device 620a (6/2/10), Value 00, please define it
2016.11.12 13:11:34 2: autocreate: define FileLog_KNX_0602010 FileLog ./log/KNX_0602010-%Y.log KNX_0602010
2016.11.12 13:11:48 3: KNX Unknown device 0209 (0/2/9), Value 0000, please define it
2016.11.12 13:11:48 2: autocreate: define FileLog_KNX_0002009 FileLog ./log/KNX_0002009-%Y.log KNX_0002009
2016.11.12 13:11:59 3: SONOS0: Connection accepted from localhost:35902
2016.11.12 13:12:00 3: KNX Unknown device 316a (3/1/106), Value 077b, please define it
2016.11.12 13:12:00 2: autocreate: define FileLog_KNX_0301106 FileLog ./log/KNX_0301106-%Y.log KNX_0301106
2016.11.12 13:12:24 3: KNX Unknown device 110a (1/1/10), Value 01, please define it
2016.11.12 13:12:24 2: autocreate: define FileLog_KNX_0101010 FileLog ./log/KNX_0101010-%Y.log KNX_0101010
2016.11.12 13:12:25 3: KNX Unknown device 116e (1/1/110), Value 01, please define it
2016.11.12 13:12:25 2: autocreate: define FileLog_KNX_0101110 FileLog ./log/KNX_0101110-%Y.log KNX_0101110
2016.11.12 13:12:32 2: huebridge_lounge: message for unknow device received: huebridge_lounge-3
2016.11.12 13:12:32 2: huebridge_lounge: message for unknow device received: huebridge_lounge-5
2016.11.12 13:12:32 2: huebridge_lounge: message for unknow device received: huebridge_lounge-4
2016.11.12 13:12:32 2: huebridge_tv: message for unknow device received: huebridge_tv-4
2016.11.12 13:12:32 3: SONOS0: Connection accepted from localhost:35914
2016.11.12 13:12:32 3: KNX Unknown device 316c (3/1/108), Value 0773, please define it
2016.11.12 13:12:33 2: autocreate: define FileLog_KNX_0301108 FileLog ./log/KNX_0301108-%Y.log KNX_0301108
So geht das ständig. Dauert kommt auch der Eintrag mit meinen KNX Devices.
Wie habt ihr das eingestellt ?
Grüße,
Visionsurfer
justme1968
warum legst du die unbekannten devices nicht einfach an? dann sind die meldungen weg.
ansonsten kannst du verbose passend setzen.
andre
visionsurfer
ja müsste ich grundsätzlich machen. Das sind bei mir aber ein paar hundert KNX Devices. Im schlimmsten Fall, will ich die gar nicht alle angelegt haben.
ok. Dann schau ich mir mal die verbose Einstellung an.
Danke.
Grüße,
Visionsurfer
marvin78
ignore könnte noch hilfreich sein.
Du kannst auch ein Tageslog daraus machen, dann wird täglich ein neues File angelegt (siehe Doku).
visionsurfer
wo finde ich die Doku, wie ich ein Tageslog drauß machen kann ?
Ich glaube meine Logfile macht mein FHEM total langsam.
Ich habe Verbose in der Global Einstellung mal auf 1 gestellt. Seit dem bin ich der Meinung, ist mein FHEM total träge.
Wenn ich rechts in der Navi auf Logfile klicke, läd sich das System einen Wolf. Meine Logfile ist riesig lang.
Gibt es irgendwo Lesematerial, wo ich lesen kann, wie ich das alles verbessern und optimieren kann.
Eigentlich hätte ich am liebsten das alle 3 Tage das Logfile gelöscht wird. Bzw. dann immer der letzte Tag gelöscht wird. Ein Logfile über 3 Tage reicht völlig, meiner Meinung.
Grüße,
Visionsurfer
#5
http://fhem.de/commandref_DE.html#FileLog
Du musst %d in die DEF vom Logfile einfügen ./log/fhem-%Y-%m-%d.log fakelog.
Mit den Attributen archivecmd / archivedir / nrarchive kannst Du erreichen, dass Logfiles nach 3 tagen gelöscht werden.
